Home » Newcomers » Newcomers » Default project directory
Default project directory [message #47687] Tue, 05 April 2005 16:37 Go to next message
Originally posted by: milicchio.dia.uniroma3.it
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig33E31F48478A225CB3AD58BA
Hi. I'm using eclipse 3 (gtk/linux)
I know it's a stupid question, but eclipse 2 had an option for
specifying the default project directory, and now in version 3 I can't
find it anymore...
Is is possible to change it or not?
Franco Milicchio <mailto:milicchio@dia.uniroma3.it> <pgp:E4685CF0>
No keyboard found. Press F1 to continue...
(Almost every BIOS available in this world... even yours!)
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCUvcmbSPkY+RoXPARAv+pAJ9uqkpUcMb71mDOP0Owj8VwwgjOdgCf cOIx
hA29s7cyF1wEzDQRYLt/Yr0=
=Hauh
-----END PGP SIGNATURE-----
--------------enig33E31F48478A225CB3AD58BA--
Re: Default project directory [message #48186 is a reply to message #47687] Wed, 06 April 2005 13:10 Go to previous messageGo to next message
Originally posted by: rightactions.hotmail.com
"Franco" <milicchio@dia.uniroma3.it> wrote in message
news:d2ut5r$73h$1@news.eclipse.org...
> an option for specifying the default project directory,
> and now in version 3 I can't find it anymore...
Yes. Here's how I did it on Eclipse 3.1M6
running on Windows XP:
(0) Exit Eclipse.
(1) Find the file "org.eclipse.ui.ide.prefs".
(2) Open it with a simple text editor.
(3) Find SHOW_WORKSPACE_SELECTION_DIALOG
(4) Change it from "true" to "false".
(5) Save the file and close the editor.
(6) Restart Eclipse and the Workspace Launcher will appear.
(7) Choose the desired workspace.
(8) Check "Use this as the default and do not ask again".
(9) Click OK.
Explanation:
New installations of Eclipse 3.1 (and 3.0 also, if I
remember correctly) display the Workspace Launcher
dialog when Eclipse is launched. The user is asked
to "Select a workspace" for the session from a list
that can include the most recently used workspaces.
(A user can also type in or browse for a folder to
use the "Workspace" field.)
This dialog has a checkbox for the option "Use this
as the default and do not ask again". When checked,
the Workspace Launcher no longer appears when
Eclipse launches.
The Workspace Launcher is also available while
using the Eclipse workbench. From the menu bar,
choose File, Switch Workspace. Unfortunately,
if Eclipse was told "do not ask again" it obeys
all too well. The "Use this..." checkbox will not
be available!
(So, maybe the user does not want to set a
default after all.)
Re: Default project directory [message #48292 is a reply to message #48186] Wed, 06 April 2005 16:14 Go to previous messageGo to next message
> (0) Exit Eclipse.
> (9) Click OK.
> Explanation:
> Eclipse launches.
> be available!
> default after all.)
Or you could simply go to Window->Preferences->Workbench->Startup and
Shutdown and check "Prompt for workspace on startup" But your way's
good too. :D
- Jeff
Re: Default project directory [message #48443 is a reply to message #48292] Wed, 06 April 2005 21:03 Go to previous messageGo to next message
--------------enig452965A189773C9798F98A31
> good too. :D
The problem is that the checkbox is on...
iD8DBQFCVIb8bSPkY+RoXPARApwbAJ4/Yyv5ZAip5Di9ZCApUo/MiL2mmwCe M77u
bgXZgnuNbgw81tHRYEm6Xl4=
=fqkd
--------------enig452965A189773C9798F98A31--
Re: Default project directory [message #48556 is a reply to message #48292] Thu, 07 April 2005 07:11 Go to previous message
"Jeff Myers" <myersj@gmail.com> wrote in message
news:d31g62$qqa$1@news.eclipse.org...
> Michael I. wrote:
>> Franco wrote...
>>> Hi. I'm using eclipse 3 (gtk/linux) [...Where is]
>>>directory[?]
>> [snipped, maybe you don't want to know--MI.]
> Workbench->Startup and Shutdown and check
> "Prompt for workspace on startup" But your way's good too. :D
Golly, I rummaged through the Eclipse HTML docs
and never did find that. Grr. ("Preferences", eh? Doh!)
Oh, and in my Eclipse installation (3.1M6) "General"
is substituted for "Workbench". Other than that,
your way is MORE than good.
Previous Topic:XMIResourceFactoryImpl cannot be resolved
Next Topic:icon display problem with eclipse on sun blade
Current Time: Thu Jul 17 07:31:29 EDT 2025
Powered by FUDForum. Page generated in 0.10360 seconds
