Home » Language IDEs » PHP Development Tools (PDT) » Can't get XDebug to work
Can't get XDebug to work [message #47626] Wed, 29 August 2007 02:46 Go to next message
Just started with trying to get debugging to work. I work on a remote
development server and use an ssh tunnel to forward a remote port to my
local computer. That works fine, when I manually launch the windows xdebug
client and start an XDEBUG session it gets a connection from the web server.
However when I subsequently try to debug in eclipse nothing happens
(breakpoints are ignored).
I have configured my debug as followed:
Open Debug Dialog > PHP Web Page > New
Server Debugger: XDebug
File / Project: /Project/name/index.php
Breakpoint: Break at First Line (tried to set this both on and off)
URL: Autogenerate (comes up with the correct:
http://some.host/some/path/name/index.php)
Session Settings: Open in Browser > Debug All Pages
Save as: Local file
Standard Input and Output: Allocate Console
Tried with 'Launch in background' both on and off
Marijn.
Re: Can't get XDebug to work [message #47712 is a reply to message #47626] Wed, 29 August 2007 05:45 Go to previous messageGo to next message
Hi Marjin,
are you sure a connection is established ? ie the launching task disappears
from the bottom right hand corner of eclipse ?
If it does I would expect Break at first line to work. I would not expect
breakpoints to work. Currently the only way to debug web pages is for
either apache or IIS to be on your workstation and for the document root to
point to either your workspace or a specific project. For your kind of
situation you need path mapping which maps the files in your workspace to
the file located on your web server (xdebug needs to be told the fully
qualified filename of the file to place the breakpoint in which is not going
to be the same as the one in your workspace). There is currently no path mapping
solution available in PDT.
Dave Kelsey
Marijn van Zon wrote:
> Hello,
> Save as: Local file
> Marijn.
Re: Can't get XDebug to work [message #47889 is a reply to message #47712] Wed, 29 August 2007 18:24 Go to previous messageGo to next message
There does not seem to be a launching task at all and the debugger does not
finish by itself. Even when I terminate it it keeps listening (don't know if
this is expected behaviour or not). Is there a way to get more detailed
information on what happens when I fire up a debug session?
As for the path mapping I actually use RSE and create a new folder that
links to the development server, so I am in a sense working directly there
and not locally doing synchronizations every once in a while.
I did however have to patch WST in order to get it working. Instead of an
IPath.toString() (which returns null for remote systems) an URI.toString()
is returned (from an IFile.getLocationURI()). Would this be sufficient to
overcome the deficit or would it still be present?
Marijn.
"Dave Kelsey" <dkel50@hotmail.com> wrote in message
news:fb3f7a$u8b$1@build.eclipse.org...
> Hi Marjin,
> disappears
> to
> going
> mapping
> Dave Kelsey
>> Hello,
>> xdebug client and start an XDEBUG session it gets a connection from the
>> web server.
>> Save as: Local file
>> Regards,
>> Marijn.
Re: Can't get XDebug to work [message #47920 is a reply to message #47889] Wed, 29 August 2007 20:12 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
I suspect (although I have not tried RSE) that it won't work. The
Information that has to be sent to XDebug on the server is the real
physical location of the file the server sees, and there is a good
chance that eclipse doesn't present that information from the standard apis.
PDT will always be listening on the appropriate port waiting for a
connection. When an XDebug launch is done, PDT waits for that 1st
initial session to connect, and if it didn't the launch will remain
incomplete waiting for that connection.
Dave Kelsey
> Marijn.
>> Hi Marjin,
>> disappears
>> to
>> going
>> mapping
>> Dave Kelsey
>>> Hello,
>>> web server.
>>> Save as: Local file
>>> Regards,
>>> Marijn.
Re: Can't get XDebug to work [message #48040 is a reply to message #47712] Thu, 30 August 2007 03:50 Go to previous messageGo to next message
Originally posted by: eclipse-news.mark-kirchner.de
Dave Kelsey wrote:
> For your kind of situation you need path mapping which maps the files
> in your workspace to the file located on your web server (xdebug
> needs to be told the fully qualified filename of the file to place
> the breakpoint in which is not going to be the same as the one in
> your workspace). There is currently no path mapping solution
> available in PDT.
Any plans / timeframe when this will be the case? I got that kind of
debugging to work for PDT M1 with your "standalone" XDebug-plugin v0.23
and the SampleMapper v0.0.2, so it seems that there already has been
some kind of solution for this problem.
It would be a real pity if switching to a newer version of PDT would be
blocked by the inability to debug remotely (or cross-platform in our case).
Regards (and thanks for the great work on the XDebug-integration),
Mark
Re: Can't get XDebug to work [message #48069 is a reply to message #48040] Thu, 30 August 2007 04:00 Go to previous messageGo to next message
Mark Kirchner schrieb:
> I got that kind of debugging to work for PDT M1 with [...]
Sorry, that should read "PDT M2".
Mark
Re: Can't get XDebug to work [message #48503 is a reply to message #48040] Thu, 30 August 2007 15:39 Go to previous message
Hi Mark. I hope that I can sort out a solution for this soon.
Cheers
Dave Kelsey
Mark Kirchner wrote:
>> available in PDT.
> Mark
Previous Topic:SPL Exception subclasses
Next Topic:Milestone 3 & Voting for the PDT 1.0
Current Time: Sun Nov 09 06:36:15 EST 2025
Powered by FUDForum. Page generated in 0.04140 seconds
