How does eclipse handle linked java files in an ANT build file [message #47452] |
Wed, 18 February 2009 14:37  |
Hey,
I tried to export Ant build file using the Ant buildfiles export wizard.
However, it seemed it did not handle linked java files. For example, I
have a simple java project which contains a linked java file in the source
folder. I export the Ant build file for this project. I check the
generated Ant build file but did not find anything in the file which
handles the linked java file. I ran it outside of eclipse and the linke
file was not compiled. If there is a linked folder, I saw the generated
Ant build file handled it correctly.
I am not sure if this is a un-implemented feature? or it is not supposed
to be supported?
Thanks.
FUDForum. Page generated in 0.04081 seconds
