Home » Eclipse Projects » Plugin Development Environment (PDE) » How does eclipse handle linked java files in an ANT build file
How does eclipse handle linked java files in an ANT build file [message #47452] Wed, 18 February 2009 14:37 Go to next message
Hey,
I tried to export Ant build file using the Ant buildfiles export wizard.
However, it seemed it did not handle linked java files. For example, I
have a simple java project which contains a linked java file in the source
folder. I export the Ant build file for this project. I check the
generated Ant build file but did not find anything in the file which
handles the linked java file. I ran it outside of eclipse and the linke
file was not compiled. If there is a linked folder, I saw the generated
Ant build file handled it correctly.
I am not sure if this is a un-implemented feature? or it is not supposed
to be supported?
Thanks.
Re: How does eclipse handle linked java files in an ANT build file [message #47730 is a reply to message #47452] Fri, 20 February 2009 14:17 Go to previous message
I moved this post to eclipse.platform. Thanks.
Re: How does eclipse handle linked java files in an ANT build file [message #592232 is a reply to message #47452] Fri, 20 February 2009 14:17 Go to previous message
Previous Topic:Compiler warnings during headless build
Next Topic:Resource Navigator context menu
Current Time: Mon Jul 21 21:18:20 EDT 2025
Powered by FUDForum. Page generated in 0.03366 seconds
