Home » Eclipse Projects » Subversive » Migrate Team Project Set from Subclipse to Subversive
Migrate Team Project Set from Subclipse to Subversive [message #47604] Fri, 19 June 2009 11:24 Go to next message
in the past I used Team Project Sets to setup a Eclipse Workspace. I also
used in the past the Subversion Plugin "subclipse". As I realized that
"subversive" will become the standard Subversion Plugin I think about
changing the Subversion Plugin to "subversive".
But I have a lot off Team Project Sets (up to one hundred) in "subclipse"
"style" and it is not possible to import this Team Project Set with
subversive to set up a Workspace.
This is "subversive" style:
<project
reference="1.0.1,https://<repository-url>/<project>,<project>,a0fd5f26b35c001e1ae8f6c792be63aa; <repository-url>;<repository-url> ;branches;tags;trunk;true;200259ad-b061-0410-8518-b3213f39e7 aa; <repository-url>;;false;;;22"/>
More straightforward is the "subclipse" style:
<project reference="0.9.3,<repository-url>/<project>,<project>"/ >
Does anybody know a way how to migrate Team Project Sets form "subclipse"
style to "subversive" style?
Any help would be appreciated - many thanks in advance!
Re: Migrate Team Project Set from Subclipse to Subversive [message #47634 is a reply to message #47604] Mon, 22 June 2009 03:27 Go to previous messageGo to next message
Hello Simon,
Subversive can read Subclipse project set files, for more details please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=276947. This functionality
will be available in the next weekly build.
> Hello,
> changing the Subversion Plugin to "subversive". But I have a lot off Team
> Project Sets (up to one hundred) in "subclipse" "style" and it is not
> possible to import this Team Project Set with subversive to set up a
> Workspace.
> <project
Re: Migrate Team Project Set from Subclipse to Subversive [message #47692 is a reply to message #47634] Mon, 22 June 2009 11:18 Go to previous messageGo to next message
Hello Igor,
thank you for your answer!
It's good to notice and I'm more relaxed that Subversive will support
Subclipse generated TeamProjectSet. :-)
Just a question to the current state of the Bug-ID. The Bug-ID was opened
in mid-May. The Subversive Version mentioned in this Bug-ID is
"Eclipse 3.5M6 with Subversive 0.7.6.I20090213-1500". The solution of this
Bug-ID is that the support of Subclipse TeamProjectSets will be available
in next weekly build. Now it's end of June.
I'm using "Subversive Version 0.7.8.I20090506-1500". This Version can not
support Subclipse generated TeamProjectSets obviously...? Is there a
weekly build available, so i can see and test this feature?
Many thanks in advance
Re: Migrate Team Project Set from Subclipse to Subversive [message #48236 is a reply to message #47692] Fri, 03 July 2009 10:33 Go to previous messageGo to next message
Hello Simon,
We didn't yet create a weekly build because we were busy with Galileo
preparations. We didn't yet create a weekly build which includes this
feature.
> Hello Igor,
>> see https://bugs.eclipse.org/bugs/show_bug.cgi?id=276947. This
>> functionality will be available in the next weekly build.
> in mid-May. The Subversive Version mentioned in this Bug-ID is "Eclipse
> 3.5M6 with Subversive 0.7.6.I20090213-1500". The solution of this Bug-ID
> is that the support of Subclipse TeamProjectSets will be available in
Re: Migrate Team Project Set from Subclipse to Subversive [message #49089 is a reply to message #48236] Thu, 09 July 2009 12:19 Go to previous messageGo to next message
Hello Igor,
> feature.
Thank you for your answer. I realized that this feature isn't included
already. I see there is a lot of work for you with Galileo preparations.
I hope it is sure to have this feature included in subversive in one of
the next versions. Do you know whether I have to change the "provider
id"-tag in the Team Project Set from
<provider id="org.tigris.subversion.subclipse.core.svnnature">
to
<provider id="org.eclipse.team.svn.core.svnnature">
Yours sincerely
Re: Migrate Team Project Set from Subclipse to Subversive [message #49553 is a reply to message #49089] Sat, 18 July 2009 12:04 Go to previous message
Hello Simon,
>Do you know whether I have to change the "provider id"-tag in the Team
>Project Set from ...
You don't need to change anything
> Hello Igor,
>> feature.
> to <provider id="org.eclipse.team.svn.core.svnnature">
> Yours sincerely
Previous Topic:Ganymede SVN problems: Authenication & Random 403 errors?
Next Topic:Team -> Disconnect missing
Current Time: Thu Jul 17 20:55:24 EDT 2025
Powered by FUDForum. Page generated in 2.01858 seconds
