Home » Modeling » M2T (model-to-text transformation) » How to set the transformation output file path?
How to set the transformation output file path? [message #47554] Thu, 10 July 2008 11:17 Go to next message
Originally posted by: georges.bachelier.atmel.com
Hello everyone,
I would like my JET transformation output file name to be based on some
variables values.
The current JET code is:
<ws:file template="templates/flow_template.jet"
path="{$org.eclipse.jet.resource.project.name}/flow.xml"/>
I have changed it to:
path="{$org.eclipse.jet.resource.project.name}/"/><c:get
select="/Flow/@flowName"/>"."<c:get select="/Flow/@flowCategory"/>".xml"/>
where Flow is an Ecore element with flowName and flowCategory attributes.
I would like the output file name to be
<flowName_value>.<flowCategory_value>.xml
When I run my transformation, I get the following error message:
org.eclipse.jet.taglib.JET2TagException: Path must include project and
resource name: /FlowEditor/
Could you please help me to fix this?
Thanks a lot in advance for your time,
Georges
Re: How to set the transformation output file path? [message #47587 is a reply to message #47554] Fri, 11 July 2008 07:51 Go to previous message
Georges:
Try:
path=" {$org.eclipse.jet.resource.project.name}/{/Flow/@flowName}.{ /Flow/@flowCategory}.xml "/>
In general, any JET tag's attribute value can be composed of multiple
'dynamic XPath' expressions between { and }. So, the above ws:file tag has
three expressions in the path attribute:
* $org.eclipse.jet.resource.project.name gives name of the project of the
input model
* /Flow/@flowName and /Flow/@flowCategory give components of the file
name.
Paul
Previous Topic:Xpand Ganymede Roadmap
Next Topic:iteration over an iterable object not a select
Current Time: Mon Jul 21 22:52:25 EDT 2025
Powered by FUDForum. Page generated in 0.04738 seconds
