Home » Eclipse Projects » Equinox » Plugin hot deploy
Plugin hot deploy [message #47736] Fri, 29 April 2005 06:36 Go to next message
Originally posted by: amottadelli.it.ibm.comnospam
It would be very nice to have a "hot deploy" facility for plugins and
new versions of plugins already deployed..... is it available/feasible?
Sandro
Re: Plugin hot deploy [message #47767 is a reply to message #47736] Fri, 29 April 2005 11:07 Go to previous messageGo to next message
Originally posted by: chaves.inf.no.ufsc.spam.br
I don't think anyone has implemented this yet. This was one of the most
interesting feature I found in JBoss - deploy by copying.
The update manager is capable of installing plug-ins while Eclipse is
running. Not all plug-ins are good citizens in a dynamic environment
(for example, the Eclipse IDE plug-ins), so the degree of success will
depend on the plug-ins involved.
The only thing missing (if this is what you meant by hot-deploy) is a
something that monitors the local sites (the main "plugins" directory
and any extension locations the Update Manager knows about), detecting
changes/addditions/deletions and taking the right actions accordingly.
Not sure whether Update provides API for changing the platform
configuration.
Or if you are *not* running with Update, you can go straight to the OSGi
API.
Rafael
> Sandro
Re: Plugin hot deploy [message #50304 is a reply to message #47767] Sat, 01 October 2005 05:28 Go to previous messageGo to next message
My customer will run some of the user base in a Citrix environment, so
I'm implementing a sort of "hot deploy" to allow the users to pick up
changes and additions to the local site (the application knows wich
plugins can be dynamically updated).
> configuration.
> API.
Yes, I can:
- easily detect that the local site is not up-to-date with the file system
- easily install/activate the changes using OSGI API
BUT:
I have not yet found any clean way to change the local site configuration.
As a result, the same changes are picked up at each refresh cycle.
Any suggestion?
Sandro
Re: Plugin hot deploy [message #50359 is a reply to message #50304] Mon, 03 October 2005 21:05 Go to previous messageGo to next message
Originally posted by: chaves.inf.no.spam.ufsc.br
The only clean I know is the configuration API:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/api/org/eclipse/update/configurat or/IPlatformConfiguration.html
>> most interesting feature I found in JBoss - deploy by copying.
>> configuration.
>> OSGi API.
> Yes, I can:
> BUT:
> Any suggestion?
> Sandro
Re: Plugin hot deploy [message #50387 is a reply to message #50359] Tue, 04 October 2005 01:37 Go to previous message
Thanks.
Actually I overlooked this API because I was trying to use "higher
level" APIs.....i.e. InstallOperation or
ReplaceFeatureVersionOperation.... this operations update the LocalSite
info AND the PlatformConfiguration (and provide some commit/rollback).
It appears that directly using PlatformConfiguration API will leave
LocalSite info outdated..... but maybe this will not be a problem.... I
will try.
Sandro
Previous Topic:Management of OSGi bundles (plugins)
Next Topic:shared install and varying configurations
Current Time: Sun Aug 31 07:02:18 EDT 2025
Powered by FUDForum. Page generated in 0.04149 seconds
