Home » Eclipse Projects » Mylyn » Error parsing server response
Error parsing server response [message #47442] Wed, 23 April 2008 04:08 Go to next message
When synching a request with our Jira repository I get the following error
message:
Error parsing server response: The entity name must immediately follow the
" in the entity reference.
Running Jira 31.21.1 on an Apache Tomcat 5.5.20. Tested this with Eclipse
3.3.1.1 and Eclipse 3.3.2 and Jira Connector 2.3.2.v20080402-2100.
Unfortunatly coulnd't test it with Ganymed M6.
Anyone got this problem already?
greetings
Tom
Re: Error parsing server response [message #47531 is a reply to message #47442] Thu, 24 April 2008 14:26 Go to previous messageGo to next message
Hi Tom,
Mylyn parses XML output from the JIRA repository when you synchronize a
query or an issue. The error you are seeing indicates that the XML parser
received a malformed response, e.g. an ampersand character "&" not being
properly escaped.
Do you get the error when you synchronize a single issue/query or when a
background synchronization is running? If the former is the case you could
try to open the issue/query in a browser (right click in the task list >
Open with Browser) and verify if the "XML" output is valid.
Steffen
> message:
> greetings
> Tom
Re: Error parsing server response [message #47653 is a reply to message #47531] Mon, 28 April 2008 06:20 Go to previous messageGo to next message
Hi Steffen!
Thanks for your help! We overlooked the '&' in our Companies name for more
than 2 days;)!
greetings
Tom
Re: Error parsing server response [message #47713 is a reply to message #47653] Mon, 28 April 2008 16:43 Go to previous message
Great that you found the cause! Do you know in which of the field the
company name was used? I would like to create a test case that reproduces
the error.
Steffen
> Hi Steffen!
> than 2 days;)!
> greetings
> Tom
Re: Error parsing server response [message #589218 is a reply to message #47442] Thu, 24 April 2008 14:26 Go to previous message
Hi Tom,
properly escaped.
Steffen
> message:
> greetings
> Tom
Re: Error parsing server response [message #589265 is a reply to message #47531] Mon, 28 April 2008 06:20 Go to previous message
Hi Steffen!
than 2 days;)!
greetings
Tom
Re: Error parsing server response [message #589285 is a reply to message #47653] Mon, 28 April 2008 16:43 Go to previous message
the error.
Steffen
> Hi Steffen!
> than 2 days;)!
> greetings
> Tom
Previous Topic:Connecting to JIRA through a central authentication service (CAS)
Next Topic:Lots of Mylyn errors
Current Time: Thu Jul 17 18:54:55 EDT 2025
Powered by FUDForum. Page generated in 0.24993 seconds
