Home » Archived » XML Schema Definition (XSD) » Value validation
Value validation [message #47445] Tue, 08 June 2004 06:59 Go to next message
Originally posted by: invalid.soft-gems.net
Ed,
Is there a built-in facility to check whether a given value is valid
compared to the effective facets of its type? I can write this myself, but
I would suspect that this is an often needed feature when working with
schemas, so it would be cool if there is already an implementation.
Mike
www.soft-gems.net
Re: Value validation [message #47505 is a reply to message #47445] Tue, 08 June 2004 07:24 Go to previous messageGo to next message
Mike,
To determine if a literal is valid with respect to a simple type, you can use
either XSDSimpleTypeDefinition.isValidLiteral or
XSDSimpleTypeDefinition.assess.
Mike Lischke wrote:
> Ed,
> Mike
> www.soft-gems.net
Re: Value validation [message #47535 is a reply to message #47505] Tue, 08 June 2004 10:19 Go to previous messageGo to next message
Works exactly as I wanted it (except for localisation of the error
message, but this is subordinated, currently). Thanks a bunch Ed.
Mike
www.soft-gems.net
Re: Value validation [message #47569 is a reply to message #47535] Tue, 08 June 2004 10:55 Go to previous messageGo to next message
Mike,
The translation is done at the end of the development cycle. IBM pays for it (and
it's not cheap!) and then donates it to Eclipse. For standalone support, we create
the xsd.resources.jar based on the donation from IBM, so that currently contains
the translation from the 1.1.1.1 release. Unzipping that file and copying the
*.properties file to where the English plugin.properties file is should get you
translation for what was translated before...
> Mike
> www.soft-gems.net
Re: Value validation [message #47593 is a reply to message #47569] Tue, 08 June 2004 10:56 Go to previous messageGo to next message
Ed Merks wrote:
> Mike,
it (and
create
contains
the
you
This is excellent news Ed. We were thinking of doing this (at least
partially) ourselves but this way is much better :-)
A last question for today: How would I go to get an assigned default value
for an attribute if there is one? I could not find anything related to
"default" in XSDSimpleTypeDefinition interface.
Mike
www.soft-gems.net
Re: Value validation [message #47622 is a reply to message #47593] Tue, 08 June 2004 11:09 Go to previous messageGo to next message
Mike,
XSDFeature.getValue will return the default value of an XSDElementDeclaration or
an XSDAttributeDeclaration. This is an XML Schema infoset property. It is
computed from XSDFeature.getLexicalValue, which is the string literal default as
it appears in the schema.
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> it (and
> create
> contains
> the
> you
> Mike
> www.soft-gems.net
Re: Value validation [message #47651 is a reply to message #47622] Wed, 09 June 2004 04:33 Go to previous message
Ed,
default as
Thank you.
Mike
www.soft-gems.net
Re: Value validation [message #588272 is a reply to message #47445] Tue, 08 June 2004 07:24 Go to previous message
Mike,
Mike Lischke wrote:
> Ed,
> Mike
> www.soft-gems.net
Re: Value validation [message #589115 is a reply to message #47505] Tue, 08 June 2004 10:19 Go to previous message
Mike
www.soft-gems.net
Re: Value validation [message #589128 is a reply to message #47535] Tue, 08 June 2004 10:55 Go to previous message
Mike,
> Mike
> www.soft-gems.net
Re: Value validation [message #589139 is a reply to message #47569] Tue, 08 June 2004 10:56 Go to previous message
Ed Merks wrote:
> Mike,
it (and
create
contains
the
you
Mike
www.soft-gems.net
Re: Value validation [message #589147 is a reply to message #47593] Tue, 08 June 2004 11:09 Go to previous message
Mike,
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> it (and
> create
> contains
> the
> you
> Mike
> www.soft-gems.net
Re: Value validation [message #589157 is a reply to message #47622] Wed, 09 June 2004 04:33 Go to previous message
Ed,
default as
Thank you.
Mike
www.soft-gems.net
Previous Topic:Schema standard types
Next Topic:Bug in substituitionGroupAffiliation?
Current Time: Sun Aug 31 18:21:09 EDT 2025
Powered by FUDForum. Page generated in 0.27689 seconds
