| Error: unable connect... [message #47487] |
Thu, 18 June 2009 03:09   |
Eclipse User  |
Originally posted by: antispam.domain.invalid
While launching my Eclipse (3.4.1) this morning, I got this error message:
> SVN: '0x00000000: Open Project' operation finished with error: 0x00000000: Unable connect to 'xxxx' project.
> Please check that SVN meta-information exists and its format is supported by the current SVN plug-in version.
> If so, it is possible that project working copy is relocated outside plug-in control.
> At the current moment project will be automatically disconnected from source control.
Now my projects are no more available in SVN perspective...
What should I do now?
Thanks in advance.
Patrick
| Re: Error: unable connect... [message #47721 is a reply to message #47663] |
Mon, 22 June 2009 12:49    |
Eclipse User  |
Patrick,
There should also be an option there to use an existing repository
location. I've successfully used this in the past to reconnect projects
that were previously connected.
Patrick Godeau wrote:
> Le 18/06/2009 18:47, Joseph Gay a écrit :
>> Patrick,
>> Try right clicking on a project that was connected, go to Team -> Share
>> Project, select SVN (as opposed to CVS), and see if the wizard that
>> comes up will allow you to reconnect your project(s).
> I tried this but it says:
> "This wizard will help you to share your files with the SVN repository
> for the first time."
> This is not what would be expected.
> Any idea?
>>> Hello,
>>> message:
>>>> plug-in control.
>>>> source control.
>>> Thanks in advance.
| Re: Error: unable connect... [message #47810 is a reply to message #47721] |
Thu, 25 June 2009 04:06   |
Eclipse User  |
I solved this problem by changing the SVN connector to SVN Kit SVN/1.6.1.
>>>> message:
>>>>> plug-in control.
>>>>> source control.
FUDForum. Page generated in 0.04172 seconds
