Home » Modeling » GMF (Graphical Modeling Framework) » How to add code to all XXXEditPart's and XXXViewFactories at one place?
How to add code to all XXXEditPart's and XXXViewFactories at one place? [message #47724] Thu, 14 September 2006 03:19 Go to next message
I want to overwrite handleNotificationEvent for all generated
XXXEditPart to listen for changes - but it's annoying and if I add new
component I’ll have to overwrite the same method again and again
the same is for XXXViewVactory - I have to modify createStyles to add
one more style.
I'm looking for a solution similar to EditPolicies where I use extension
point - org.eclipse.gmf.runtime.diagram.ui.editpolicyProviders and in my
class to install edit policy to EditPart if EditPart is one of those I'm
interested. Is there any similar mechanism for handleNotificationEvent
and createStyles ?
Trifonov
Re: How to add code to all XXXEditPart's and XXXViewFactories at one place? [message #47854 is a reply to message #47724] Thu, 14 September 2006 06:07 Go to previous messageGo to next message
Hello Trifonov,
You can try using dynamic templates.
Alex Shatalin
Re: How to add code to all XXXEditPart's and XXXViewFactories at one place? [message #47914 is a reply to message #47854] Thu, 14 September 2006 07:07 Go to previous messageGo to next message
Hi Alex,
I know that feature (Although, I haven't use it and I don't know details
about it) but if you change something in templates in next version of
GMF I'll have to rewrite my templates
Alex Shatalin wrote:
> Hello Trifonov,
> Alex Shatalin
Re: How to add code to all XXXEditPart's and XXXViewFactories at one place? [message #48094 is a reply to message #47914] Thu, 14 September 2006 11:06 Go to previous messageGo to next message
It depends on the level of template granularity.
If there's <jet include fail="silent"> in the very place you need change
in, you could place your extended code in the separate .jetinc file and
don't bother about merging templates in the future. Right now we don't
provide granularity finer than whole template, however, it doesn't mean we
won't if there's need (read: bugzilla)
Artem
"Trifonov" <ttrifonov@sbnd.net> wrote in message
news:eebd5k$c43$1@utils.eclipse.org...
> Hi Alex,
> about it) but if you change something in templates in next version of GMF
>> Hello Trifonov,
>> Alex Shatalin
Re: How to add code to all XXXEditPart's and XXXViewFactories at one place? [message #48531 is a reply to message #48094] Fri, 15 September 2006 02:25 Go to previous messageGo to next message
I've got the following hierarchy: AbstractWidget - is abstract class and
all concrete widgets extends it. I believe it will be very nice if I've
got generated AbstractWidgetEditpPart and AbstractWidgetViewFactory.
I'll be able to edit just the abstract classes and to get the
modification in my sub-classes easily. I made a note about that in the
treat where GMF 2.0 was discussed.
> Artem
>> Hi Alex,
>>> Hello Trifonov,
>>> Alex Shatalin
Re: How to add code to all XXXEditPart's and XXXViewFactories at one place? [message #48683 is a reply to message #47724] Fri, 15 September 2006 06:19 Go to previous message
Originally posted by: 5d5.mail.ru
I guess these are quite generic requirements - plug in custom edit
policy to update edit part / view on changes in domain / notation models
and define custom style in gmfgraph model; we could support them in
tooling...
Maybe such enhancement requests should be added to bugzilla?
Trifonov wrote:
> one more style.
> and createStyles ?
> Trifonov
Previous Topic:Develop a tool similar to ACME
Next Topic:classes not being generated
Current Time: Sat Jul 26 23:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.03979 seconds
