Home » Eclipse Projects » DTP » Could not open the editor: Editor could not be initialized.
Could not open the editor: Editor could not be initialized. [message #47558] Tue, 22 July 2008 21:04 Go to next message
Dear All,
Does anyone encountered this problem?
I am using Ganymede (3.4) on windows xp sp 3 with JDK 1.5.0_09.
The Data Tools Platform Connectivity is
1.6.0.v200805151245-7_70Dn-QXuj8_GoX7JfPiBEG.
When I open a file of extension "*.sql", it open in the "SQL File
Editor" but with the error message and stack trace below.
java.lang.NoClassDefFoundError
at javax.crypto.SecretKeyFactory.getInstance(DashoA12275)
org.eclipse.datatools.connectivity.internal.security.Default CipherProvider.loadKey(DefaultCipherProvider.java:66)
org.eclipse.datatools.connectivity.internal.security.Default CipherProvider.createDecryptionCipher(DefaultCipherProvider. java:48)
org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:749)
org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:489)
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadProfiles(InternalProfileManager.java:936)
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfiles(InternalProfileManager.java:135)
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfileByName(InternalProfileManager.java:210)
org.eclipse.datatools.connectivity.ProfileManager.getProfile ByName(ProfileManager.java:96)
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getConnectionProfile(SQLEditorConnectionInfo.java:106)
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getSharedConnection(SQLEditorConnectionInfo.java:229)
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.isConnected(SQLEditorConnectionInfo.java:252)
org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getName(SQLEditorConnectionInfo.java:214)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.refreshCo nnectionStatus(SQLEditor.java:1726)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.refreshConnectionStatus(SQLScrapbookEdito r.java:264)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.doSetInpu t(SQLEditor.java:919)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.doSetInput(SQLScrapbookEditor.java:173)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3025)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:446)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:354)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2483)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3043)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3070)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.init(SQLE ditor.java:544)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.init(SQLScrapbookEditor.java:128)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
konkeong
Re: Could not open the editor: Editor could not be initialized. [message #47592 is a reply to message #47558] Wed, 23 July 2008 09:19 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Can you provide a series of steps to reproduce this issue from a clean
environment?
"Lee Kon Keong" <konkeong@uberfusion.com> wrote in message
news:g6603q$faf$1@build.eclipse.org...
> Dear All,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> konkeong
Re: Could not open the editor: Editor could not be initialized. [message #47650 is a reply to message #47592] Wed, 23 July 2008 21:07 Go to previous messageGo to next message
My mistake.
I was trying to overwrite the "local_policy.jar" and
"US_export_policy.jar" in my
"C:\Program Files\Java\jre1.5.0_09\lib\security" directory with
"enhanced" copy, so that I can do AES more than 128 bit encryption.
Apparently, I just rename the above 2 jar files to something else, and
forgot to copy the new jar files in.
Essentially, my JRE is missing those 2 jar files.
After I put back in those 2 jar files, there is no more error message.
Everything works fine.
> environment?
>> Dear All,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Thanks
>> konkeong
Re: Could not open the editor: Editor could not be initialized. [message #47717 is a reply to message #47650] Thu, 24 July 2008 09:53 Go to previous message
Glad it was an easy fix! :)
news:g68kkg$tn0$1@build.eclipse.org...
> My mistake.
> "C:\Program Files\Java\jre1.5.0_09\lib\security" directory with "enhanced"
>> environment?
>>> Dear All,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks
>>> konkeong
Re: Could not open the editor: Editor could not be initialized. [message #592187 is a reply to message #47558] Wed, 23 July 2008 09:19 Go to previous message
environment?
> Dear All,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> konkeong
Re: Could not open the editor: Editor could not be initialized. [message #592202 is a reply to message #47592] Wed, 23 July 2008 21:07 Go to previous message
My mistake.
> environment?
>> Dear All,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks
>> konkeong
Re: Could not open the editor: Editor could not be initialized. [message #592234 is a reply to message #47650] Thu, 24 July 2008 09:53 Go to previous message
> My mistake.
>> environment?
>>> Dear All,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks
>>> konkeong
Previous Topic:ODA Plugin Project Structure / References / Deployment
Next Topic:[ODA Ecore] Integration and Deployment Questions
Current Time: Tue Jul 22 22:09:42 EDT 2025
Powered by FUDForum. Page generated in 0.25172 seconds
