Home » Modeling » Epsilon » (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel"
(Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #4150] |
Thu, 20 November 2008 08:31  |
Hi there,
I'm new to using Epsilon and have been experimenting with some simple
model-model translations using ETL.
I'm able to create .launch files to perform this, but would like to make
use of Epsilon tasks in Ant, to describe work-flows, so that 2+ step
builds can be performed with a single script.
My .xml build file contains the line:
<epsilon.loadModel name="SomeModel" type="EMF">
Then, when I run this Ant build file, I get the message:
...myFile.xml:5: Problem: failed to create task or type epsilon.loadModel
Cause: The name is undefined.
I'm probably making some basic error, but any help will be much
appreciated.
Edd.
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #4221 is a reply to message #4150] |
Thu, 20 November 2008 11:47   |
--------------010504070806040905010108
Hi Edd,
Could this be because you're running the build from a JRE other than the
Eclipse JRE?
Click the drop-down arrow next to the External Tools button (green arrow
with a brick) and then select "External Tools Configuration..." Click
your ANT script's configuration and click the JRE tab. Then select "Run
in the same JRE as the workspace." Click Apply and then Run.
The attached screenshot shows the correct JRE option selected.
Louis.
Edd wrote:
> Hi there,
> <epsilon.loadModel name="SomeModel" type="EMF"> ..
> appreciated.
> Edd.
Content-Type: image/png;
name="BuildConfig.png"
Content-Disposition: inline;
filename="BuildConfig.png"
iVBORw0KGgoAAAANSUhEUgAAA9gAAAKJCAYAAABAj4GXAAAABHNCSVQICAgI fAhkiAAAAB50
RVh0Q1JFQVRPUgBnbm9tZS1wYW5lbC1zY3JlZW5zaG90HJc3dwAAIABJREFU eJzs3Xd8FHX+
x/HXzO6mUBIgIRAChN57lWIDQZHz8FTUU/HwDhX7KT/AOyuWE1FOTyyA9fRs KHqAniICKoKA
0luCgElIo4SEtK0z8/tjC7ubTbJJNtTP8/FYsrvzne985zsbkne+M99RCGHM pIeNUO8LIYQQ
QgghhBACVrz3lBL8ntn/xWW3zTFimnflz38YefJaJYQQQgghhBBCnGEath1s 2I6k8/XCGb6g
7QvYl902x7jztr8AkHes/BQ0TwghhBBCCCGEqF8Fx8txaXqt1jWbVBLiGwAw 6YrhwHAAwxuy
zXAiXOccLYtIg4UQQgghhBBCiNNNwfFyjhWXsfvnlbVav8fg0ei6QUJ8Aw4X WQEYPuoK8IRs
M0BM864AGEbFS693vBddqw33nmSv1XpCCCGEEEIIIUSkHSu2crSolLRNqxg9 7iq6tmlao/XT
Dxay8qvP6DZwFADN4mJ9y7yZWhkz6WHjj5PvoNzurFDBrv/EsCd3PgoqKCoK KqpiAsyoioqC
GRUzimJCUbzPzaiKCbuaz/h7JtR+74UQQgghhBBCiAg5dKyUn3/4HxeMmUDL Zo1qVcf2fXmk
bVrF4Asup4VfHXlHS9i44uMT12CHGLz2UAEFDFBUFUVRwDAwDAVVUUABULxf PP8o1dQphBBC
1K8V368HYMyF553TbaipIwWFpP2agc3uPhNtzIXnnXH7caa1VwghxMmheKYi a9msEZpeu7Ca
1KwxaZ66QuVdv4AdegMqCoaikBDfkD9fPpD2yU0pc8HarYfJL3NSbnNQUFBC WakTl01BUQzf
hiqrUwghxKn37Q8bKl12yQVDa1RHuOVPlm9/2MCSZ68DYMLMj0O2r6r9h7rv UzhtCJeu62Rm
53P4aAHl5TZ0wyDKYqFRw1j69+5Wp3b6O1JQSLRRxssPjCUxvgGK4m57pPYj 0kJ9/iLZ70II
Ic4uqnLirlq6X8D+cuVaAMaPHhFQvrL3vXWFyru+gK1XFoYVM1EmhQcnXUD7 XikcK9dI33WM
zFIXdrsDu9WGoWooZju6SUE1GnvHsyuvUwghxCm1as1GXwgJZcLMjxl1/pCw 6win/KkU/POo
uv2HyO9TbX8mOpxOtu3Yw2VDOzBiQg9aNW+MxaRSVGoj61Ax/1q8hX69ukak jen7M5n31zE0
b9KAe1/4msz84xXKnC4/28P9/J0u7RVCCHHqKf4B2/Pz4atV65j3f78H4J7n lzJu1PAq3/ev
K9TPmGpPEVcVlZsv7ElSQiPKXQrHHIBiYLfbsdls2Gw2rFYr5TYr5eU2YlSD htEJVdYphBDi
9DFh5scV3rt45BD27P2NvENH6NwxldbJLQA4mJvPvgNZJLdoXmGdVWs2cvHI EyHnYE4+OXmH
sNkdREVZaJ3cgratk33LV/+4EYDOHVPJys7Dbndw8cghvve7d+5ARnYuNpud BrExdOmYSpP4
uBP1e9qiAJYoC4nNmtCxfVvMJlOFtgX/PLp45JCA/fYPal4d2rVm3cZt2B0O oqMstGqZRNs2
rfD+aDaArOxccvOOVFomuA1Fx0vYn3GQsrJyDKBJXGPapLSkWdP4EGuAy6Wx Y1caT0y5gDZJ
8byxbDNrtx/E6dLp2jaRP1zUDUVRMIzw2lNd39psdpo3aQhA1qET4drbLxeP HOLry+zcQxzM
ycfucNAgNoa2rZPZs/eAr5z/9vw/F8HvVfY5gJodY+/nz//Yetsbib6Bmh8/ IYQQp5fKRrC9
5v3f77nn+aW+5/6Cy6uen7/Bqh3BVhULXVMSKD1cypFyKLTrHMovxmazY7Pa KLdasZZbsVpt
WK3l2NFpGJNYZZ1CCCFOLxeOGBzwes+vB5h4fgcuGTyKhUs2s+1AFoZhMLBj PHNvv44VPx9g
zOBRvvL+AfXCEYPZtedXRvRswfSJl9C8SQMKS2z876d9fL8tnZ49uvD92p99 6yxcspkHr72U
hPgGXPngidORX/pkI/deOZoWzRqSe6SEBUs2c8yAJvGNyc49RM+UGObefh2G YVBUaufnPbl8
uHIPPbp1qbB/oX4eeff5+7U/V3h/x+5fGdC+MX+7vh8J8Q04Vmxl+Yb9rNyy l949OgOwY/ev
jOqXXGUZf8eKitGsx3j45vNol9wEBdidcYQv1u3jaKFBsyYVQ9pvWdlcc1E3 OrRqyjv/28Yv
vx6jT+9eqKpCcUkp8z7bSq/undENo9r2+Pd5qL5dvSMtYFT/v7MrjvB7j+/u 9H0M7dqcGdeO
ISEultyCUhav3sPsoD9UBH8u/NsQXCb4c9CxfdtKj/GxotKAtlZWp3e7de2b Y56PT02PnxBC
iNOLX772/W4w5sLzuOf5pb5AHRys73l+KWMuPK/C7xKKEvr3i2qvwQaFBo2i yGqTjKYbmHSD
9k0b0rZ/G1yajqYZaBq4NB2XrlN6vIQ1H2S650WTgC2EEGeE4JA58rwBvPnF NjqkNOEvv+vH
QwtXowCTx/djf04hb325jZc/rRiWLhg+iIPZeZzfuyWTL+/Lqk0ZzP/8F666 qDs3j+uDputs
z8oP2FbblvHc++JyyqyOgPd7tGvOtHkr6NspiQcnjeDuqwfx15e+ZfCA3mia RlJiE+7+51cc
Kijjgv5tueeaIZhUhY+/P1Bh/2ry8yjzYC6j+7fipkt78/n3aXywYic3Xdqb my7tjWEYbNqf
iwHVlgm2Z+9+FkwfR7O4WP7x7x/Zuu8Q3domcv3YPjz34Qaa+o3Oex0pKGR4 L/do7g9bMunU
pTMmkwpAfFxj4uMaYxgGWdl5NWpPZX0bfL21l3+Yzck9xJAuidz6+/5s2J3D /81bgWpSueuq
QSH7M9x5Wfw/BxcMH0RWdl6VxzhUWy8YPogf1v0SUG84xzOcvtF0vcbHTwgh xOmlshHs0ecP
DQjZXvc8v5TR5w8NOdpd7TXYDqcWshEKZnSg8U+7+TzDSlG5zTdaXW61UV5W jtVqo7zc/dXl
MhjUY3SVdQohhDh9hLoWecLMj+nbqzvP/mcdc+8Zw8ybhgMK5TYns/+zls6d O7Ft++6Adc4b
3B+HUyMn/zB/+2M/ABat3IXdqbH0x3Suv6Qnlw/rzFcbvglY7/3lO+jSuTPR 0VGs/3mL7/0P
vtlBp04d2bgnHYAWzRphtdlxODUaNmjAe19txel0oes6qzZlcM81QxjcvRWv fr65wv7U5OdR
Xv4RLr1xgLtv1qTTpVMn/vtDOhPO78qlQzuybK27/eGU8adpGrHRFpwunaPH yzF0nfTsQp5+
90d6de8aso0Oh5OmjWMAKCq1AWrIcuG22auyvg123uD+AccE3KeGT594CQBv LdtKm9R2ALy5
bAuDu7eqUIdhGCiKUu0x8P8c1OYYez9/9dU3JpNa4+MnhBDi9OJ/DXaZzVFF yRMqK1fZz7Zq
TxFXFDPFJXZKhvXg4qEGum64R669X0OMYK/9MLvKOoUQQpw+Ql2DPWSQOyA7 dDPfbDzAVRe6
Z6r+7Ps0XIaF6KioCut4/893OJwkxDcAYP6M8QFlkpo2wG4P/EFVXGbHEmWp 8DOjoNhKx5ho
NE0HTpzWdbykFNVxnMdvGUn7Vk2JiTL7ljVuEI3L5aq0beFwOJ00i4sFoKjU TqcGMZ5wCwnx
DXA4nQBhlfGX0iqZ97/Zwc2X9eGf945F1w0O5Bby3tc7KDpeTFxc4wrrWCxm CktsJDZpQJNG
MdgdTqKiLLVus1dlfRssVL/ZHQ6aN3Vfp324qIw27d1/ADhcWBa6kirq8uf/ OSgpLYvYMY5U
39Tm+AkhhDi9WDxngQFouu57/vOmbRVGr+HENdmDB/b1vWdS3XWoqoJT0yus E8ZtusykHyym
pymLX9IO8+3efPdodbmNMt/111ZsVhtWu42u7QaSktSxyjqFEEKcXvx/cID7 /++ysnIaRxv8
bkRnsg8XA/C7EZ35fksmJaUVw5T3//yoKAtHi8pp0awhf3pyiS/M+G/r503b Qq5bWZ3+9u3P
4PWZ42jaOJan3lnD5r35mFSFT566ptKgWJOfRxaLmaISKwnxDWjSKJqyMivx Dd0hsuB4ORaL
BTCqLeNwBP4hoUVSIt9uSmfFz7/RJqkxfTq24OZxfXjg+qH85Zkv6de3Z4W2 NG0Sz087s7li
ZBcu6JfKdztyaJ/aGkVRKCu3kp9/mM6d2ofV5uD2hNMnocpERVk4UlhGy4RG JMY3wGq1ohsG
SZ7QHUxV3QfFarOR4Am61W0vksc4Un1Tm+MnhBDi9KKEOEV805btAeE6eJIz b8ge2L8PAN6M
rlRyirgvwhuGUeHhXtHM4nV55B2z0bdrEiO7NMfQNcqs5Vit5VitVqye2cTb tOhCq6SOvtt0
hapTHvKQhzzkceofwX7etC3goWkamZlZzLhxOLpuMPs/a3n2P+swDJh+wzCy MrMwmUyU29yj
fy2bNeLnTdswDIOk5oksW7sXgD9d3peGsRYaxkYxpEcKs+8aS/qvoa+RDtWu yt7zXkNVZnMS
E2Vm0mV9KpQLVX84fZHQrCmrNmUAMOH8ruzbt58rL3DfBuubjQdontgsrDLB 9u3P4G+TRtI+
uSkZecfZvv8QAA6XjqIqIdvWKrkFn6xOIyOviBsu7cWQLgmkp+1lx87dmJ3F 3HdNf37d91ut
2hNq38Mp0yKpOUt/9BzfcX3IyMggNzubv1zRP6BcdHQU+cdKARjSvRX79x3g j2N6Vbs976O6
Y1zZ5y9YpPqmNsdPHvKQhzzkcXo9VP9JznSjwrXV9zy/lP59e9O/b29f0K6s vKoE/tzyCuM2
XSYw4M3lBxk/NIleHVvSLrUZHyz5mb0Hy1GAuAYJNG3ZkpSkDoACilplnUII IU4flV2D/ddr
h9I6KY4XP96AbnKf8v3aZ7/w1+uGcusV/Xj9i+189O0urhvdkwUzx/vWG9i/ Dz/uysLh/IXL
h3Xi3UeuxOHUSMs8yierdtEiKZHi4pKA7VX28yLU++3bteWfH23g1t/35+nb Lqag2Mri1Xuq
3Mea/DxKbtmCpesOoKoKF/Vvx4Tzu3Ks2MoH3+xk+S8H6dyxPYZhVFsmJzdw MreEhGZ8sTaN
my7tSZe2CWBAWuZR3vnfdtq3Sw3ZRlU1kdquHQ8t/I7Lh3Xk8mGdmHJFf8wm lZJyO7/lHUfX
9bDaHNyecPokVJnmiQms3Z2Jqm5hwvldeffhCeQfK+Oz7/cwuHsrdN19zXVq 29a8/OkvTL1y
ADMnjeBoUTmLVu1izJAO1W4vnGOc3DIp5OcvWKT6pjbHTwghxOkl1H2w+/bp 5QvTffv0qvZ9
/7pC/d+vjJn0sPHHyXeQdaiowsJDXySQc3SVt6j7tCxDQVFUz2sVxVA9Fyip qKiAiqKolJLO
0EmX1GX/hRBC1KPNW3dUumxAv95kZGVz7Fgh7dq2oVmzJgAcO1ZERtZBmjVr Sru2rTl85Ch5
+YfRNM23ntfRgmMcOVqAzWZHVRUaNmxIUvNE4ho3Cti+/zqVvR/8XklJKQdz crHbHVgsZlok
Nedgdm5Amcrqr6ovvGUNwyA37xDHCotwuVxYzGYSEpqR3DLJt044ZYLrPV5c wuHDRygrLwcU
YmNjaN0qmYYNG1TZPl3XOXzkKIVFx7HbHRiGgclkokFsDJ06tq91e0K9F04Z gD3pv+JyuXC5
NCxmM4nxMbw2/XJyjpTwwLyV9OjehZLSMg5m52C3O4iyWGjZMonMrOxqtwfh HePKPn+1OZ7h
7Hdtj58QQojTQ3zDGJZ/uZhrr7uRfTkFtaqjUWw0P6xYwqXjr+Z42YnL4Jwu nY0rPj4RsDPy
CyusfOTLRPIKfsAwvJN8uBO/gjtUK4Z7tNodtL0j1yoKCqWkMfim0bVqtBBC CCFOX79lZHH/
tYP5YPk2DuQWkhgfy9QrB9K/S0te/HgD+4+6aNa0yaluphBCCBGgWeMGfP3F p1wwZgLFZbbq
VwjBZneStmkVl/3uGo6VlPve1zSDjSs+rnqSs8TLj5Dxfl7ltSuVPAcG3Tgq ZJ1CCCGEOLM1
bRLPtxt/ZeqVA2jXMh67U+NAbiHPvPsj+w/ZaNWqpfwOIIQQ4rRjc2qMGX81 K75cTOtuw2gS
36hG6xcdLyU77SfGjL8am1ML+bOu2muwB94wqmatrqY+IYQQQpzZ4uLiOFhY zEOvr8Fms6Eq
CrGxsSQmJpCc3FJ+BxBCCHFaKi230SAmitHjrmLlV5+RXYs6Ro+7CrvDRXkl 98eu9jZdQggh
hBDB4uIah7z3s/w+IYQQ4nRWZrXTLL4hv7uy4iSv4bA7XZRZ7SGWuE/ploAt hBBCCCGEEOKc
UVBUGvE6vTOUm7s1Psp/l6+J+AaEEEIIIYQQQohzRbfGR90j2EuevY5jBUcB aJaQeEobJYQQ
QgghhBBCnG4MA1yagd2p43AaODUDi34cgJzsg7y+8LsTp4gLIYQQQgghhBDi BF03cGlgd+o4
Xe5QXRUJ2EIIIYQQQgghhIdhgNNl4NINXC7D9zwcErCFEEIIIYQQQpzzXJqB SzPQdPck4A6n
+3VNSMAWQgghhBBCCHFOMgzQdPcotWGAgTtoO5w6tbnPlgRsIYQQQgghhBDn HKfLPULtvWO1
7hm11sI8HTwUCdhCCCGEEEIIIc4Zmmbg8AvW4Bm1dhlQq3HrEyRgCyGEEEII IYQ46+k6OFw6
wQPUTs3A6dIjsg0J2EIIIYQQQgghzlreWcErnPptgN2lo0cmWwMSsIUQQggh hBBCnKW8M4Mb
wdnac711HS63DkkCthBCCCGEEEKIs4ruGbXWvVOD+zEMA7uz4vuRIAFbCCGE EEIIIURYtu7+
jvVb/8eBg9uxO6wAaLpGlDmGPt1GMmzAFXRtP/CUttE3ah1imW5Qb+EaJGCL 00xKSgoAOTk5
p7glp8aKFSt46KGHyM3NxTAMcnJyzrg+OdPaK4QQQgghqncwL51PvnqRgtIM krsm0aN3G5Ro
FZfupFwrpeRoObsPfMfGd5bTsU1v7rhpLg1iGp/UNhqA0+kZtQ5BN8DhjOAF 1yHUOGDbbDYW
LlzIF198wYEDB3A4HCQmJtKtWzc++OCD+mhjBfILvDhbPfLII+Tk5LBy5Uq6 det2qptTJfk+
FEIIIYQ4NxzMS+el9+4mpWsCA0f3pEnDFKKUOFyajs1VTrHzKLHRR4lOziOm 5zEyftjO35+7
gmlTFtAmuetJaaOuGzhDXGvtZRjuGcTrW40CdklJCddccw179+7liSeeYMKE CVgsFrZs2cKC
BQvqq41CnDOys7MB6Nr1xH9EZ1qAPdPaK4QQQgghKldQmMsL79xBu6FNaN+9 A60a9ENxWmhq
aYdm0ihVjhJjNMXsaoDisqBHmXGNOsjxH0qY+8bt/GP6snofyfaeEl4ZX7iu p9PC/ak1KTx3
7lx27tzJjBkzmDRpEnFxccTGxjJ8+HD+/e9/+8qlpKSQkpLC22+/zeDBg2nd ujXgvph84cKF
DB8+nNTUVAYPHswrr7yCEfRnhtdff52UlBTatGlD//79mTFjBiUlJb66g7fj FW794fDW/f77
7zNs2DDatWvH6NGjWblyJbNnz2bAgAGkpqYyduxYNm3aFHb7/etetGgRI0eO JDU1lYsvvpif
fvqpRvUAvPnmmwwdOtRXx6efflqv/RLp/Qtuezgq+3wF73eo98JtWygfffQR Y8eOpX379gwc
OJD333/ft0zXdebNm+fbnyFDhvDSSy+h+835X922U1JSfMekdevWvvKh9iuc 416T/gjuS6j9
92Hw60j0DcBPP/3EFVdcQadOnejYsSM33HAD3333XVWHTAghhBBC1NE7ix+n cTuNhE5NaRrV
jiRTd8xY2HT4A1xGKfHRLWlsaUajqAQamuNpYIonVmtCVH8H5RTxzuLH661t BuBwVROuPfe+
PgnZGqhhwP7yyy8B+MMf/hBW+fT0dL777jvfqNz8+fOZNWsWQ4YMIS0tjeuv v55//OMfLFy4
MGA9q9XK6tWr2bdvHzNnzuT999/n0UcfBQJHx3JycgJeh1t/TezYsYNvv/2W 119/nbS0NG6+
+WYKCwtZs2YNb7zxBrt27eK+++4Lu/3+NmzYwPLly3nttdfYu3cv06ZNq1E9 b7/9No8++ig9
e/Zk8+bNfPrpp3zxxRcVthPpfonE/r355ps8/vjj9OnThy1btrB48WK+/vrr GrUj+PMFoChK
WOtW1/fB3nrrLaZNm0ZycjIbN25kxYoVpKWl+Za//PLLzJ49myuuuIL09HTG jx/Ps88+yyuv
vBL2tkN9tkONBod73GvSH6H6srbfh8Ei0TcAd911F5s3b+aVV15h165d3Hvv vbz11lth7Z8Q
QgghhKi59N82kXF0C3F9NKLMjVCcjTCrsWiGTqy5OT8fWsKag+/hcNkwKxYs phjMahQWUyxm
swV6lLB193cczEuPeNsMAxxOo+pBw5N0Wrg/5Z47pxovvfIaxwqOAtAsIbHS wqmpqbhcLjIz
MzGbKz+73Dt6tWPHDpo1a+Z7/7zzzuPgwYOsXbuWdu3aUVxcTPfu3Wnbtm2l I4iaptG2bVua
NWvGjh07AuoP/qW+NvVXtw/bt28nISEBl8tFamoqAFu3bqV58+bouk6bNm1Q FCUgmITb/k2b
NtGyZUtf3TWtZ/jw4WRmZrJu3Tpf2zIyMhgxYkRA/0SyXyK1f962//TTT7Rt 2xaAzMxMhg8f
HtD2UCr7fKWkpGAymcjKyqpQ1ltfbfoeYNiwYWRlZQX0tb8hQ4aQk5PDli1b SEpK4tChQwwY
MIDWrVuzYcOGsLcd6rMd/F64x70m/RHcl8Fq8n0Y/H6k+qZr1644HA6WLFlC t27diIqKqrS9
QgghhBCi7l59fxoZrCLpvFhaKINoHTWA1o16cLBkO1GmWPonjefHnA/56eAS WjbqTGKjJArs
uRTZ8zlmy+ZIaR6m9YmMGTiJa8dXPaBVE5oeOGodKmMHT3hm+P4J8RwCgrpR RblgFv04ADnZ
B3l94cKajWAnJSUBcPTo0bDKB//CnpeXB8CIESNISUmhe/fuAAHBZsOGDVx1 1VV07dqV1q1b
+8JXYWFhtdsLp/6aSkhIAAj4g0Lz5s0BUFV39/kfjJq0v2XLlgF117Qeb4Dx P63X/7lXJPsl
UvsXHPCCn4ejqkBYnaraFkpubi4Qun8BDh06BEBiYmLA1/z8/DpvO1i4x70m gvuyLt+HwSLV
N9OnT0dVVcaNG0enTp24/PLLWbNmTY3bI4QQQgghwrP3wCbMqeXYNDvFZaWU OI9SYDtIQXk+
Lt1JQ3MTRredwuS+cyi1H2f1r/+jxHYcTXegGRq6buBKKif9t03VbyxM1V1v 7eV0hb5NV32r
UcC+/PLLAfjvf/9bq421atUKcI8A+58Ce/DgQV+ZqVOnsmHDBl555RUyMjLY v38/EF4ICaf+
+laX9te0Hm8g9QZoCB2aI9kvkdq/UKOfkZgcS9M037W9oQJcbXn7sLI/Snj/ 6OL941NBQQFw
IjBGUrjHHWrfH5E6zhC5vpkyZQq7du3iyy+/ZObMmWzbto277767xu0RQggh hBDhKbeVoEc7
KS4vocRRwDFbLkesmRyzHcKpOQEwKxbaNe7DnYNeZkynP7Lz4A725v6GU7ej aRrOhraInSLu
0gy0MM74dlUxm3h9q1HAnjZtGt27d2fOnDn85z//oaSkBJvNxvr165k8eXK1 6//lL38B4Omn
n6a4uJjS0lJWrVrFDTfc4CvjDQONGzfGZrMxe/bsCvU0buyehS4zM7PG9Yea +CmSwml/pOq5
9dZbAff+FhUVcezYMR5//PEK5SLZL5Hav1tuuQWAJ598ksLCQgoLC3nqqadq VZeX93TpFStW
UF5ezty5c+tUnz9vXz/66KMcOXKEoqIiZs2a5Vs+ceJEABYuXIjdbmf+/PkA 3HjjjRFrQ3Bb
qjvudemPunwfBotU30yZMoW0tDR69uzpOx0+Ojq6RnUIIYQQQoiacVoclNpK KbTnctSWxWFr
BkfL83wB2ytKjSGxQQomk4pds2LXytA0A81V96Rr4B6RDidcazphlasvNQrY cXFxLFu2jPvu
u4933nmHfv360aVLF26//Xbsdnu160+ZMoVnn32WnTt30qdPHwYNGsTbb7/N 7bff7ivz8ssv
07lzZyZOnMioUaPo0KFDhXoeeOAB4uLiGD58eEAorK5+b2io6vrxugqn/ZGq 55ZbbmHWrFls
2rSJvn37cuWVV3LZZZcBYDKZfOUi2S+R2r8pU6bwyCOPsHXrVvr168eECRMY O3Zsrerymjt3
Lp07d+a2227jkksuYeDAgXWqz9+f//xnnn/+eXJzcxk8eDCjR4+mc+fOvuXT pk3jrrvu4vPP
P6dz584sW7aM6dOn18sIa7jHvS79UZfvw2CR6psbbriBp556iq5du3L11Vcz aNAgXn311RrV
IYQQQgghasZlU3A5DYrshzliPchh628csx72BWwDg6O2HOb9chevbpyJKcpB 06YqLt2B02Gg
RyDsulzhjUgbBmhhnD5eV7pu4HIZOEP88aBGk5yd6f73v/9x22238eKLL3LN Ndec6ubUiwMH
DnD++efTsWNHfvjhh7DWORf65WxXm+MuhBBCCCFEVf765EU4hv6Gq7Ed3aqi KiYamOMpLnbx
u863cUWnu9iQ9wVvb34CJ+UkNInBqpXg0h24nAbHj7mIyY+jh2Uoj9z9QY23 bxjg1IwQE40Z
Fcp5R7kxApcadZnkzHBPqKbp7lCtGxUnVIuPct/GtlaTnJ3p5s+fz8MPP3xW hchbb72V7du3
43K5yMrK4pFHHgHg3nvvDbuOs7FfznaROO5CCCGEEEJUpUuHgejZsShmd6rU DY1S5zFKncUc
Lc9m9rqbeWHdfbgsx4ht5KDEeQyX7gDAWqajaWAuiqFNcpcab9sw3NdShztT WTgTn1W7TUDT
3EHd5tApt+vYnYbv9PRwRtHr71zp09DSpUtPdROSLOuWAAAgAElEQVQi7sor r2TmzJns3r2b
2NhYevXqxZtvvuk7ZTgcZ2O/nO0icdyFEEIIIYSoSr/uF7H189WoPY8HvG8Y Ot/++hkOSklM
cN86VTM033K7VcdarkOhmVhXDMMGXFGj7XrDdbiROdzwG3pb7vCsaQYu3W8E vJb1nVMB+2w0
fvx4xo8ff6qbIU4yOe5CCCGEEKK+DR9wBSvXfUj2Jhtq/2PoVvcJ0KpJwxRV TlxsVIV1nA6D
kiINzQ5NjzSla/uBdG1fcS6gTd99B4ACmCwWFFVFwRuudXRdxzAMDF1H1ytP uy3appLYOrVm
O2aASzfck7Dp3kAdmWu3JWALIYQQQgghhAhp8tWPMfeN27Hu1KFTMRjQuJGl QjnDcJ8WXlqs
odshNqsJiZYkJl/9eIWyL06bxqbVq+kzfDiN4uNBUXA5nThsNhw2G3arFbvN hq283P3c7+F7
z2bDabfjcjpZ8NMmOvbpW+2+uGcYdwfruoxSV0UCthBCCCGEEEKIkNokd+Xa 8dNY9OVcyo9b
0LoVYUS7QFE8I8zuUWtruYbmBL1YpWF2U5JjWzJtygISmraqUGf65s1kpqdz JDeXqOhozFFR
ntFrw/fQNQ1N09xfXS73w/+1pmF4pijPz8yoMmC7NAOXBvpJuDm2BGwhhBBC CCGEEJUaPuAK
2iR34dX3/4+j63JxJZXhjLfiamRHQ0crUzFKoogujqVhcSM6tOnB5Ksfo01y 15D15WZkYCsv
p2lSEtffdx9d+vZj2b//TX5GBp369qVTn76sWbqE0uPHSU5tx8jf/56v3v03 pceP0++CC+nc
ty9bvv/e814R+7dvZcQVEwK2YRgGTs1A0yJ7Cnh1zqnbdAkhhBBCCCGEqL11 m5exct2HHMxL
R9MN3+2tzCaVfj0uol/3ixhexaRme7du5ab+/fnd5Mk8+vbb7muu9cDZwgOi cIj3DcPApRns
27aNBy4bTaMmTfjP7n2A+3ZaTu3E/bcN40TANvwqMvy+BiwPWuatozLBt+mS EWwhhBBCCCGE
EGEZPuAKX4BO/20TAA1iGlU6Wh3so3/9i+R27XzhWgsK19VzT0wG0KlvX574 eDEPXDaard9/
R4/hF7pPAz85g9UhnVP3wRZCCCGEEEIIERneGcLDDdd5GRl88c47XH/ffb5w XdMzt3Ud36g5
QO+RF9Kxd1/+/Y8nA94/VWQEWwghhBBCCCFEra3/8EN+27iRwoMHqyyXl5FB 74QEsr74gld/
/DHs+k+c2n0ikPufxt3ebOLQnp28f8t1Fdfzy9xxrdqQ0m8Qfa4KLBdJErCF EEIIIYQQQtRY
+fHjvHL11dgKjtAsKYlmrVoQGx9XaflWrZMYOHJI4Ju+a6NPXPxsBF0E7R2Z 9p+szPAr36pF
X4whfX3rGP4XUHvqc5bbKN6/i43rVrP5g7e47s1FxMTFR6AXAknAFkIIIYQQ QghRY8uffx7X
8UI69OzB0CsupWmrljWswXNbLl33TEbmfe65VZfhea4bGIbu+ep5bhjo+onn vvV077KK7x8/
XEDmll1k/3qAta+9wOiZj0e8TyRgCyGEEEIIIYSosW1Ll9AqtQ3DRl9MI3MM 2uGiKssbngnI
dMNA58Q9rw3DcIdrQ0f3vMYXsr0hmoDArQcHa0+o1lwunA6H76uu6ei65mtD QutkbGXl/Pr1
UgnYQgghhBBCCCFOD5rDQUrrNjRWzFBSHrKMYYCO4QvOut/I84nn7qDsDc26 X2D2vfZbx13W
/VpzubDb7TgdDpwOJ4ahV9vuRvHxGC5npLsDkIB9UqSkpJCTk3NS6qpq+dq1 a7nzzjs5evRo
hTKRbKMQQgghhBDi7KcoCglxcahWe4VlujdMA7onEPs/vAHaF5j9wnRAiA5a Zug6TqcTm9WK
w+FA17SKDauGyVBQFCUCPVCRBOwzQKTC7zPPPMPLL7/M+eefH9F6hRBCCCGE EOcmRTdQ/UOu
YbCnpAi1Zw/PS4Mju3fSuqiMponNA0ey/YK07h2x9g/ante6YeB0OrEHhWoF MPm1pcRWTuyo
CzBbLABoLheHl31JcrMkT2PdoVqtxxtl1zlgp6Sk+J43bNiQ/v378+STT9Kl S5e6Vn3SvPba
azzzzDP87W9/44477qjRuicjpEaq/j179jBs2LCI1yuEEEIIIYQ4NxmKgq6q nhcGusvFcRNc
NPZyLBYLdrudH0uLKc9aT5P4JgGBOvi54R+qPQ+b1YrNakXX3ad+B4dqf0qj BvQdcxlt27bH
4XCQnZ1J3tdfY1FAUVUURUFRVRwutd76IyI15+TkkJOTw6ZNmxg+fDh33313 JKo9KXRd5913
3+Xxxx/nvffe8x24s5HNZsNslpMWhBBCCCGEEJFhqO6ArSsKmqa585QBJpMJ XddxOBwoKOBy
YTgc6E4nhsNR4bnhcGDY7RgOBy6rlfLCQo4fPoy9pATF5cKk69U+VMPAZDJh GAYOhwOn04Wq
KESbze5HlIXoKAsmc2URve4imrYaN27MHXfcwQsvvACEHt31fy8lJYXZs2fz 8ssvk5+fT9eu
XXnhhRfo2bNnyPozMzN57LHHWLduHU6nkxEjRvDiiy+SmJhYq/oAVq9eTXx8 PH/+859ZvHgx
3333HaNGjQpob2V1ekfvvV+rGhF+9dVXWbBgAWVlZfz+979n9uzZREVFhd1P oep2OBzMnDmT
ZcuW0ahRI26//fZKtx/cVq9Q9Wqaxpw5c/jwww8pKytj7NixPPfcczRq1KjS +oUQQgghhBDn
nu8++IgNMTHu2cw8p383Gz8WAJfLhdPpRNd1fvj6a6LNUZ4Zwz28z/3uc214 ZgKvDVP7NpyH
O89YrVYADmdnU/DTJncBxX3duKVJk9rubrUiGrBLSkp488036dWrV9jrrFu3 jiVLlhAXF8eC
BQuYMWMGX375ZciykydP5qmnnmL+/Pk4nU6ef/55Zs2axbx582pVH8A777zD LbfcAsCf/vQn
3n777YCAXVWdOTk5YZ8ivn79elauXAnA/fffz3PPPcdDDz1U7XpVmTNnDgUF Baxfvx7DMLj/
/vsrLRuqrcFh22vevHls376d5cuX07hxYx555BGefvppnnnmmTq1VwghhBBC CHF2SRk+jGbt
OwS8V97QHaRdLheqqqKaTaRcdBEJbdsFlNvy/vusz8qipAbbi2kQy9g+fWjZ sRNN2rYNWFai
2TGME8HeZDLRrHNn2o66LKBccV4uRevX12Q3wxaRgO0f1JKSkli6dGnY6z7z zDM08fwFYerU
qbz44ouVll29erXveUxMDA8++CBDhw6tdX2ZmZls27aNN954A4AJEybw1FNP kZWVRVu/g1WT
OivzxBNP+Eban3jiCSZOnFjngP3555+zePHigHq9E5jVxYcffsgHH3xAcnIy AH//+98ZM2aM
BGwhhBBCCCFEgE5dutClR08Ml8s9+ZimsfnYIfc9qTUNk8mEqqh0aNqUts2b B9yGK81kogRo
DsSFub1eoy8mRjfof+ONROfmYsvJcV9brSjkORR0XcflcqEoCqqqEh8TQ9ek 5qgmE4rZhGIx
86vLVm/9EZGAnZOTg2EYZGVlMW3aNHbu3EmbNm3CWreJ3/B8bGwsripOB/jl l194+umn2blz
J+Xl7vusBU+vXpP63n33XQoKCujQoUOF9x9++OFa1VkZ//5o06YNR44cqXEd wY4cORJQb9ug
v+DUVn5+PhdccEHAe/U1jb0QQgghhBDizGVYrbiyszGcTvc11S4XRpSCy+XC MAwsFgsK4MjJ
wa65JzFzOp1YS0txlrjHruOApmFuL9bAd4q5MycHx759vsnLtGgzuq7hcDgw mUzu68BLSnBl
ZKJazChRZkwx0Sgul++09EiL2PRpiqKQmprKvHnz+Pvf/05paSlms9l37jtA YWFhnbZx++23
c8stt7B582ays7NJS0vDqGXH2O12PvnkE9avX++bpC0nJ4effvqJRYsWYbdX vJdbXRw8eND3
PDs72zfqDNS6n5o3bx5Qr//zukhKSmLTpk0B/ZKdnR2RuoUQQgghhBBnD8PA PXrtGcHWXS4M
3LfV8o4kAxieZdbiYsoKC9GdTmozhNe4TWu8V3GbVBWTqmI2mTCpKqqqoGk6 drsdi8XiPj1d
UXzlLGYzligLJosJo55u1RXxKaWTk5MZPHgwn3/+OT169GD+/PlMnTqV48eP 8+ijj9apbpvN
RnR0NNHR0WRlZTF79uxa17VkyRL69+9fYaS9bdu29O3bl6VLlzJx4sRq64mL i2P//v107Nix
ynKPP/44c+fOBeCxxx7jD3/4g29Zbfvpyiuv9NVrGEad+9dr0qRJTJ8+naee eoqUlBT27dvH
v/71L1577TVfGbmHthBCCCGEEMLQdVyeycp0w0DHfe9rm81KVFQ0qqqiaS40 XaeouNg9gZnn
tl6GonD9mDGMmPZ/vgnS3Lfo0twPTUNzudBcTt/D5XSQve4n98bNZrBYMFQV RVXB5M6MDRo0
wmKxuG/5paooUVEoJhOYLCjRMaie+2TXh3q5AdiNN97I+++/z3PPPcfXX39N t27dmDBhAiNH
jqxTvXPnzmXWrFl06tSJiRMnMnjw4FrX9c477/CnP/0p5LKbb76Zd955J6x6 7rjjDsaNG1fp
hGFeQ4YMYdSoUQwdOpSmTZsyffp037La9tOMGTOIj49nyJAhjB49muHDh4e1 XnXuvvtuhgwZ
wrXXXkvHjh256667GDduXETqFkIIIYQQQpw9NEDTdVyeoO0yDJz5hygtLcZs NlNSUkz+7l04
HE4cuo6mqr5HlwsuQLPZ2PnhB+xdtpS9Xyzj1y+/YP9XX3Hg6+VkfLOCrFWr yP7+B3J/XEf+
Txs5+PW3JLZJJbl3b5zFxWCxoHgeWv5h8rL2Yzab0DSNA+m74PBR33JMJrBY UD23LtYN9z23
3Q/D8/C89l8WUE4Hw/MIMQqu3HPnVOOlV17jWMFRAJolJFYoJIQQQgghhBBC +Hu0R3cuvmwc
rRMSMVxONJcLQ9M4nJfLb7odU4skXKWlaLvSSE1qhdkceAJ1VEICA2o5kXLx 5s3kf/opqmf0
WlFVXC4n23Oz0Fq3AgX03zLp16YDTRISUc1mVLMZc+OG7D+Uyzcff8qUlZtO 3CoMv8uy/a7z
Nnz/nKAoCngeTWPdl/rmZB/k9YULI3+KuBBCCCGEEEKIc4OOe9Ra9z50nfjE 5nQvL+dYZh5O
h5OYlFRQFIKninYVFrL2jjvcIdkzUZmiKKieGcC9M4GrnlnCVb/liqq6R6b9 1ou2WBjYvgs2
uw1d12nQtTexDRuiqCqqyeQ+NVw3KDtWBIDmdPjC84l7cxMUuP3T9Ylg7Z65 vOIJ4RKwhRBC
CCGEEELUim6cCNia5xpsHShzOlGiY4iKjkGvZF1vaNY9IRpVBUXBUFUMT4g1 /JYbnjBt+AKu
ex3/8G1WFOJiY92h2jOyrZpM7hFsVUXRdPd14IDmcILfdGcBedovaLtnY/Ns T1FRVPfXUBdc
S8AWQgghhBBCCFEj3tOpNcDlF641w6CkpAS7w+GbzKwCv1FqX3hWVXdY9oZs z3uKX/Am6D3D
L2R7R5VVvxFu31fvc0/DFW/bnX4BO3gk2/Nc8YVrzzZUAzCBGnoWcgnYQggh hBBCCCFqxBsv
dcPAaei+Eezi0lLsTqd7QrEQFHCPQnsDsve5JzhXeO43au0L134j1/7h2zc7 uV851S/M+98W
zNANXE5HxX3yy82K36g5Cu6ZyD074R0ZJ+jEdwnYQgghhBBCCCHCZviFUEM3 0HQdTdOwlpdj
s9kqXU/xG1H2XTsd/PB/3/+67BDr4bfcf4Q74HRzRcEA31cAw5O03SPYlTYW 1aSioIKhoJg8
od5k9kyYZvEEbHvAahKwhRBCCCGEEEKExTCCTqM2dDRNx2q1UlpSUul6/iE5 OCirJlNA+FaD
QrX3NUHBW/V7HXBauG/U2R2wNdynsvva7D7v2z3JWTBVQVVMqKoKqCgmE6rJ 4puF3B2sLe7r
sAPGxN0kYAshhBBCCCGEqAEDp8MzUZgBVpfG8XIbhskSsrQ3LON3OriqKqiK imFS0RV3WDZ8
D29Adj83fCPWnq+qAqrJXU5x14tv4jHvSLY7AIe8UjrE7N8BbfVMiqaYLZhM ZlSLBdXkDddm
74XZIUnAFkIIIYQQQghRLcMAwzCw2ewUF5UCYDMMCsusGJbokOt4Z/sOHpUO eD/oVlzBo9Hu
CcpUVDxfDQXVUFB0xZ21PROXKYqOolcefr0cesV5zd2j3iZMZk+gNnsfJ4K1 oqqEGrX2JwFb
CCGEEEIIIUSVvPeEttscFBeVUlJUgsvp5LdfNp7qptWcge9WXeCZsMxsxmS2 YDJbKgRsRTVR
XbD2koAthBBCCCGEEKJaum7gcDjRXBoGcMGDszB0PfRp2B6hlikn7n9VaaGq 6qw7d+0mT3g2
eUapTRYLit+Itfd0cKMGjZGALYQQQgghhBCiUr6AqShEx0QBEBMbQ5Px48Aw KoRho5IXht8T
w/+rb9mJNyqUDWpP8C21DL+GGkFlg7YQtJ53wjSTZ0Izk+ca7Uqu366GBGwh hBBCCCGEECH5
ArAnqVqiLFiiLIG36vIvCBieVBwq6BpG4DoGRshlAfUbQXUaFdsV8H7A8hPh u7KAH7A8RHiv
icqnTxNCCCGEEEIIcW7zhdXwrkE+10nAFkIIIYQQQghRwYnR3VPckDOIBGwh hBBCCCGEEBVJ
sK4xCdhCCCGEEEIIIQLUZOZscYIEbCGEEEIIIYQQ9eccCusyi7gQQgghhBBC iADe21Qrvn8C
nlS3dsTbc7o6VlAS8FpGsIUQQgghhBBCiAiQgC2EEEIIIYQQQkRAhVPE1675 7hQ0QwghhBBC
CCGEOLN079Er4HWFgH3e8PNPWmOEEEIIIYQQQogz1fGiwoDXFQJ2cAEhhBBC CCGEEEJUT67B
FkIIIYQQQgghIkACthBCCCGEEEIIEQESsIUQQgghhBBCiAiQgC2EEEIIIYQQ QkRAhUnOQvl2
+Vf13Q4hRJguuXSc77l8bwohhBBCCHFy+P8eXpmwAna4lQkh6leoQC3fm0II IYQQQtSvcAe2
5BTx08Ce3TuJb9L0VDdDCCGEEEIIIUQdSMAWQgghhBBCCCEiQAK2EEIIIYQQ QggRARKwhRBC
CCGEEEKICJCALYQQQgghhBBCRIAEbCGEEEIIIYQQIgIkYAshhBBCCCGEEBEQ 9n2wI2nTJyMY
OHFtnerYu+Ef1ZbpMvTvddqGCPTEnAU8OuN23+s58z9nxtQ/nMIWCSGEEEII IcTpI+IBu7Lg
m9RhHAD7v7ubS27bwLcLh9YpZOu6wqBL5/heb14xvcq2RCpsl6elk7fgaRr2 HEjLKfdVWJ7/
xr8o27WJ5NsfokG3rhHZZrDla9LDLnvp+ZFtw+R7H+Cdl/4Z0TqFEEIIIYQQ 4mxQLyPYA8Y8
F/BaURQAVrzaBdxPcTo11n9wHufdsL5W29ANFd0wUFAAo0Lg9vfr1/ewd8M/ 6hyyy9PSyXv5
CZIdseRt3Uj+G/8KCNn5b/yL0q0baeWIJW/eEyTf82i9hey+F4+otsy21bX/ A8Yt720nylVO
jKOYWFshDexFAHRo3VVCtjilHHY7TqcTXddPdVOEEEIIIcQZRlVVzBYL0dHR 9VJ/xAO2pruD
b8BGVIVl/+zAhDv/C4BRnsFlt3wKCix5dRAX/vmXGm/HpavoBryx+GeKissY lRIYuA3wPIeo
hgnElRXUOWTbs/Zh2DSa9etLM8Vg5/p1ZOZmEXfeKIrXr8KZlUPPfiNQFIPc LeuwZ+2rt4AN
8NV/Fldb5u2P8gG45foLa1T325P6VHjviTkLOJCd7gvXGRlZNapTiLoqLy/n wP79bNy4nvy8
vFPdHCGEEEIIcQYxmUwkJbVgyNChdOrUmejYWAjKrnVVDwHbjB7URsOA391/ gI+eaQPAdbc+
y6LXZ4IBl961rZbbMaFp8Oc/DMIANn3zTUDgPlpwnOPF5cx/4nqiGiYA0Ljs KNt/fI4+Iyue
Th6OpmPHY8/ax47V39Oz1xB6duzP0WN5HPr3W7Ro1YaEDv3heDk7d/9Mo4vP p+nY8bXaTk2M
u+nqasuEE8TD5T9ynZmRCcDW+T0B6Dd1V8S2I0Qwh8NBbk4233+3itGXXErr Nm0wmUynullC
CCGEEOIMoWka2QcPsvLb5TRNSKB9fHvsdntEtxHxgO3SVDQt8D1N04myqFz9 4EE+eCwZozwD
m9XFhGm1D2ROXUUH/v35LzidLvrFBQZuBcAATYeEPnf71sv/+tFabxOg5ZT7 MPbb2LlxLb26
9idBbUJC63gUFIzj5ezYu4XG3UaEvD67vrSon7MbKvCf4Azgy49OhO2L/5bO 6me6hgzZ/3rp
JabefrvvNAy73c78BQu4795767fB4qzidDhY++OPXHrZ5Qw5b9ipbo4QQggh hDgDtU1NpWVy
S5b+93PuvOfeMyBge4JvMJtTJ9qi8sdZebz19yQG37i0Tttxj2Ab3HTFQBRg wzdfBwRum8OF
zWbHanVgtTuw25zM/fs1OPW635ks+ZmZlFx6OcXbd9A4tQPgHqUvzToAmovk Z2bWeRs1oSon
ZzubXu4R8Nr7hwzvCQsX/y2db5/qwsC7dgeU69WzF1NuvY03Xl8IwJRbb2Py n/5U/w0WZxVd
18nPz6NlcqtT3RQhhBBCCHEGS23Xnry8XFQ18netroeA7Q6+oZRrGrFRKpOe OkTang112o5T
M6HpBh9+uRmn00W3BoGBO1QLNN1A0yN0Smm5E6LNGCU277xtGA4n2J2Rqb8G TsZJsuv/2Y3L
HlzmeaWcuFZB8VzzXpoGGIz+6xK+mtONYfen+dYdPXoUAJeNuxyAhx96yPee EDWhaZqcFi6E
EEIIIerEZDKhBZ92HSERD9je4FuZUpt7R7LSviW1TZdab8elmXDpcO24AQCs X74qIHCHGsF+
ZsZVOLW6/3Ke97dnMawuGiUlg9XhC/ON4pPRM9PJ+9uzJ3UUO+GKRypdVrDs yYhs47wH0lj6
RDf39HHKiVPwDRQUxeCK+58HYNkL07lgZlqF9f0DtYRrIYQQQgghxNmoHgK2 GVc1d89RPOXq
QtNVdB0WL3cH6lRzYOAOZuC+HttVx4Cd97dnKf7iC3p2cZ8unXdkPwXHbCQ0 iyG5eUd6pnZh
1xfukd6TFbKLv3yS38pDL8u2RW47FzxYMTgDfPuk+w8li5+dxiWP7K10fQnW 4lyUkpJCTk7O
qW7GSXEu7Wt1zqa+8N+Xmu7X6dIPp7odp3r7QgghTp56CNju4BtOubptx4ym G1w5pj8AP329
JiBwhxrBnvXAVWh1uAa7+L8rOf7ZEnr16o2Bwa6dO4m/agKthg6ibMMv7PQs 69mlB7s+W0LD
oYOIu3J0nfYzHCagU4N63wxPzFkQMNHZ+Osf4MuP/onmMlj09ANcOuvX+m+E EGews/GX7LNx
n4QQQgghaqsebtNV9Sni/uXqth0F3YCl327BZnfQSgkM3KHXMeo0cm7u1hqA woIscvKOE3/V
BN8otTdI7/xsCa2S4wLK14dtq9f6niuRvza/UpPvfcB3q67UdqkAEqzPIAmJ zRk16mIWffwx
iqJUWFZw9Mgpatm54WwMomfjPp3NVq9ezWuvvcYvv/xCbGwso0aN4rHHHiMx MfFUN00IIYQ4
K9TDbbpMFe6DHcww6n6qtjfIjx/VDwVY87+NAYG7rMxOSZmVsnIrf7tzguc6 aQVNr/2U2w26
daXtkrfJmnBLQLj28r7O/WwJbZe8TYNuXWu9rapcer673rc/ygegPvL1Le9t J8pVToyjmFhb
IQ3sRQB0aN3VF7LbtWtbD1sW9a1pk6a8+eabTJky5VQ3RQhxki1cuJCpU6cy dOhQrFYr//zn
P7nzzjtZtGjRqW6aEEIIcVaIeDZz6apntu7KH7ph4Krj7bI0Q2HVsvmsWjaf lcvmBwTua8YN
4eZrzufuP41lxh0T0A13qNeNus8i3qBbV7qlr6v0+urkZ2bSLX1dvYXrYF/9 ZzEvzq/6URtv
T+rDglvO41+3j2X2fdf5Tg0/kJ3uG8EWZ6bnnpvD62+8ya+/Vn7mQUZmJjfe eBNtU9vRqlUK
1153HUePHvUtT0hszltvv82AgQNJbpXCiJHns379Bj788CMGDxlKy+RWXHTR xezevce3jqZp
PPnkU3Tt2o2U1m2YcuutlJaWBmw3IbF5jffHbrczffp0unXrRrdu3ZgxY0bA /QxTUlJ4/fXX
GTRoEK1bu88qsdls3HfffXTq1Il+/frx6quvkpKSUuk2NE3jmWeeoU+fPnTs 2JE77rgjoO0u
l4vHH3+c3r170717dxYsWBCyHv9tpKSk8Oqrr9K3b186derEAw88gMPh8C1f tWoVo0aNIjU1
laFDh/LBBx+E3Z6atr8ubams38I5Lu+99x5Dhw4lNTWVsWPHsmvXrlrtw4MP PsjHH38cUP6j
jz7iwQcfBCAzM5PJkyfTpUsX2rdvz0033RTweU5JSeHdd99l2LBhtGvXjlGj RrFx40YWLVrE
yJEjfe1LS0sLWKeqPqtJ/1fVvzXt1+qWf/jhh4waNYqGDRuSmJjII488ws8/ /+xb7nA4uP/+
+33fG6+99lqFNoS738HCOQ7Bgr9nqvrMVPd9GO7nrbrPU20+L0IIIc4dEQ/Y mq7y7ZKF1T7q
ci00wNVX3RTwCA7cwV+9zzXjJN00+iS45foLw35EioTrM198fDz/nPs8U++4 E6cz9G3lbrjh
RqZOvZ296Wmkpe2hU6dOPPxw4Gz133//A8uWLuXA/n1cc/XVXHf99az4dgX/ /fwzfjuwnwkT
JnD/Aw/4yr/wwots3baN1atXkZ62h5iYGGbNeqLO+/Pss8+Sn5/Pjz/+yJo1 a8jJyWHOnDkB
ZTZv3szy5cvJzs4GYM6cOZSUlLBhwwZWrubL+9IAACAASURBVFzJxo0bq9zG vHnz2L59O8uX
L2fbtm3ExMTw9NNP+5bPnTuXvXv38s0337Bhwwby8vLCavv69etZuXIl69ev 58iRIzz33HO+
Zffddx/Tpk3j119/5bPPPmPz5s1ht6em7a9LWyoTznFZt24dS5YsYc+ePYwb N44ZM2bUah+e
fPJJFi1axLJl7gkmly5dyieffMJTTz0FwOTJk7n11lvZvn0727dvp2PHjsya NSug/jVr1rB4
8WL27NnDlVdeyaRJk1i5ciWLFi0iLS2N3/3ud0yfPj3sPgu37TXt3+r6NZx+ 9/fDDz8wcOBA
3+s5c+ZQUFDA+vXrWbFiBWvXrq2wTrj7HSyc41Cdqj4z1X0fhvt5q+7zBLX7 vAghhDg3KPfc
OdV46ZXXOFZwtNJC3y7/iksuHXcSm3Vu2bN7J+cNP5/jRYWnuiniNBf8vVjT 703/66wff3wW
JrOZRx5+qMKyYFarlX79+pOenuYr++vedJo1a+Zb3rpN2wrvtWvfgUP57l9y +/UfwKefLKJT
p04AHDlyhPMvuJC0PbvDantJcTHzXnqR+6fNIKX1ifkNBgwYwOLFi2nfvj0A Bw4cYOLEiWza
tAlwjzZt3ryZFi1a+NYZOHAgn332Gamp7nkEMjIyGDFiRKXXE3tHFTt27Ohr +5gxY9i6dSsA
gwYNYtGiRXTo0KHCupXNwJySksLatWtp164dAL/99hsTJ07kl19+AWDw4MHc eeedXHbZZSQn
J9eoPTVtf13aUtn+hXNcdu3aRZMmTQD356Vbt25k/j979x3fVPU+cPyTNt2F UtrSAS1lb9qy
igwZZaNAWaKIgoKgLEFlg4AMwQGC/uArqCigKLKVJUuRKbuMsvfqgAKFziS/ P0pDUtKMJl3w
vF+vvJrcce5zzr25zZNz78nlyzmqQ2xsLB06dKBDhw6sXbuWtWvX4uNj+IqI pKQkwsPDOXbs
mDaW48eP4+npqZ1fvnz5p6bpxmeqzXTbwlTsxto3K1Ptamq+rhMnTtC3b1+W Ll2qPXZr167N
ihUrtPW6cOECjRs3Nvu4zcrYIHiG9kPWZbMeX8aOGVPvQ0uON2PHU06PFxmv QAghCpYPhw3h
08++4P69e2Ytb+pz9/VrV1nw7be2vwdbCFE4jBkzmjZt29GyRQvq1w/Xm7d/ /39MmjyJY8ei
ePQo4zfgsg6KlplIA7i4uBiclp6ern198+ZNwuu/oFdG1jJzIi4ujqCgJ+MB BAUF6V12Cugl
15Dx4bmUTpKu+9yQW7du8eKLL+pN0409JiZGLwZzBQYG6j2PjX3yBceCBQuY PXs2X3zxBUWL
FmXSpEm0bNnSrHgsjd+aWLJjzn7JTHbg6ePF0jr4+PjQpUsXZs2axYQJE/SS 6wMHDjB16lSO
Hz+e7fGcmRhlxmJoWtb4jLWZJbFb0r6m2tWcdgfYs2cPQ4cO5dtvv9VLSGNj Y/XqZei4Nrfe
WZmzH0wxdsyYeh9acrwZO54gZ8eLEEKI50Mejj8thChIHB0dmfd/3zBs+PCn 7t996+236ft2
X04cjyIuNoZLFy+g0Zj+dQBjfH19OR51jPi4WO0jLjbGqjIBvL29uXr1qvb1 lStX8PLyMrlO
5uXigN5zQ0qUKMHBgwe5fv269qG7TokSJbhy5YrFsevGfe3aNb2RnENDQ1m0 aBFRUVFMmTJF
73JWU/FYGr81sWQnJ/vFGFN1OHnyJMuWLWPhwoV8++23XLp0STuvf//+9OnT h0OHDnHt2jWi
o6OtPp7BeJtZErsl7WuqXc1p97Vr1zJw4EAWLFhAaGio3jwfHx+99XWfW1rv rEztB6VSSVJS
kvb13buWXdWV0/ehIcaOJyGEEMIYSbCFeI5VqlSJPr17M3LUaL3pycnJODs7 4eTszOUrV/Tu
pc6pPr17M2zYcC5eukR6ejonT56ib79+esvkZJCzDh06MGHCBOLi4oiLi2PC hAl07NjR6Dod
O3Zk8uTJ3Llzhzt37jBx4sSnltEdXKlXr1589NFHXL58mfT0dKKjo3n33Xe1 87t168a4ceO4
efMm9+/fN1ieIRMnTiQ+Pp74+Hg+/vhjIiMjtfPee+89zpw5Q3p6OhqNRq83 zFQ8lsZvTSzZ
ycl+ycrcOjx69IjBgwfz9ddf07ZtWz799FP69+9PcnIykHE8Ozk54eTkxJUr V8z6gsAcxtpM
l6n2N9W+uu1gql1Nzf/222+ZMmUKv/76KyEhIU/F2qlTJ229MtfPab2zMrUf qlatyvz580lK
SuLWrVuMHGl4MNHs5PR9mCmznU0dT0IIIYQxkmAL8Zzr168vMTG39abN+Wo2 48aNJzAwiI4d
OxFeLzybtc03dOgQ6tcPJzKyM6UCg3inf3/at2tvdbmjRo3Cx8eHhg0b0rBh Q3x9fU1+MB8x
YgRubm7UrVuXZs2aUatWLZTK7O+YGTRoEPXq1aN79+6UK1eOgQMH0rbtk3tw PvjgAypUqECL
Fi2oX7++0RHJddWrV4/mzZsTHh6Op6en3qBIrVu3pm/fvpQvX56pU6cyd+5c s+OxNH5rYslO
TvaLMcbqMHr0aN566y3q168PQMuWLenatStjxowBMga/mjRpEuXLl6dbt27U rVs3x3HoMtZm
5sYOlrWvqXY1NX/SpElcv36dpk2bUrJkSe3j4cOHQMZ7w8PDg3r16hEREUGD Bg1yXO+sTO2H
zz77jI0bN1K5cmU6duxIo0aNzCo3U07fh1mZOp6EEEIIY2SQswJABjkT5rJ2 kLPCLLtBzmzh
3Llz9OrViz179ti0XGMK0qBHBSmWwkLaTAghhCjcZJCzZ1iVqtUluRa5ztzL r7MbSfxZM3Hi
RIYNG0ZKSgqTJk2idevW+R2SEEIIIYQo5CTBFuI58bwkzuYqVaoUjRo1IiUl hVatWslv1goh
hBBCCKuZnWBv2bQhN+MQQog81bdvX/r27Ztv2y9IlxcXpFgKC2kzIYQQQhhi doLd/bVeuRmH
EMIMv/28OL9DyFf29vaoVKr8DkMIIYQQQhRiKpUKe3v7XClbRhEXQhQKdnZ2 +Pn5c+vmjfwO
RQghhBBCFGKXL13E3z8AtVpt87IlwRZCFAoODg40bNSITRvXczr6lPRkCyGE EEIIi6hUKk5H
n2LZL0tp3bYtqSkpNt+GDHImhCgUHBwdCQwMot1LL/PnH2u5feuWJNlCCCGE EMJs9vb2+Pr5
0a79y5QpW45HDx/afBuSYAshCgWFQoGTiwuVq1SlRs0Q7OzkAhwhhBBCCGEZ tVpNWmpqriTX
YGWCfSc+DoDUlBTS0tJy5Rp2IXKTnZ0dSgcHnJycACju5Z3PEQmjNBpSkpNJ SU7O70iEEEII
IYR4itU92I8ePeLY+Rg27L3AxZsJtohJiDyhtLcj0NeDduFlCa3gi5OLS36H JIQQQgghhCjE
rEqwU1NTOXftLj9vPU37prV5rWQJ7O3lsk1ROKhUai5dj2Hp1oN4eRWjWhmP /A5JCCGEEEII
UYhZlWCnpaay+t+zdGxRj25NKtgqJiHyzAuVi6NU2vPLpiPMGPJSfocjhBBC CCGEKMSs6m5W
q9VcuplAKV8vW8UjRJ4r5evFxRt3ZdAsIYQQQgghhFWsvgc7XaXWuyx8+u9n rC1SmDC6a8X8
DuGZYm9vR7pKBugTQgghhBBCWEe67IQQQgghhBBCCBt4JhPs0iVcGfpyOYM9 vdL7K4QQQggh
hBAiNzyTCXbT6t6s2XdTe7m6JNVCCCGEEEIIIXJbriTY+Z3QlvBw4kpskvZ1 dveF51acti43
v9tTCCGEEEIIIYRpVg9yVhAp7RWoNZr8DkOIAu/2rZtEHT2S32EIIYQQQgiR q2qEhOLr55/r
27F5gp3Z25r5d/rvZ3i9aSCHzidw8uoD7XJFXZW82TyIbzddYnjH8myPiiO8 oicOSjtOXX3A
xkO3UakzkmSFAppU8yakjAeOSjvO3khk/cHbpKY/PfJz1u1nytqLbShOc7Y1 umtFth6NpV5F
T4q4KG1SbptaJbhxJ5ljl+5ry6kZ7EFAcSfCyhYzWJ4Q1tBNrFu0bpvP0eSu LZs2AM9+PW3h
eWqr56mu1pB2yjvS1nlL9/9gxMuv5EsMW9f9qn2eVx/8RcEg7/fcY6xtt2za QNTRI7n+frN5
gj399zOM7lpRLxHcfeoOLUJ8OHXtAZkdy42qePHf2QRS0jIS10BvFxZsvgTA S3X9eLGaF9uj
4gBoUNkLP09nvt9ymZQ0NS1DS9CshjebDseYtX1Dl1gbWs7cbQUUz5j/KEVl k3L/OhLLqy+W
Ii1dw6lrD6gSWISawUX5+Z9rbDwUY7A8IXIq80PF83BS37Jpw3NRT1t4ntrq eaqrNaSd8o60
dd7K/D/YtH13AG2HTl7L3D7Ajj9/0yb8kmw/+zLf7/Letz1jbas7D8i191me XCJ+4fZDUlVe
VA0swokrDyju7khZPzf+2nhRu8yWozHahHXLkVhea1JKm2CHlCnKsp3XeZCU DsCO47G83SLY
YIJtLXO2teVYrMHkOqflqtQaVu29wRvNgvAt5kSVwCL8tP0K6nw64YtnV9bk uriXN1UiZ4Cz
M86ZCzlD5itnZ5j9aW9W7731VFmD67jlUdQ5Y8k/rf3zwwCoN+BwboZUYD1P /+Cfp7paQ9op
70hb563M/4ON23bLt8TakMZtu2mf79ywPE962UT+a9G6rZwDcomxts2cB7mT ZOfZPdi7Tt2h
WQ1vTl59QONqXuw9fYc01ZMTW8LDNL3nbs722tdFXJT0bx2cJ3Gas63Ex0my Lct9mKzi+OX7
NKrqxbZjsTxMtiyBF8IUQz3Xbf93lOA2bXAGnJ2dcXYGZ6CYc8brYs7w/qhl zP60h15ZhhLu
gsTS5Lr1iCg2zayRy1EVTIba6tj+70yuV7Pe27kVUq6RDzHmMdZOR1c3BiCk 0868DOmZJcdk
3sr8P9igddcClVxn1aB1VwB2b/odsG0C8OqMHdjZKbBTKLC3U6C0s8Pezg6l nR1Ke0XGc3s7
7O2fzLNTKJjwenWbxSD0SZKde/Iryc6zBPvsjUSaVPOiaXUfShZ35o//9D+g F3Nz4G5iRpLt
4abUSzATk1T8tP2Ktvc3N+XWtkyVW8LDiZAyHqzYc4NWoSU4cyNR2x5C5JZL GzdmPDHSgw0Z
SbZzaKjeugW9B9scmcm17mvI3Z7sXbt38+6773H9+nXi42JtXr6Xt49Nym3Q 4sNs553dOJhj
+7/LlyTbVP1sVX+ABQu/4/btjOfjxha+LxRs7fCKRjTvuxeAbQvrE9bl31zb li33Y14qrHE/
byy9QtDjzk4S9vagWP1l3CveOJeielr9ll3Y+9cKm/Zml6hQFu8AH5zsFbgo 7XB2sMPdwQ5X
BzvcHRS4Ku1xdXg8z16Bg72CBav+s0FthDWGTPwee/uMLzvs7OyxVyqwt1Oi VNphr7RHqVSi
tLdH6WCf8dfejvdei8jvsJ9buZJgJ6epKV7EkTsPUvWm74q+Q6dwf9YfvP3U N4cRISVYfyAj
6W4RUoITV54MiHb4QgJta/vy15EY7j1Mx6uoIw0rF2f1vps2j9MW27K0XAel HR3q+bFm302u
xiWhUWuIrB/AT9uvkK7SZNueQljC0H3XQ6r8QoOR+ywua/eMcGCLjSIzLKcf VM39Fnj//DCa
9xmN6sFuAFq8+z8AHsUcZvf8sFxLsj/+eCIzZ3xKmzZtcqV8Sxhrq8zxMjSA gscvFAo0GnB0
86LEw8t5lmTbImmxtHfgwMGjbN68maVLv6Rnz+EcOFiHOrVDrIqhMDDWTiqV GtLuoQFUBgYZ
FZaRHivjbP1lRWbvdd2Izhb3Xifs7UGxyn4k7O2Bus01m8VkjroRnQH4b+tK wPqetpizF4g7
dxE7O90ebAVKO/uMHmx7u4wEzU6BnZ3d478Kq+uRE8/TF1amerHr1qlEvdDq qNJVqFQqbt2M
wbN4MdLS00lTpaNOV6NSqUlXq1Gr1Vy8WrCvNMxL5vRiF4oe7H1n7tAnIghH pZ3e4FwaDdxJ
TCVKZ7TsTNfikujXKhgHpR3R1x6w82Scdt6e03eoT3FefbEURZyVxCemsuvU nVyJ0xbbsrTc
1mElOHAugatxGb/dffbmQzzdHWkd5sufB25l255C2Iqfs+llzOHl7UOlSpXY 9e9OFIon/5A1
Gg0NGjbizJkzZv+zzO1/qimpanh4ExSuetNdPUrS4OVX2T4nhMZDjhpc18vb R/vczc2N2rVr
8+n0aVSqVMnkdk+ePElERMH+VlmlVqDWwIIV/5GSksajpBQSHybz6FEyn4/q hKObFwA+Dy9x
eN8PhIX3ybYs3bYC8PDwoGHDhkz55BNKlw4yK578+oA19P336dlzuFnLZq2n rryOP7c+lKrS
NWhS40CjQJVu3eW1Z8+eZcrUaezatYuHDx9StWpVhg4ZQocOL9so2tyXmx/+ Xxu/hJ8/eZ0h
E78HwNnZCXc3F9zdXXB2cuS91yK0y5iKMVPRokVp1qwpM2fOxNvLK1fizilD bZlbbZuTS8Pv
XwLISFiKJ/xLbNGG2S5bIaAIZ2880D7P5OrmRmhYXcZP+YzyFSs/NV9X5vq6 ajWL5ND2VYB1
SfbwiisYtNTPonW+7nkLmGtwXnbnPlvsv2cxuc7peeO/A6e5F5+I4vEXHnb2 SpQ3YrGzt8Pe
3g57e/uMh50dSqUdYPxLkWfhHFyQ5UqCvfvUHXYbSEqrBxVh54l4g79Rvff0 HfaeNpzIajSw
J/oOe6LNS3SzJqG6r7OObp41TlPbMifBtbTcrJfLA+w/e9doeULY2o4d0QAk AyQnk5ycMT05
OfnxNOjdu77JclxcXNi0eTNtWrfWTtuwYQOurq5G1sp7jYccZdnEqvR48yXs ilXg569mAdDj
zZdwLVaBe3eM36KR+Q/y/v37LFiwkP79B7Bjx3aT201JScHBwcH6CuQilcYe lVrD253rPJmo
UYBCg1oNPiGD0Tzu1b7x11cmy8tsK41GQ3x8PPP/9z969+nD9m1bcyV+WwgL C6HbFm+mTi7F
ihWbtdO7dX+F5b/9+tTyuh+YnrVel10/hgMZH9c0SRn/r1TpanY/nt7gTcuu grlw4QIdOnbi
o48+ZNaXX+Dm7s7xqCjmfv21fLgjI7lu0KABkNFr5V0s4+c6XV1cKFrEjT0H jgPQoEEDs5Ls
zGMxLi6O8eMnMHz4B/z046Lcq0ABp85y8UWlSbuo5/uIFKUDKfaOJDi7k6x0 4KGjC2lHrnP6
44YE91iW0Ysd7EfCjh6oX7pq9jZOX8tIlh88uM/i7+czfODbrN6066n5xmLM FNokkiN/W5dk
p6vscHN1Ii3xHgAnts0jtMMok+sY8yyd7wqq0JoV+LBfpPb1vmMXCK9ZNtvl P1+wKtt5cg7O
fcbfMTaiUEBoGQ883R05ZeBEIoTIHykpT543bVqZpk0r06ZpZdq0CaVTp4xH jx716d2jvl5y
rbteVkMGD2bOnDl6076aM5ehQ4boTbt0+TI9e75OUOlgAgJK0v2VV4iLe3Ll iu634l7ePvyw
aBGhYbXw8w+gadNmRB0/bnY9M++tzuqliSdZ9uMfqBPOGnxtjqJFizJo8CBO n8n48k2lUvHJ
J1OoVKkyJUsF0rdfPxITE/Xq5OXto/d83rz51KgZgrdPCZNlAGzZspWGjRrj 5x9AaFgtFi9e
oheTNW0FkK6yR6OB71Ye4H/L9zF36S6+WLSdafO38PHcDYz6fA0fTFuJWg1p anvTBT6mUCjw
9vbmow8/5HR0tHa6oR6QrPvfkJTUVAYNHkypwCAqV6nK3K+/tqCWxnXb4s3f q+ZpX+f08nBz
jvOs+z85OZn3Bg7S1mvO3Ll6bWDpMQamjxljVGlq2nYdRZuuo9Ek3UCTdJM2 XUfRpsso0nUu
FT+6urF2EDRjZsyYydAhQ3irTx+KFy+Ok6MjtWvXZtEPP+SoDY3Vzdg8L28f 5sydS6XKVSgV
GMTgIUNISU01a7vZtTNY9/7LTK4Htc344JyWqqZnxyZ4FS9GZKt6RLxQDWdn RwAGtS2rTbLN
4e3tzbRpU9m+/ckXgYaOv5SUFN4fNozgMmUJLlOWYcOGk6Jz0jfVbqbOX1m3 mV1bmnvMg2XH
t0qt0Xv4XvmXy/8d4taefdz9dyeaLRtw2riW4mt/xffKv6jUGm64NiDhEkDG l89Zy9B96G5D
97mrWxH69B/CuTPRBueb+6jRuBNRR49w+1bObpNMU9tT3MOVEl5FKeFVFIDi Hq7aR+M6FXm1
/Qu82v4F+nRpQp8uTShboUqOtgXZ//++e/cuFStVIiEhQW/5u3fvUqlyFRIS Ep46HnJyrBp7
P3p5+/D9Dz9Qq3Zt/ANK0rBRY/bu3ccvvyyjbr1w7TonT57SrmPO8Z3dNo2d N8yx69BZ9hw6
y64jZ0lXq9j1+HnG47z2+Z4jxj/DmHMONqdtLW27nKxj7T7OL3mSYI/qUpEG lYvz54FbGOi8
FkLkk2SeJEc7dkSzY0c0G3dEs3HjEVavzngsW7aXRcv2smjRXoPrZfXyyy8R GxvH/v0Zg6Ls
2rWLO3fu8NJL7fWWe+21ngwY0J8zp6OJjj5F+fLlGTdufLbl7tq1iw3r/+TC +XO0b9+eYcPM
u3Q3k26SvX9+mPZ1ZlKdKetrU+7fv8/cOXOpXj1jhNVZs2Zz5OhRtm/fxuno Uzg7OzNp0mTg
ybf88XGxet/4Hzx0kO3btxEXG2OyDID3Br7HqJEjuXz5En+sW8uBgwf0YrK2 rdJVdqjUGt7o
UJu3Iusx4JUGDOnVhI/6RjDuvTZMfv9lPh0RiUqtIU1lfoINEBcfz5ezZlGn Th3TC5swfdp0
4uPiOXL4EDv/+ZudO20zsnXnzRnJdZPIdwkJDcTXN+Oe7Ox6r40x5zjPuv+n TZvO/fv3OXLk
MP/+u5N9e/V7iHNyjJk6Zox5se9/rFk8FU3yDTQpt9Ck3ESTfIs1S6bw4tsZ 7/PDKxrRtM8e
mvbZw+GVjYyW9/c//xAZ2cns7ZtqQ2N1M1XvPbv3sOvfnRw5fIjYmFg+nf6p WdvNrp0h5++/
rMk1QGpqGht3ZtyqsnHnUTbuPEpa2pPBUi1NsnVv3cmU9fibOnUat27e4sB/ +/lv/z6uXb/G
tGnT9dYx1m6mzl9Zt2msLc0t05LjO2vCuuV/H+Hb4Vq2jx7rhtBjXcYXxAmX MpLBgEe7LU6w
7927x8L/m03lqjWsSrBVag1VG3bMcZKdkm6Hr6c7gSU82L58Bq8O+RJfT3d8 Pd15uVltXB0d
2HfmJuuj77HySCy7LydxR1Pc4u3oMvSe8PT0pMPLHfjxp5/0lv3xp5/o2rUL xR5fuaErJ8eq
qffj33//w7q1a7lw/hxdu3ThlR49+GvLX6xetZKLF87TsWNHhg1/so45x3d2 2zTnWM9OerqK
hrUq8EKtCjQMrYAqNZ2Gj59nPMppn78QWoH09OyvwjPnHGxO21radjlZxxb7 OD8oBr83QDPn
m3nciY/LdqEtmzbQ/bVeT02/fPECA2dvYcKg7tSrkPFGkHuEc9/orhXzO4Rn yv6zCUz++jdW
f9EHpbJgX7r728+L9QZpsGSQHEPLzp3Ynk5T/iHY+fGl4Y858+S17vPM17M/ bMDgiZue2kbm
pbE//vQTf23+iyVLFtOte3defvll3ujVy+ils0lJSYSGhnH6dLReWZnPz509 g6enp3bZ4DJl
DX64MFRP3Z/iqjfg8FOvDdlp5j3YAL6+vmzcsIGgoEBCw2rx+/LfKF++PACx sbE0frEJ0adO
PlWvzNcnjkfh5/fknjhTZdQMCWXI4EG0a9eOgICAp2Kzpq0Atm37jWZt+hms e1bbNy6gefPu
2c439C19sWLF+POPdVSuXFm7TNbjIuv+N/S8eo2arFu7hjJlygBw/vx56oXX N3iMZVfXzpu9
WdkqTu91ZnL9ZeXDfPThh7Rq1YqwMPMHObP0OM+6/6vXqMkff6wjuHRpAC5e vEiduvW0ZVp6
jIHxY0aXsXPKlq9rERkZiUahYfWq1bQYeAiAA781oOVbf6FBgUKhQaNRsOX7 ltTpvstgOb5+
/ly/dhWlMvu71CxpQ2N1M/VeOfDffu3xc+HCBTp2iiTqmOH3vbFzlG6Z1rz/ sibZsxdtYPIH
vdi48yhtGmccfxO+WML7vTMGSfx6wwV2796d7WXiujHGxcfz8ccTuXfvHksW /6Sdn/X4q1a9
BuvWrqFs2YwYzp8/T8dOkRyPOmZWu5lzfGbdpqlzgDXnxEyZg5xVbtDhqXl1 fuzBB/Wz/9Lv
i70HiO3xPpdW98AvtBgJRxJIeeWSwWVDyhTj6MUE7XNd3iX8WLxiMwGlggzO z5S5vinRu9da
PLr4n4tHcuDOC7gp0pg24V2GTloIQMVygcTduc+2i0m0e7Em7s4Zn4cSk9NY /88xvhzUljJe
T39BY+oebGPvibNnz9K1W3cOHvgPpVJJeno6devVY93atZQqVeqpc39OjlVj 70cvbx/OnjlN
8eLFtfNLBQY9NU13HXOOb1PbzO7cZuz8O3fJXzSqU+PxwKNo/2bn3wNRDH69 pcF55pyDzWlb
S9suJ+tYu48zGf3fZuVnaV3Xr11lwbffWn8PttLeLmNk0cck+ROFjUqlRmmf JxdzFDi6ibOh
e7B7dMr4aa6sY6Almzh19OjRgxkzZrJi5UpOnDjJkiVP967s3/8fkyZP4tix KB49egQY7l3J
lHnyhIz7vNPTLf8pvcZvzmWnTk925mtDSXZ2yXWm+LhYNBoNly5fZuiQoURF HSMoKJCbN28S
Xv8FvWWN1QvQ+8AAmCzjx0U/8PnnXzBj5mcULVKEqdOm6t3zbm1bpamVqNUa du05woCxXzNm
UA9e7dyCX1ZuYdrXy1izcCJly5Zi154jDPp0L2MSg3m9Q71sy9P9MJGQkMCC BQsZNXoMq1et
tCiurGJiYggKejJQWunHCam5MpPpwWXkRwAAIABJREFUzrzLylZxesn1Tw2v MXv2ZkJCWml/
qqtb91e065rbk23OcZ51/8fExBBYqpT2dWBgoN78nBxjpo4Zc7QYdIgVczLe P62GZLxn9v38
Aq16L0OdEp+RXD9eNqLnL2z+sT7hr+19qhxPT0/i4+Px9fU1a7um2tBY3UzV W/f4CQoKIiYm
xuztZsea99/Pn7yu7Y0e1LYsjx6l6vVgAzxKyjhzm0quM2UmQEWKFKFp0ybM +vILvflZj7/Y
2Fi991Lp0qWJjdVPCIy1mznHZ9ZtmmLtOVFXdoOcfbHX+FUdFxzCsdOOTWL8 p750t3Ho/F00
Gg3Xr15i0qjBnDx+FN+AQL355saYVYX6LxO1dx1g/j3ZKelKfIq5M25oD6Z8 tQyfYu4ABHgV
Yfv5RGpWK8u9Rynce/TkMtya1coyfck/fDu0icEyTfXGZveeqFChApUrV2Ld uj+IjOzE2nXr
qFe3HqV0zn+6cnKsmno/ZiZ2mfMNTdNdx5zj2xafV7JKTkklouGT3yLfsuu4 3uustuw6mO08
c87B5rStpW2Xk3VssY/zg1UJtp2dHcH+xbh2Ox4qW3f5iBD55drteMoEeKLO blSRZ1hK6pNT
QJumlXO0niFOjo68804/3ntvIGPGjMbJ0fGpZd56+20+mTyZiIjmFClShMTE RILLZD9gh7XS
bnyHU5Eq2p/jUj3YjZOrIw26DODvuSE0HGw8oTZEoVBQJjiY+fPnEdGiJU2a NMHX15dNGzfg
75/zUV5NlREWFsbSpUvQaDRs2bqVIUOG0ubkiRxvL6u0dHtUGg0Dxn7NmoUT 6dh3It0jIwgP
fXKMZJ1vLMHWVaxYMYYMHcKs2bO105RKJUlJSdp/tnfumDeoY4kSJbhy5Yq2 J+3KlSvmVfCx
la3i6My7/L1oHF7XxsOWcTTpPYWVreJYsHApbdrU4fDhA4SFZfy19PJwyNlx 7uPjw9Vr17Q9
2Fev6g+olJNjzFbHTGZinSk9Tc2GBRlXMLTtNQc0sGHJEKO9K01efJE1a9by zjvmXSVhqg2N
1c1UvXWPn6tXr+Lj42P2dnNLZpI9qG1ZkpNTaNM4RK8H+4/HA2SZk1yD5QNQ +fj46LXL5cuX
8fb21lvGWLvZ4hyYlS3PiVmT10fzIs360ckH33TCoygk30qAZCibto+z9obP e7rbyHzuXyqY
yZ//jzc6N6fOC01wdXM3GI+lytZ7iaj9Gbc1mZNkp6TbU7yEGwDFi7lpp7u7 OXPmahwORTy4
nZCkt05RVwfOXM3+SldrDOjfnxkzPyMyshP/+9+3fPbZTLPXNedYtbXcOL7N kZKaypot+zIG
ttJocHNxy3htZPnsmHMOzo+2LchxWMqqBNvBwYFOjSqwcP1+0tNVBJcsgf1z 2hMoCh+VSs2l
6zH8ueMgw3o0IDUlBUdHp/wOq3AwMshZpveHDuX9oUOznZ+cnIyzsxNOzs5c vnKFKVOm2DBA
ffUGHOaPz2vy0ltvY+deTm+es30yqSnWfcAJCAigfv1wfl+xgj69ezNs2HCm fzqdwFKlOHPm
LF/O+pKFCxaYXZ6pMvr1e4cPP/yAMmXKoNFoUKls+23to1Qn1Gr99MjUa3Pd v3+fhQu/o0KF
8tpp1apV4+uvv2HQoIEkJCQwZuxYs8rq0rkz48aN56s5X4FGw5gx5q2na2Wr uMfJ9SfQYjwr
W8Vx4GDGly2HDx/g9m3YuPEAvr7w34GD1K1T26Lyc3Kcd+4cyfjxE5g9K2Nk +6z3bJs6Pjw8
PDh37pz2EkbIvWOm4eMRxP9ZWBdN0k1AQ3q6WntvtiEjR47gpZc74OTsRIeX X8bVzY0Tx48z
Z+5cgwOdmWpDY3UzVW/t8QOMHTuOrl26mL1dQ+1sK5mJc2paGu+MyIhv5bod BpextcjITowZ
M5a5czMGqxw9ZgydO0fqLWOs3XJyDjTVlrY8J2ZNaNMfPSTwBdOD813ds5Pg d5YRvagHwfWd
iV7UA/qcN7kN3edeJfwJqVWf9WuWE9mjt8F4cqJ0nfZEHfgTMJ1kp6Tb4+Pq xOLlmyni+uQz
j7OjkqSUNK7EJ3I9PlFvnZJe7iSlGP9ljZxq1qwZ48ZPYOHChbi5uVGzRg2z 1zXnWLU1a//H
5/S8kZqcTscW4drXG/4+ovc6q792HMp2njnn4PxoW0MKShyWsi7BdnSkUpAX /TrUZuX24/z6
ZwLpquevF1AUTkp7O0r7FWNA53pUK+fHo4cP8zukPJecYtkAVdr1jAxyZq45 X81m3LjxXO3d
B39/fwYNHMiqVautLjc7TT88xu9Tq6F43K/W7b2hqB9dYcWPq2g9xvoRJ9/o 1YvJn0xh65a/
mDNnDpGRnbl16xbly5fng+GWDbgxdOgQo2W0bdeWN97szaVLlyhfvjzz5823 On5dqSolKo3+
udzUa2N079FzdXWlfv1wvlu4UDtt9uxZDB0ylM+/+AJ/f3+GDBnM2rXrTJY7 Zsxohg3/gJCQ
UNzd3Rk0aCB/bTGnL0pf/FsP8GI88W9l/MrFjBnTGDFiBDNnzmTp0i/p2XM4 I0eOYcaMaRb3
YufkOB8zejTDh39AzZAQ3N3dGdC/P1u3bdPON3V8DBo4kOYRLXj48KG29zK3 jxlVuiYjwVaA
Ks14wlC2bFlWr1rJlKnTmDRpMklJSVSrVo0hgwcbXN5UGxqrm6l6h9cPp2HD Rjx8+JCOHTsy
evQos7drqJ1t7dORPXOlXGPGjR3LiJEjqV2nLgAdO3Zg7JgxessYazdTx6ch ptrSlufErBer
pSQkkHr7yfhBuldf6N7vmpKQwElNXb3RgbO78E13etZlOnR7g3lfTqZj994A 1K/09G+S7z4V
n2382Qms1Z6oQ6aT7EfpSi5Hb9C+rhzkSYCPG8XSzxLgXRRXF0fUxd1ITcsI 3NHBjqIujii9
i2ZbpqH7sC15Twzo35/hH3zAb78uM3sdMO9YtbWcHN+6cnreSLj3gNcH6/fu L/19czZLG2fO
OTg/2taQghKHpawa5OxOfBwoFDg5OeHg4ICdnfRei8JFrVaTlpqqHfK/uFfB vuzE1oOcffhB
d4Z+tYEQD8t67t/q/SKff2Hd/bO5xZw2+WNiVXr068KyBSt4aeLJPIqs4Mmu rRb9vo0unTuy
5o+tTPt6GWMG9aDjSxHcunadjn0nsmbhRPxKldSbb+4l4vnF3PdK5kjhBw4e ZcaMadrpI0eO
oU7tkByNJG6ts2fP8kqPHhw6mP09dbZiyTlFb71vatGpUycUClilMwBaQZbf v1ee07bOb/nd
bjmVOchZQGg7venxHz659UUB+r928zi7fnxVLl5fROOw+EnPY1qvc3plJT16 SIcXq/DXActu
V7GlG0fWA1g8+BnAxXgN7T9aTNvmYSQ8TEGjUeDp7siGbYf587NeBgc5E7ZT WM8JhUGhGuSs
oCcjQpjD0dEJN/ci+R1G/kiFr97Nycnc6vER893znlwbk662R63W8HK75rzc rjmQMaBPiYAA
9qz/Vvv65XYRlCkdQMMQwwPSFGZ1aocQEtJK73VeGjtuHB99+CGpqamMHz+B du3amV4pH7UY
eIiVWQZAE6IgynpJdrGZp7JZ0vC6qp46vzGsU5ZarWLt70uoWKWmTS77zinf mhn/06OOZvRS
W5Jkl/FS8Odnvfjgmw1EX8roeKsc7C3J9TPEnN/fLoxfoBU0hf9TshAixz6f +1t+h5AvJLE2
Ll1lx7LlGzIuj3z8merJpZIKFGjIHC5ao+CZSrB1e6fHjX3b6PzcFBQYRL3w cJKTU2jbpg2j
R40yvVI+k8RaFAbGRv+2RkRYAKXLVGD01G9ybRuW8KnehqijG4k6esSi3uwy XgpWTijYX+iJ
nJPkOW9Igi2EEELPgFdND/gjclf//u/Qv/87+R3GM00+aOZMYW+33Opd3nzw ye/u5mcPtq7i
VTN+qizq6Caijh4BcnbpuBDCMpJgCyGEEEKI50JBSX7zkkflJ7e7RB3dLMm2 ELlMEmwhniNb
Nm0wvdAz4Hmppy08T231PNXVGtJOeUfaOu89h/m1niKVDCfbomCQc0Luycu2 lQRbiOeIjE4p
hBBCCACC5TOBELmReMvvagkhhBBCCCGEEDYgCbYQQgghhBBCCGEDkmALIYQQ QgghhBA2IAm2
EEIIIYQQQghhA5JgCyGEEEIIIYQQNiAJthBCCCGEEEIIYQOF5me6ZsyYwe3b Gc+//HJk/gYj
hBBCCCGEEEJkUSh6sDdv3srmzZsZMaINR49uZvPmrfkdUq4rWbKkVfOFKGy8 vH3yOwQhhBBC
CCGsUigS7Ew9ew7P7xBylSTNoiDx8vbRPoJKBxPZuQunT5+2WdlZxcfF2qTs nMRgqq6683Uf
QgghhBBC6CrQCXZERAQAvr7ehIS00j6yzjfHvHnzCAoKYt68eRbHYU7iW7Jk Sb1HlSpVePvt
t7ly5YrZ27l+/brFsQmRm+LjYomPi+V41DEaNWxI//4D8jukXGOqrpnzdR9C CCGEEELosjrB
3rFjBwqFwuzHjh07LN5GSEiI3utWrcxPrAHUajU//fQTEydOZPHixajVaotj MMf169e5fv06
165dY+fOnVSsWJF33nknV7YlRF4qWrQogwYP4vSZM4DhHuisPcI/LFpEaFgt /PwDaNq0GVHH
j+stl7UXOOvz73/4gVq1a+MfUJKGjRqzd+8+fvllGXXrhWvLPHnylHYdlUrF J59MoVKlypQs
FUjffv1ITEy0uq7mkh5tIYQQQghhdYLdtGlTtm/fjre3N9u3b0ej0Tz10J3f tGlTs8veunUr
ERERbN68FV9fGDGiDb6+GfdkR0REsHWrefdib9++HQ8PD9566y08PT2fSvJL lizJ4sWLCQ8P
p3Tp0rRq1YoTJ05o52X+NfcSboVCgbe3N++//77eZaaG1tedll35qampDBs2 jPLlyxMaGpqj
XnghrHH//n3mzplL9erVzV5n165dbFj/JxfOn6N9+/YMG5Zxi0dmz6+pXuC/ //6HdWvXcuH8
Obp26cIrPXrw15a/WL1qJRcvnKdjx44MG/7ktpFZs2Zz5OhRtm/fxunoUzg7 OzNp0uQ8qasQ
QgghhBBgo0vEmzZtyvLly+nWrdtTyeuOHTvo1q0by5cvtyi5zrR161Y0mnRA /x5sc5NrgEWL
FtGnTx8A3nzzTX744Yenltm9ezdr1qzh1KlTtG3blhEjRgBPLtvO7J02V3x8 PHPmzKF27dpm
r5OdmTNnEh8fz969e/nrr7/YtWuX1WUKYY7MXuYyZcvx/Q8/8N3ChWav+9nM mfj7++Pq6sqg
QQOJioqyaNuzvvyCkiVL4uLiwoAB/UlMTOTzzz7Tm3bkyBHt8kuWLmXGp9MJ CAjA3d2djydM
YN0ff9isrqbuwZZLxoUQQgghhM1+pks3yc5Mpq1JrnXvrx45cgy3b0NISCvt T3XpzjeWbF++
fJmjR4+y8PGH5Y4dOzJlyhSuXLlCUFCQdrnp06dTrFgxAAYMGMDs2bMtihee 7oH28PBg1apV
FpeT1apVq1ixYgXe3t4ATJ48mcaNG1tdrhCZYmNiuHj+HPfv3wOgReu2QEbS qNFouHT5MkOH
DCUq6hhBQYFmlenp6al97uLiQnp6ukUxFS9eXG99Q9N0y7x58ybh9V/QK0Oh UJi9PVN1NTeB
3rJpg9nbFEIIIYQQtmdnZ4d7kSKUKVsenxIl8nTbNv0dbN0ke+DAgXzzzTdW 9VxnmjFjBm3a
1OHw4QOEhWX8NbcH+6effiI+Pp6yZcs+NX3cuHHa15nJNeQsGQD9Qcru3bvH 999/z/jx4/nt
t98sLktXbGwsgYFPPujrfjEghLXu3rnDmeiTVKsRgp+/P0qlg958hUJBmeBg 5s+fR0SLljRp
0gSlUklSUpI28b1z505+hK7H19eXTRs34O/vn+MyDNXV3d3dojI6deme4+0L IYQQQgjrqdVq
4mJjOHLoIE5OThT18Mizbds0wYYnSXazZs0svufakMzfvD58+AC3b8PGjQfw 9YVNmzbRunVr
o+umpKSwfPly9u7dq5egXrlyhZdeeomPPvoIJycnq+LLjoeHBwMHDmTu3Lna aVmTkrt375pV
lo+PD1evXiU4OBiAq1ev2jxe8fw6d/Y0NULC8PMPICUlheTkZIPLBQQEUL9+ OL+vWEG1atX4
+utvGDRoIAkJCYwZO9aibXp4eHDu3DnKly9viyoA0Kd3b4YNG870T6cTWKoU Z86c5ctZX7Jw
wQKLy9Kta+833zRrHS9vH+LjYklMfGDx9oQQQgghhG25urlRvWYIZ8+cpl79 F1CpVHmy3Vz5
ma6mTZuSmJhodXINMGPGNEJDQ9m8eTMjRrTh6NHNhIXVYebMmSbXXbNmDWFh YXrJNWT0AIeE
hLB27VqzYihatCjnz5+3KO4HDx4wf/58ypUrp51WtWpV5s+fT1JSErdu3WLk yJFmldWpUycm
TpxIfHw8cXFxTJgwwaJYhDDmwf37+JTwJSUlGZXK+JUbb/TqxY8//sTs2bNY v349wWXK0rZd
e4tvWRg0cCDNI1rYdOTtoUOHUL9+OJGRnSkVGMQ7/fvTvl37HJeXWddM8jvY QgghhBCFi3uR
ItxLuIujY+50qhqSa7+D7ebmZnUZmSOFKxQZHe1ZBzkz9TvYixYt4s1sep/e eOMNFi1aZFYc
7777Lm3btjU5irju72DXqlWLffv2MX/+fO38zz77jI0bN1K5cmU6duxIo0aN zNr+iBEj8PDw
oF69ekRERNCgQQOz1hPCHGq1GgcHh6e+1TN0z3GzZs3Yvm0rNWvUYPv2bdy+ dZMjhw/xVp8+
essbWld32vDhw7hy+VK265ha39A0Ozs73n//fY4cPsStmzf4d+c/REZ2Mljn hw8f4urqalZd
M+eb+h1sGeRMCCGEEKJgsbOzQ61WY29vn2fbtPkl4rmhVasINm48oPfaHOvX r892XsuWLWnZ
siWAwdHBdacNGTKEIUOGGN2WOSOMV69enU2bNulNe+ONNwyWofvcycmJr776 iq+++ko77d13
3zW5PSHE01QqFUuWLCWkZs38DkUIIYQQQjxjCnSCrTuQ2ZdfPn05tSU/1SWE EAB+/gFUrFiR
ef/3TX6HIoQQQgghnjEFOsEWQghbi425nd8hCCGEEEKIZ1Su3YMthBBCCCGE EEI8TyTBFkII
IYQQQgghbEASbCGEEEIIIYQQwgYkwRZCCCGEEEIIIWzAqkHOJv580lZxCCGy mPha1fwOQQgh
hBBCCGEBqxJsjUZjqziEEEIIIYQQQohCzcoE21ZhCCGEEEIIIYQQhZv0YAsh hBBCCCGEEDZg
XYJN4Uuwi9xYz+3bGc9dw9rlbzBCCCGEEEIIIZ4ZVo0irtEUrseLvjFs3ryZ ESPacPToZl70
jcn3mGz1mNKrRr7HIHW17aOg0mg0JCclc//eA+7dTeDe3fs8fJBIakoqz8tV LV7ePvkdgjBT
YdlXhSVOIYQQQhj3XF4i3rPncO3zwloHQzLrMu3Nmoz58Vg+R2NbWev0LO23 wiQ1JZUH9+4T
ffoUFy6cIz4+DgBvbx/Kla9A9Wo1cHFzRam06tRic17ePsTHxeZ3GEIIIYQQ 4hn3XCTY+xcP
p16vL/H19SYkpJXePI1Go51f2GXuj9GLjuZzJLaXtU6F5dh7lqSmpBJz6zZ/ bd2Ij08JOkZ2
IaBkKQCuX7vKPzu2s3Llcnq92Qd7pRJVerrR8nR77Nzc3KhduzafTp9GpUqV bB67Ncm1JOf6
bWBqv2XXE5sXbSj7SgghhBD57bkZRVyjgV8O6U/bdt1bb35h9yzUwVzPU10L Ao1Gw8MHiWzf
sYV69erTuEkzvfllypajTNly7Px7O8t/+4Xeb/UjWaUy+UVIZjJ0//59FixY SP/+A9ixY3uu
1UPYhqn9JkmuEEIIIZ5XVt6DrSkUjzo9v+C/JcNpXjIOX18YMaINvr7QvGQc /y0ZTp2eX5gs
w95OQeeGpZj4enUmvl6dzg1KYW+n0M7/tE8Ijap6M7p7Vab3CUGj0aC0U9Ct cSCf9KrBuB7V
eLG6D58+nmfooQDa1PZj/KvV+OSNGrzatDSOyifbsFNA+3oBjH+1Gh/3rE7j aj7aebr7Q3cb
n/YJ4cXqPox7tRqf9KpB10aB2Ns9WbZiySIM61SJqW/WZGS3KtStUNzseCyN 35pYdOukW1dz
9kt4JS9GdqvC1DdrMqRjRfw9nXNUh04vlKR2eU/9Y6uCJ51eKIlGo8HT3YE3 I8ow+fUaTHmj
Jn1alsHNyf6pWEZ0zYhlWKdKlC7hSu3ynnzYpbI2Pt9iTgWuhz4lOYWz587g 5+9P4ybNSEpK
YuzYsdSsWZOaNWsyduxYkpKSaNykGcWKFef4sWM4ODiYXX7RokUZNHgQp8+c AQz3gupO8/L2
4YdFiwgNq4WffwBNmzYj6vjxbMvP6bqZ63l5+zwVk7EyVCoVn3wyhUqVKlOy VCB9+/UjMTEx
2/i2bNlKw0aN8fMPIDSsFosXL9HOu3T5Mj17vk5Q6WACAkrS/ZVXiIuL04vx +x9+oFbt2vgH
lKRho8bs3buPX35ZRt164dr4Tp48leP4spN1v+WEqfoZaxtdebGv6tSpS3R0 tPb1smXLtM+j
o6OpU6cuACkpKbw/bBjBZcoSXKYsw4YNJyUlRS/WefPmU6NmCN4+JZ7aztGj R6leoyb/+9+3
JtvAy9uHOXPnUqlyFUoFBjF4yBBSUlPNbt+0tDTGjR9PxUqVKFuuPN/83//l qG2EEEIIkeG5
SLA1Gg21X/scjSbjklXde7Azpptev3UtP4q6ODBz+UlmLj9JMTcHWtXy00v6 An1cmb06mpHf
HUaj0dCqlh/ODvZM+/UEX6w8RbCvm9F2axZSgpJeGWVMXhpFWrqatnUCtPNb hPnhW8yZ2auj
+fTXExR1UxpMOrM+L+PnzpcrTzH9txO4OytpGfYk7ldeDGLzoZuM/+ko8/48 S2AJV7PjsTR+
a2LJrn7m7Jeyfm7837ozfLz4GMcvJdC5YWCO6rBmzzVqVyhOzeBiaDQaapYp Rq3yxVmz5xoa
jYbeLcuy80QMk5ZGMfnnKGLvpfBSeEm9WCoEuDP/z7NMWHyMw+fv8FarslQq VZRv159jwuJj
HLtwly6P4ytI0lLTOHP2NPVfaAjAlClTSEpKokWLFsTHx7No0SKmTJkCwAsN G3Hw4H6UFiTY
9+/fZ+6cuVSvXt3sdXbt2sWG9X9y4fw52rdvz7Bhw02vZOG6mT2x8XGxT/XK Gitj1qzZHDl6
lO3bt3E6+hTOzs5MmjQ523jeG/geo0aO5PLlS/yxbi0HDh7QznvttZ4MGNCf M6ejiY4+Rfny
5Rk3brze+n///Q/r1q7lwvlzdO3ShVd69OCvLX+xetVKLl44T8eOHRk2POfx ZScn+y0rU/Uz
1ja68mJfNW/enN179gBw48YNRo4arU04d+3eTfOICACmTp3GrZu3OPDffv7b v49r168xbdp0
vbIOHjrI9u3biIuN0Zu+afNmund/hc9mzqB//3fMaoM9u/ew69+dHDl8iNiY WD6d/qnZ7Ttj
5kyio0+zY/t2Dh86yI0bN3LUNkIIIYTIYF2CXQgeB3/+UPtQKJTcvg0hIa20 P9WlO99YOaHl
PFmz9xoPktJ5kJTO6r3XCC3nqZ0PsHbfdRKT07XTQsp5su7xtMTkdNbtu260 3epW9GLVnqsk
PEwjOU3N+v+uUz24mHZ+7fLFWf14/qNUFWv3XtfbfnbP1+rEvWbvNcLKFdfO T1OpKeLqgKuz
kruJqSzfecXseCyN35pYsqufOftl5e6rJDxKIyVdzY6oGEp6ueSoDulqDUu2 XaRt3QDa1sl4
LNl2kXS1Bg3w+YpTnL3xgFSVmqRUFesP3KBiySJ6sSz/9yp3H6aSmq7mnxOx ODnYs2KX/rRS
3q4F7gfw1GoVcbEx+AeUBGD9+vV6XxxkTgPw9w/g8qVLZg10ltnbWKZsOb7/ 4Qe+W7jQ7Jg+
mzkTf39/XF1dGTRoIFFRUXmyrjllLFm6lBmfTicgIAB3d3c+njCBdX/8kW1Z zs4u3L59i/i4
OEqVKsVXs2dr5+3e9S+NGzfG2dmZokWLMn7cOLZv17+MftaXX1CyZElcXFwY MKA/iYmJfP7Z
Z3rTjhw5kuP4sjK13zLn6z6yY6p+xtrGXLbaV82bN2P37t0ALP/9d5ydnFi1 anVGPXbvpnnz
jFsnVqxcybRpU/H29sbHx4dPp09nxcqVemVN+eQTvL289KZ99913DB/+AcuW /ULbtm3NboPM
bXl7ezNt2lR+X7FCO89U+/7662/a+nt4eDD18RdllraNEEIIITJYdQ92WrrK VnHkmhrdZ2if
Hz68lTZt6nD48AHCwjL+6s43Vh93FyW37yahfpxQ3LqbRBFnpd468feT9dYp 4qIkJuHJOrcT
koxux8PVgRFdq+pN0+gsX8RVya27SajVhtMv3XJ1n+vGfTshiSIuT+L+ftN5 Wtf2p2WYH8mp
KlbuvsqJywlmxWNp/NbEkl39zNkv9x6m6q1nZ6fIcR3uPFDx35k4WtcOYM2e q9x58OSyzzK+
7rxcvxSlvF1xVNoZrP+9h0+Wz5yedZqx+PLP09/F/fbbbybWUZgsNT4uFo1G w6XLlxk6ZChR
UccICgo0KyJPT0/tcxcXF9JNDKpmq3XNKePmzZuE139Bb3mFIvv2+HHRD3z+ +RfMmPkZRYsU
Yeq0qbRp3RqA/fv/Y9LkSRw7FsWjR48MllW8eHG9WAxNsya+rEztN0vuwTZV P2NtYy5b7avG
jRszctRoAH7//Xfmfj2XWbNm0avX6xw4cJC5c+YAEBsbS+nSpbXrlS5dmthY /Tbx8/N7qvz/
+7959OjRg7CwML3pptogKChI73lMzJNecVPte/v2bb1YdVl7nAghhBDPo+di FHGA9mXvc/gw
HD58gNu3YePGA/j6QtvgeNZdqs+MAAAgAElEQVRfLG5y/QeP0vEs4kDcvYxk yMvdiQdJ6Xpt
kLU9HjxKp5i7A/H3M9bxdHc0uFym+4/S+HLVKb2EMOt8L3dHYu4lG5yfXSy6 cXu6O/IgKU07
/3JMIt9uOIsCqBLkwatNyzD+p7tmxWNp/NbEkl39crJfsptmTh1KerkSXtmb 7zado2ujII5d
uqvddu+WZVm1+yrRV++RnKrCydGeGW/VylEsBe29pVTa4eNTgps3rlM6uAzt 2rVj0aJFesu0
a9cOgJs3rhMcXAa12rwvCRQKBWWCg5k/fx4RLVrSpEkTlEolSUlJ2mTxzp07 Nq1PbvP19WXT
xg34+/ubtXxYWBhLly5Bo9GwZetWhgwZSpuTJwB46+23+WTyZCIimlOkSBES ExMJLlM2T+Mz
xNB+c3d3t7gcU/Uz1ja2YElbuLm5Ubp0aVavXoOzswutWrbks88+Z8OGDQQH B+Pq6gqAj48P
V65coUyZMgBcvnwZb29vY0UDsG7dWjp07ESxYh4MHjRIO91UG+hu6+rVq/j4 PLliwFT7+vr6
cvnyZcqVK2dV2wghhBAiw3NzD/aMGdMIDQ1l8+bNjBjRhqNHNxMWVoeZM2ea tf6hc/F0bhCE
u7MSd2clnRsGcehcvMH7gnXX6fRCIK5O9rg62RP5QtBTy301oK72+b8nYujR pDReRRxRKMC/
uAtvtiinnb8/Oo4ujYLwcHPA2dGOyAaBBref9XnkC0G4Odvj5mxPZIMgDpx9 EvebLcriW8yZ
zE4J3QHCTMVjafzWxJJd/XKyX3K6DxyUCl5vXoYft5zn6IU7/PrPJfq0LI/S XvF4vh1pKjWp
6So8izjyyovB2cZtzrSCxMHRkUqVq7Jn9y4Axo0bR+/evfHy8sLLy4vevXsz btw4APbs3kWd
evVJS02zaBsBAQHUrx/O7ytWUK1aNb7++huSkpK4efMmH3z4oc3rZC4PDw/O nTtn0Tp9evdm
2LDhXLx0ifT0dE6ePEXffv2yXb5fv3c4ffo0aWkZXzipVE96WJOTk3F2dsLJ 2ZnLV67o3Uud
U5bGZ4zufssJU/Uz1jZZ5cW+iohozrjx4+nerRsA3bp2ZcTIUURENNcuExnZ iTFjxhIXF0dc
XByjx4yhc+dIk7EEBATwx7q1LFmylNk6l4GbaoNx48YTFx9PXHw8Y8eOo2uX Ltp5ptq3R49X
GDlqNDdu3ODevXuMffw+zknbCCGEEMLqBLtwPE78PpqqXaajUGR02OsOcla1 y3RO/D7aZBnr
9l3jwaM0xvesyfieNbn3MJV1+65p5xtqjz/2XSMlTc3kXqGM6VGDi7cTUak1 esvorrf50A3O
30hkUIfKfNGvDm+2KMfRC3e089f/d51bd5MY1b06H/cM4c6DVIPlZH1+/uYD Rr9Sg4mvh/Iw
OZ0/913Xzj92MYG+bSrwRb86dKgfyI9bzpsdj6XxWxNLdvXLyX7JOs3cOnRv HMzfUbc5d/0B
Gg1EXUxg/+k4ujUujUYDS7ddJLJBEJ/3q8OQjlW4cPNBtnGbM60gcXB0oHKl KsTcvsXOv7fj
4uLC1KlTOXbsGMeOHWPq1Km4uLjwz45t3Eu4S0hIKKmpKaYLzuKNXr348cef mD17FuvXrye4
TFnatmtP48aNc6FW5hk0cCDNI1oYvY84q6FDh1C/fjiRkZ0pFRjEO/37075d +2yXb9uuLW+8
2ZvAoNJMmjSZ+fPma+fN+Wo248aNJzAwiI4dOxFeL9yq+uQkPlMy91smS+7B NlU/Y22TVV7s
q+bNmxMbG0vk44S5c+dIYmJiaN78SYI9buxYfEr4ULtOXWrXqYufnx9jx4wx Kx4/Pz/WrV3D
r78t5/PPvwBMt0F4/XAaNmxEaGgYnsWLM3r0KO08U+074qOPqFixAi82aUqt 2nUo9fi37XPS
NkIIIYQAxeD3BmjmfDOPO/Fx2S60ZdMGur/W66npg77Zl5ux2cyplWOo0nka AI7nd2inp5Zr
+tT83OTr6cJ7L1Xi48VHTC9sI18PDC8w+6kgxVIYfD3w6UTqt58X06L1k8GP tmzaoPfamOyW
3bJpA526dCcx8YHR9dPT07Gzs+PnpYspUqQITZo2p1RgxlUZ165e4e8d20hM fMCbffqiUChI
SzXv1gJRsD18+JDKVapy9crl/A5FGODl7SO/Oy6EEEIYYeyzri0+S2e6fu0q C7799vm4B7ty
5FRtrCllmzyZ8Xia7nxb69q4NOv3X0dpr6Bzw6DHvaF5224FaT8VpFiEZZRK JfZKJW/368+h
gwfYtHE9t25m/KSPv38ANUJCqVs3nJTUFEmunxEqlYolS5YSUrNmfocihBBC CFEoWJlg2yqM
Z1fcvRQ+fj0UB6WCYxfvsm7vtTxvt4K0nwpSLMJyqvR01CoVYWG1qFsvHHt7 JQpArVaTlp7G
w4eJ8iXKM8TPP4CKFSsy7/++ye9QhBBCCCEKBesS7AL3a70Fz7ajN9l29Ga+ bf/duXvybdtZ
FaRYRM5pNBpSU1NJlV7qZ15szO38DkGYIJeHCyGEEAXLc3GJuBBCiJzRHTBM kjkhhBBCCOPk
EnEhhBDZkqRaCCGEEMJ80oMthBBCCCGEEELYgFUJ9rfvN7RVHEIIIYQQQggh RKFml98BCCGE
EEIIIYQQzwJJsIUQQgghhBBCCBuQBFsIIYQQQgghhLABq+7Bzi0bojax7ewf HLl6HheVNwo3
FbV9a9OkYl2aVG2c3+EJIYQQQgghhBBPKXAJ9uTVX7Iv7hANa0fxXlgLYi6n oU7z5mzcGebs
PEr8o1g61+mc32EKIYQQQgghnlEqlQq1SiW/mlTAKRQK7OzssFcWnLS24EQC HDi/mwO39tE4
0I/arqNoEtyOJUnvc+1iLGW8gvEp6sTSg2sI8vSjTrkG+R2uEEKIQig1JYW0 tDTUanV+hyKE
ECIP2dnZoXRwwMnJyehy6WlpXL9+jePHj3P3zp08ik5Yys7OjqIeHlSpUoXS pYNROjjkd0hA
AUuwv/lvOcUc7Yi9n4CjqhSOCg/eqPp//MR77D10BFeFHwFuCn45vtnsBLtk yZLa50WKFKFJ
kyZMmzYNLy+v3KqGEEKIAurRo0fcu3uXm7dukPjgQX6HI4QQIo8o7Oxwc3PD 378kxYsXx8nF
BQz0TqtUKmJiYjh08CBNm0dQOrgM9vb2+RCxMEWlUnHx/Dn++XsH9vb2BAaV LhD7qkAl2Ndv
nMPHwZkr95NISnsIgBIX+lSdj6fTBLbtuQoKby7d+n/27ju8qXr/A/g7SdO9 m7RNd6FQVil7
WLZ6VVBZXuWqeEFZKgUKorJlT2UqDq574b3gQAUcIAoIZe/RAqWDlu42aZt9 fn/0R2joSAqh
Sen79TznMed81+ecYNJPvmdcqV+/WVkAgPz8fCxYsACvvfYaNm3aZPP4iYjI cWm1WpQplcjI
SEe79vEIkMkc4ouYiIjuPqNRQE72NZw/ewbePj7wdnaGRqOpXs9gwInjxzDg gQcRFd3MDpGS
tSQSCWJaxkIidcL+vXsRFBQEN3cPe4flWAl2QaEBZfpc6AU9yrXlpu0iuCAc g3E561V4uruj
RFpxW/3LZDIsWLAAXbt2NW0LDQ3FG2+8gffeew85OTnIzMyERqPB7NmzsW3b NgDA448/joUL
F5pOJ1Gr1Xjttdfw008/wdPTE+PGjcPixYtNiXxNfV69ehXz5s3D/v37odPp kJCQgDVr1kAm
k5naLF26FBs3bkR2djaaNWuGZcuWIS0tDevWrUNGRgZiY2Oxbt06tGrV6rb2 n4ioKdNptcjM
ykBcfAfI5IEwGg3Q6/X2DouIiBpIYFAQxGIxUi6eR68+/WpMsAVBQFFREcIj Iu0QId2OsLAI
FBcVQafTwc3ewcDBEmwddDC4VkBnNACim9t3nv4Fc75fBK3agOa+OuAO7jUg EomqbTt69Ch2
7txpOm18+fLlyMnJwd69eyEIAqZMmYIVK1Zgzpw5AIAVK1ZAqVTi4MGDAIBp 06ZZ7HPUqFFY
tGgR3n33Xeh0OqxatQrz58/H+vXrTW3++usvbNmyBX5+fvjggw8wcuRI9OvX D998841p2/Tp
002JPxERWc9oNEKlUsHPPwAGg543riEiaoJ8/fygVCohFtf+tGKj0QiJRMLv iUbCyckJRqPR
Yd4vh0qwH+yagORLB+EqEUEiqQxt+6mdWP3rBrh5uCAkRIEilQr9whNuq/+C ggIsXLgQvXub
P+rrjTfeMLsm+7vvvsOWLVtMs8sLFy7EP//5T1OC/f3332Pr1q2mNm+88QZ+ /fXXOvvcvXu3
6bWrqytef/11dO/e3azNihUr4OfnBwAYO3Ysli9fjmXLlplte/PNN29r34mI CBCMRkgkYuh1
OnuHQkREFhw/dgQ97usNdUW55cpWkojFEHiTS7qLHCrB/le7f+BE9lk4iSrg 6uSMnad/waKf
F8PgZITCRw6d0YhvC9sj5+wpXNg5GgAQHBwFn3nz6uz3xo3OvLy80KdPHyxf vtysPCgoyGw9
Pz8fERERpvWIiAjk5+eb1vPy8hAWFmZar/q6tj4PHz6MxYsX4/Tp0ygvr/yQ uHU2/UYiDQBu
bm41buPpjGRvgiBAo9ZAq9VBMBoAiOHkJIbU2RlSZ2mNZ4kQORrH+I2biIis wc9sakwcKsHu
0vw+vFSUg3cOf40vTn4PI3QICY6EyElASZkai+9Pwru9hmP66dOmNivbtcNr FhLsG9dGW0sm
kyEjIwNRUVEAgPT0dLPZaJlMhszMTERGVl6bkZmZabHP8ePHY968eejfvz88 PT2hUql4LTU1
OlqNFsqSUpy/cA6XL6eioKDyhyeZTI7mMS3Qrm0c3Dzc4eRAzyIkqkZAjXeO JSIiB2XhM7u8
rAzuHra9uZUgCA5zynFVTk5Opgm3qq/vtC+yHYf7K3hYl2GI8AvGV6d/wbH0 U3Bzc0NBfhp2
qh5EzqoPMGTIw0iZ/Yqp/pAhD+PCi6Otmsm21uOPP465c+firbfeAgDMnTsX gwcPNpUPHjwY
CxYswMqVKwFUng5uiVqthouLC1xcXJCeno5ly5bZJFaihqLVaJGbcx2//r4D cnkgBg8djpDQ
yrM3sjIz8Ocfu7F1638x8t+jIXFygsHCB3ZpaSmWLV+O7du349q1bHh6eqJn z54YN3YM+vTp
0xC7dFsCZHIU5OfZrI8Amdy03cPDA507d8aypUsQGxtbrbyqO42hKRPA2RAi osakrs/szPR0
nD55HPEdO0NR5fG8RPZS+9X9dtSl+X14c/Ab2JW4BT+N+RwHpu3F8QM7ENyq Fb77rvK/N5Yb
68cP7LDZ+K+//jrkcjkSEhKQkJCAoKAgvPbaa6byV199FR4eHujatSv69++P Tp06WZyxe/PN
NzF//nzExMTgn//8p9mdzIkcnSAIKFOqsPuP39CtWw88N+oFREU3g7OzM5yd nRHdrDn+/fwY
dOnaDf/95is4OztbPFX8hTFjoNfp8d233+FaViYOHjyAJ4YPx6pVTe8+AwX5 eSjIz8PpUyfR
KyEB48dPqLG86kJ3QqicDeHChQsXLo69mD62ay7PTL+KM6dPws/PH6dOHEN2 Vlb9+r1NtjpT
z5HP+Ksam5OTk2nx9fXFP/7xD5w7d67G8qpLU+WQCXZt3l22Bj06ROHdZWtM y4312lg6Pbym
cldXV7z55pu4cOECLly4gDfffBOurq6mcjc3N6xbtw6XLl3CiRMnMHDgQISE hNTZ58MPP4z9
+/cjPT0dycnJeP75583q1dTG2m1Ed5tGrUFK6kUEKxTo3bd/rfV69+0PX19/ nD55ElKptM4+
9+7dh3nz5iIyMgISiQSygAAMGTIYP/zwvamOwWDAwoWLEBvbCqFh4RgzdixU KpWpPEAmx7r1
6xHbqjXCwiOQOGkSNFqtqTzt6lU888yziIiMQkhIKJ586imz+ykEyOTYuPFd xLWPh0weaLHN
jdnkAJncbGbZUpzW8vb2xsTEibhw8WK92tU2y021ECpP++PChQsXLo693PzY rl6WkX4VF86d
w4AH/oGEvv1wX+++OHfmFK5dy7K6X8tfF7W3t9X+3UmbO43D2n0EAJ1OB51O h7S0NPTt2xfP
PvtsjeVVF3v8W3EEjSrB7tevg+m/N5aq2xvSG2+8gZKSEuTm5mL+/Pl46KGH GjwGooai0+pw
MeUCevS0fAf/ngm9cORIMpwsJNjdunVDUtJUHDp0CGq1usY6q1evwfETJ7B7 9y5cOH8Orq6u
mD9/gVmdv/f/jX17/8LxY0eRl5uHZUtvXn7x9NPPYMKE8bh44TzOnz+HmJgY zJ49x6z9kaNH
sHv3LuTn5Vpsc2Pm+NZZZGvitEZpaSnWr1uPdu3a1bstERFRU2E0GpGVmYk+ A+6Hi4sLdFpt
5dmlPXoiMz0dErGkwWKRSqV4//33ERMTA3d3d3Tp0gUnTpwwle/YsQPx8fFw d3dHTEwMPvzw
Q1O7G/+tOilx5coVDB06FH5+fvD09MSjjz6K3Nxci3EYDAbMmjULISEh8Pb2 xjPPPAOlUmkq
12g0eOGFF+Dj44OwsLDbfjKRj48Ppk2bZjaDbUltx+Be1WgS7A49Hoa6uBgA oC4uNi031jv0
eLhB4wkLC0OvXr3Qq1cv+Pj4YPr06Q06PlFDMhoNyM/LhSLE8rVNCkUIrqal WTw16NNPPkZ4
eDimJE1Fs+YxiO/QETNnzULx//9/DQCff/EFli9bipCQEHh6emLe3LnY9uOP Zv0sWbIYMpkM
MpkMS5Ysxv+2bDGV7d+3F71794arqyu8vb0xZ/Zss0fmAcCihQshq3ITQ2va 3MqaOOtyY0Y8
ullzfPjRR/jPpk01llddquIp4/UjCLaZeeDChQsXLnd3ufm5bb5dJBKhx30J cJZKodfrTds9
PDzRved9MApGq/q1lT179mDPnj3Iy8vDkCFDMGHCzUu9Ro8ejXnz5qGoqAi7 du3CgQMHAFTO
+N74r67KoyMHDx6MSZMm4dq1a8jKykLLli2tyjOWLVuGo0ePIjk5GVlZWXB1 dcWMGTNM5fPm
zUN+fj5SUlJw5MgRi3/b1KakpASrVq1CfHy81W1qOwb3qkZzcrzPvHnoi3n2 DsNkzJgxGDNm
jL3DIGogt/NbXN3XYPv4+GDOnNmYM2c2BEFAamoq3n7nHTz/whhs3fI/AEB2 dja69+hp3ust
13bf+ki9qr/yJicfwvwF83Hy5KlaH48XHBxstm5Nm1tZE2ddCvLzIAgC0q5e xeRJk3Hq1ElE
RISblRMREdFNxlqeZW0wGBo4EmD9+vXw9/cHAEydOhWLFy82lbm5uSEnJwd5 eXmIiIjA+++/
X2dfJ0+eNGu7aNEixMTEWIzho48+ws8//2x6fPCSJUvQuXNnbNiwAQDw9ddf 4/fff0dgYOUl
catXr0abNm2s3seqs+wKhQJ//vlnreU33PjhoL7HoLFrNAk2EdmPk5MYcnkg sq9lITIqus66
2deyEBUVDaPR+i84kUiEFi1aYOmSJWjW/OaXSFBQEHbu2A6FQlFr2/T0dERH V8aUkZEBufzm
7O7zL7yAhQsW4P77B8DLywsqlQpR0c3qjOV22lgTpyUikQjRUVF4992NuP+B B9G3b194enre
dn9UO71BD22Va/WJiMix2eMzW6fTQa/X1Vqu0dy8vM3Dw920LpGIodfrTeuf f/4Zli9fjvnz
58PHxxvLl6/AwIGP1NgPABw8eBCzZ8/ByZMnUFZ284f+qvVqep2VlYW2bdua 9VW1XU5ODhSK
YNN6SIiixvFr20eVSlk5GZCWhhdffAmHDh2CQhFsVl5be0vH4F7TaE4RJyL7 kTo7I7ZVG/y9
f5/Fun/v34cu3XpAp639SwkAHn98ML777nvk5eXBYDAgKysL8xcsQJfOnU11 Ro8ahaSkqbiS
lga9Xo+zZ89hzNixZv3Mnj0H+QUFyC8owKxZs/HE8OGmMrVaDVdXF7i4uuJq ejqSpk61GL+l
Nj4+PkhNTTXbZk2c1goJCUGPHt3NTnW3hDc5qyeeIs6FCxcujWIxfWzfst1g MODooWSUl5WZ
bS8tLcHRw4cgWPict/bLoq72Nb2uaVunTp2wefNmpKVdwcqVq5CYmFhn25Ej n8P48eNw8eJF
lJaWVLtpW21jBwcH48KF81AqS01LaWmJqTwoKAhpaWmm9bS0tBrHr2scAIiK isKmTR8gKSkJ
SqWy1v2outR1DGz9b8URMMEmIoukzlK0im2N3Os5+GtP7dfs/PnHLpQUFyE+ vgO0Wk2dfU6f
/gq2fvstevS8D4qQUDz8yECUl5fjww//Y6ozefIk9OjRHUOHDkNYeATGjR+P QQMHmfXTvUd3
JCT0QocOHeHn748ZM143la1buwazZ89BeHgEBg8egu7dulvcV0ttJr78Mgbc /4BZUmtNnPXx
3MiR+OSTT03rlq7BJiIiakrEYjHCIyNx/Ohh0+VcytJSnDx+DC1axsLV1eWO x6grSa8sty7B
Hj16NM6dOwetVgtBMJpdM+7j44OLFy+ata2oqICLiwucnZ2RlpaGxMTEWser +vr5559HYuIk
XL58GTqdDqdPn8aoUaNM5U888QRef30G8vLykJubi1dffa3G2K3Zx5CQEPTs 2QObN39jVYJd
1zEQBAFeXt71Wnf0BJuniBORRSKRCK7urnj62efw5RefITU1BX37DUBYeOX1 z5kZ6djzxy6o
VEr8e/QYVKgrLH7Y9e7dG717966zjlgsxpQpUzBlypRa60xKTMSk///yudXA gQMxcOBAs21j
x968d0JN1zZbajN1ahKmTk2qd5w3lJWVwd3dvc4Y+vfvj/79+9dafiteo10/ Ahzvy5iIiGpX
02d25Y/NIhxJPgAPTy+olKXo1KUbZPJAVFSU22LUOr8rqpbVVO/GtoEDB+KZ Z57FlStX0KJF
DD744H1T2aRJiejTpy/KyspQUlJ5k9cNGzZgxoyZePbZkVAoFJg0KRFbtmyt dbwbr5OSpmDN
mjV49NHHkJOTgxYtYjB9+nRT+axZMzFlyhS0bdsWnp5eSExMxC+//HLb+/jv f/8bb7wxH6NH
jwIAeHv7VGt/Y5/qOga19W9p3ZExwSYiqzg5OUHi5IQXxo7H0SOHsXPHz8jJ vgag8s7hcfEd
0LVrd2i0Guh4fWuNDAYDPv/8C8S3b2/vUJo2B/y1m4iIalfbZ7Z/QABat22H M6dOoku3HvCX
yVBeXmazMWsbt7i4yFRW9XVN5cOGDcOwYcOq9Q0A06ZNw7Rp08y2DRo0EIMG mf/QP27cuBrH
q/paJBIhKSkJSUnmkwA3yl1cXLBx40Zs3LjRVDZpUmKN+3hjMqCufbwxGSAI AoqLi2o8TtYc
g5r6t7Tu6JhgE5HVDHo9jAYDOnbshK7dukMicYIIlXfy1Ol1KCtTNaoPwIYW rAhBy5YtsfGd
t+0dChER0T3BP0CGXn37w93DAxXltpi5riQIAoQa7lTu53/z0Z5FhQU2G89R GAwGfPrJp4iP
j69x/8kyJthEVC+CIECr1TrEXZgb26nRebnX7R0C4eZ1dURE1DhY85ldXmab meubg9Y8bmFB
/s0q9+B3SWBQcOVkwMZ37sn9awhMsImoUbJ0o6/GlnwTERGR42iq9+uoOhnQ FPffFphgE1Gj
xASabodILG6yfzQRETU20c1icD0n2+b9isSWH6QkCAKM/K6g28AEm4iImgSx WAxPT0/k5V6H
u7uHvcMhIiI7KC8vg5eXF4x1XF8sFothNPLH2MbCaDRCbMWPJg2FCTYRETUJ UqkUYaHhuJSS
gujmzeHp6WXvkIiIqAGpVEpcuXQJcR06QKvR1FhHJBLB19cXGelXIZfXfTka OYaC/Dz4+wc4
TJLNBJuIiJoEqbMzvH18ENu6Da5cSoVSpeQdUomImgiRWAwvTy+0aReHgABZ rTdFE0skaNe+
PQ7s34eu3bsjMDAIIpGogaMlawiCgNzc6zicnIyOnTrB2dnZ3iEBYIJNRERN hEgkgoubG7x9
fREaFuYwv3QTEVHDMBqN0Gm1dd5xXCKRQKEIQVxcHE4cO46SkuI6Tycn+xGL xfDz80O7uDgE
BATAxdXN3iEBYIJNRERNiSBAo1ZDo1bbOxIiInJQUqkU0c1jEBIaBr1ex2ux HZhIJIbUWQo3
N3d7h2LCBJuIiIiIiKgKiUQCdw/eEJPqj+fHEREREREREdkAE2wiIiIiIiIi G2CCTURERERE
RGQDTLCJiIiIiIiIbIA3OSMiIiIiIqrCYDDAaDDwDuIOTiQSQSwWQ+LkOGmt 40RCRETUALQa
DXQ6HZ9rSkTUxIjFYjhJpXBxcamznl6nQ1ZWJk6fPo2iwsIGio7qSywWw9vH B61bt0ZkZBSc
pFJ7hwSACTYRETUh5eXlKCkqQnbONaiUSnuHQ0REDUQkFsPDwwMKRSj8/f3h 4uYG1DA7bTAY
kJubi6NHjqDfgPsRGRUNiURih4jJEoPBgCuXUvHnnj8gkUgQHhHpEO8VE2wi ImoStFotypRK
ZGSko137eATIZA7xRUxERHef0SggJ/sazp89A28fH3g7O0Oj0VSvZzDgxPFj GPDAg4iKbmaH
SMlaEokEMS1jIZE6Yf/evQgKCoKbu/2fXc4Em4iImgSdVovMrAzExXeATB4I o9EAvV5v77CI
iKiBBAYFQSwWI+XiefTq06/GBFsQBBQVFSE8ItIOEdLtCAuLQHFREXQ6Hdzs HQyYYBMRURNh
NBqhUqng5x8Ag0HPG9cQETVBvn5+UCqVEItrf5iS0WiERCLh90Qj4eTkBKPR 6DDvFxNsIiJq
MgSjERKJGHqdzt6hEBGRBcePHUGP+3pDXVFusz4lYjEE3uSS7iIm2ERUL4Ig QKPWQKvVQTAa
AIjh5CSG1NkZUmcpRCKRvUMkssgxfuMmIiJr8DObGhMm2ERkNa1GC2VJKc5f OIfLl1NRUJAP
AJDJ5Gge0wLt2sbBzckCFPAAACAASURBVMMdTg70LEJbCJDJUZCfZ+8w6q2x xn3XCajxzrFE
ROSgLHxml5eVwd3Dtje3EgTBYU45psbl3vormIjuGq1Gi9yc6/j19x2QywMx eOhwhISGAQCy
MjPw5x+7sXXrfzHy36MhcXKCwcLNowJk8hq32zshrCkpvZsx3c3jYO9jeTfY 4kcDAZwNISJq
TOr6zM5MT8fpk8cR37EzFKGhDRaTrTk5OfHGm/cIJthEZJEgCChTqrD7j9/Q rVsP9O7b36w8
ullzRDdrjr/27MZ/v/kKo54fC7XBYPGX33sxAbwdPA4NTeAMNhFRY1LLZ3Zm RjrOnD4FPz9/
nDpxDACgCAm5a2HUdoaeLRLjezG5bqo/GtR++zwiov+nUWuQknoRwQpFteS6 qt59+8PX1x+n
T56EVCq97fFeeWU6vvzyK7NtX3zxJV55ZToAwGAwYOHCRYiNbYXQsHCMGTsW KpXKVFen02H2
nDloGRuLZs1j8PY775jKapoxvrGt6n+r1qv6WqPRYEpSEqKimyEquhmSkqaa PeYjQCbHRx9/
jA4dOyFYEYJ+/frj1OnTt30sauuvqKgILWNjUVxcbFa/qKgIsa1ao7i4uNo+ bNz4LuLax0Mm
D7TJvgTI5Pjwo4/QqXNnKEJCkdCrNw4cOIivvvoaXbt1N7U5e/acqY2l966u MWt7f6qWWeX/
T/vjwoULFy6Ovdz82K5elpF+FRfOncOAB/6BhL79cF/vvjh35hSuXcuyul/L XxfV2+l0umqL
vY+Toy61vXd389+KI2CCTUQW6bQ6XEy5gB49EyzW7ZnQC0eOJMPpDhLsJUsW 46uvvsJ3330P
APj22+/w9ddfY+nSJQCA1avX4PiJE9i9excunD8HV1dXzJ+/wNR++YoVOH/+ Av7YvRvHjh7B
tWvXrBr3xkxyQX5erbPKixcvQU52Dg4fSsah5IPIzMrEkiVLz
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #4291 is a reply to message #4221] |
Thu, 20 November 2008 12:06   |
Hi again Edd,
I've just added an exemplar Ant script to the OO2DB M2M example in the
Epsilon subversion repository.
You can view the source here:
http://dev.eclipse.org/viewsvn/index.cgi/trunk/examples/org. eclipse.epsilon.examples.oo2db/launch.xml?revision=159&r oot=Modeling_EPSILON&view=markup
Using Subversion, you can check out the complete example from:
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.eps ilon/trunk/examples/org.eclipse.epsilon.examples.oo2db
To check out, I believe that you can leave both the username and
password fields empty.
Louis.
Louis Rose wrote:
> Hi Edd,
> Eclipse JRE?
> Cheers,
> Louis.
> Edd wrote:
>> Hi there,
>> make use of Epsilon tasks in Ant, to describe work-flows, so that 2+
>> step builds can be performed with a single script.
>> appreciated.
>> Edd.
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #4502 is a reply to message #4361] |
Fri, 21 November 2008 06:53  |
Hi Edd,
No problem. Glad that you're up and running!
Louis.
Edd wrote:
> Hi Louis,
> That's great -- thank you... Your screenshot and svn example really helped!
> It turns out that I indeed hadn't been using the same JRE as the
> workspace, and also had used the tag, metamodelUri instead of
> metamodelFile -- I had thought these would amount to the same thing, but
> perhaps not.
> Anyway, it works now and you've helped give me a basis for more work in
> Epsilon.
> Many thanks again Louis,
> Edd
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #562076 is a reply to message #4150] |
Hi Edd,
Eclipse JRE?
Louis.
Edd wrote:
> Hi there,
> I'm new to using Epsilon and have been experimenting with some simple
> model-model translations using ETL.
> I'm able to create .launch files to perform this, but would like to make
> use of Epsilon tasks in Ant, to describe work-flows, so that 2+ step
> My .xml build file contains the line:
> Then, when I run this Ant build file, I get the message:
> ..myFile.xml:5: Problem: failed to create task or type epsilon.loadModel
> Cause: The name is undefined.
> I'm probably making some basic error, but any help will be much
> appreciated.
> Edd.
--------------010504070806040905010108
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #562095 is a reply to message #4221] |
Hi again Edd,
Louis.
Louis Rose wrote:
> Hi Edd,
> Could this be because you're running the build from a JRE other than the
> Eclipse JRE?
> Click the drop-down arrow next to the External Tools button (green arrow
> with a brick) and then select "External Tools Configuration..." Click
> your ANT script's configuration and click the JRE tab. Then select "Run
> in the same JRE as the workspace." Click Apply and then Run.
> The attached screenshot shows the correct JRE option selected.
> Cheers,
> Louis.
> Edd wrote:
>> Hi there,
>> <epsilon.loadModel name="SomeModel" type="EMF"> ..
>> appreciated.
>> Edd.
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #562116 is a reply to message #4291] |
Fri, 21 November 2008 05:48  |
Hi Louis,
perhaps not.
Epsilon.
Edd
Re: (Beginner) Ant/Epsilon: "failed to create task or type epsilon.loadModel" [message #562161 is a reply to message #4361] |
Hi Edd,
Louis.
Edd wrote:
> Hi Louis,
> perhaps not.
> Epsilon.
> Edd
Current Time: Tue Jul 22 01:37:26 EDT 2025
Powered by FUDForum. Page generated in 0.28724 seconds
