Cannot create part for *.aj file? [message #47547] |
Tue, 08 February 2005 11:27  |
(I'm using 1.2.0.20050204153223 with 3.1M4)
If I create an aspect via "New Aspect Wizard", the file is created is
the .aj extension but the editor part cannot be created. Clearly this
must work else the plugin would not be usable. What step am I missing?
thanks!!
barry kaplan
groups1@memelet.com
Re: Cannot create part for *.aj file? [message #47843 is a reply to message #47813] |
Thu, 10 February 2005 05:33  |
Originally posted by: mchapman.uk.ibm.com
On Wed, 09 Feb 2005 13:10:28 -0500, Barry Kaplan wrote:
> Well, now it works again. After some random changing settings and
> eclipse restarts, *.aj files are working as expected (with of course
> lots of missing functionality like imports, completion, etc that I
> understand is to be expected at this time). I'll stop posting problems
> for a bit until I can get things stabilized and see some patterns.
Hi Barry,
Much more of this functionality should be working in .aj files in the
1.2.0 stream. Add import, organise imports, and ctrl-space content assist
should in general be working, subject only to minor limitations.
If you're still getting problems please post any stack traces from your
error log, and entries from the AJDT Event Trace view (under Show view >
Other > AspectJ).
> (BTW, where is the better place for ajdt issues: here or the mailing list?)
We monitor both places, but here is probably best for these sort of
problems, as the ajdt-dev list is primarily for development discussions.
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Cannot create part for *.aj file? [message #586500 is a reply to message #47607] |
Tue, 08 February 2005 14:59  |
Barry Kaplan wrote:
> So I change the plugin to create aspects with the .java extension. But
> when now when I open the file (using AspectJ/Java Editor) the syntax
> is not recoginized (ie, the keyword 'aspect' is marked as unrecognized).
Turning off "show errors as you type" seems to fix this problem.
barry kaplan
groups1@memelet.com
Re: Cannot create part for *.aj file? [message #586570 is a reply to message #47726] |
Wed, 09 February 2005 12:08  |
Barry Kaplan wrote:
> Barry Kaplan wrote:
> Well, I'm mighty confused. I just switched over to another workspace
> (different code base) and created an *.aj file just fine, editor part
> and all. Don't know what was wrong in the other workspace.
I take it back. The editor part created but it has no functionality (eg,
no error marking, no completion). I had to rename the file back to a *.java.
barry kaplan
groups1@memelet.com
Re: Cannot create part for *.aj file? [message #586584 is a reply to message #47756] |
Wed, 09 February 2005 12:36  |
Barry,
Clearly things are going pretty wrong for you. Could you look in your
error log for any clues? (Window > Show View > Error Log)
Matt.
Matt Chapman
Re: Cannot create part for *.aj file? [message #586592 is a reply to message #47785] |
Wed, 09 February 2005 13:10  |
thanks!
barry kaplan
groups1@memelet.com
Re: Cannot create part for *.aj file? [message #586604 is a reply to message #47813] |
Hi Barry,
Other > AspectJ).
Matt.
Matt Chapman
FUDForum. Page generated in 0.13685 seconds
