Home » Language IDEs » Java Development Tools (JDT) » Assigning an additionally none java file extension for build/compilation...?
Assigning an additionally none java file extension for build/compilation...? [message #47668] Tue, 03 June 2003 13:30 Go to next message
Originally posted by: vkyr.nospam-ision.net
For a custom java compilation unit code generator, I would need the ability
to hook it's none ".java" file extension after the build to the Eclipse Java
compilation process. How can you programmatically assign a different file
extension (say xxx.gjava) to the common Eclipse incremental compilation
mechanism for projects?
Valentino
Re: Assigning an additionally none java file extension for build/compilation...? [message #49893 is a reply to message #47668] Thu, 05 June 2003 05:24 Go to previous message
Nobody ever tweaked around with something like this?
"Valentino Kyriakides" <vkyr@nospam-ision.net> schrieb im Newsbeitrag
news:bbilvv$28q$1@rogue.oti.com...
ability
Java
> Valentino
Previous Topic:Run ANT with different JVM
Next Topic:IClasspathContainer and JavaModel update problem
Current Time: Sun Jul 27 03:01:16 EDT 2025
Powered by FUDForum. Page generated in 0.03793 seconds
