Home » Eclipse Projects » Technology Project and PMC » RC1 memory leak????
RC1 memory leak???? [message #47413] Sun, 02 March 2003 22:03 Go to next message
Has anybody else experienced memory issues with RC1?
I recently moved from 2.0.2 to RC1 and ever since I made the move I find
myself needing to restarts Eclipse after a couple hours of work because
resources are running low, I never had the problem with 2.0.2 but it is
almost like clockwork with RC1.
Robert
Re: RC1 memory leak???? [message #47444 is a reply to message #47413] Sun, 02 March 2003 22:17 Go to previous messageGo to next message
Originally posted by: kduffey.marketron.com
Been running on my laptop for 3 days straight no restart. Sometime I notice
a "slowdown" but not sure why. It always seems to occupy about 90MB of ram
or so.
"Robert Upshall" <rupshall@psasoft.com> wrote in message
news:b3uhia$5g9$1@rogue.oti.com...
> Robert
Re: RC1 memory leak???? [message #47474 is a reply to message #47444] Sun, 02 March 2003 22:23 Go to previous messageGo to next message
If you use Task Manager to display memory consumption, you need to display
the "virtual memory" column. This will show you real memory consumption,
which is probably over 150MB.
My M5 IDE workspace says
Mem Usage : 120MB
but *VM* Size: 360MB
"Kevin" <kduffey@marketron.com> wrote in message
news:b3uhq1$5k2$1@rogue.oti.com...
notice
> or so.
> > Robert
Re: RC1 memory leak???? [message #47504 is a reply to message #47413] Sun, 02 March 2003 23:19 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Simple explanation. Eclipse memory usage increased considerably in 2.1
(along about M4 time). It now runs at right around the default max memory
(100MB) which means when you experience the slowdown you are spending all
your time in garbage collection.
Try launching with -vmargs -Xmx256M and see if your problem doesn't go away.
Bob
> Robert
Re: RC1 memory leak???? [message #47534 is a reply to message #47504] Mon, 03 March 2003 00:54 Go to previous messageGo to next message
Originally posted by: ron.baldwin.sourceprose.com
"Bob Foster" <bob@objfac.com> wrote in message
news:b3ukqf$6sm$1@rogue.oti.com...
away.
> Bob
Does anyone know what caused the increased memory usage or if anything is
being done about it?
Ron
Re: RC1 memory leak???? [message #47588 is a reply to message #47534] Mon, 03 March 2003 02:46 Go to previous messageGo to next message
"Ron Baldwin" <ron.baldwin@sourceprose.com> wrote in message
news:b3ur0o$9j9$1@rogue.oti.com...
memory
all
> away.
> > Bob
I'll let someone else answer that, but the answer doesn't matter to you.
Even if it only increased a couple of meg, the problem is that on your
system you are using very close to the max memory, which makes Eclipse very
slow and unstable. So...
> away.
Bob
Re: RC1 memory leak???? [message #47675 is a reply to message #47413] Mon, 03 March 2003 06:22 Go to previous messageGo to next message
you wouldn't be using xdoclet and ant by any chance?
there is a bug in ant+xdoclet (and possibly onther tasks) which causes a
memory leak in eclipse
http://bugs.eclipse.org/bugs/show_bug.cgi?id=24448
as far as i have seen a patch has been accepted by ant for ant version 1.6
which should fix the problem.
sincerely
morten wilken
> Robert
Re: RC1 memory leak???? [message #47766 is a reply to message #47534] Mon, 03 March 2003 12:11 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
Our benchmarks actually showed a decent reduction in footprint from
2.0.2 to 2.1 M5. We would be very interested in learning about what use
cases result in footprint spikes, if you discover them. Everyone is
encouraged to enter bug reports with the "performance" keyword in
bugzilla if they have encountered performance losses from 2.0.2 to 21.
Here are some 2.1 M5 benchmark results:
http://www.eclipse.org/eclipse/development/performance/21m5/ performance.html
And here is the overall information page on the Eclipse performance
improvement effort:
http://www.eclipse.org/eclipse/development/performance/index .html
Re: RC1 memory leak???? [message #47913 is a reply to message #47766] Mon, 03 March 2003 15:07 Go to previous messageGo to next message
There is no actual Sun Java VM 1.4.1_01/_02 taken into consideration, which
most people nowadays use.
Beside this, a users/developers normal daily work would also involve many
editor related tasks, like opening different source files, inserting,
copying and pasting text, showing up help etc. I don't know if such issues
were somehow taken into consideration too in the shown measurements?
One thing I generally realize in allmost all Java IDE's is, if you do a lot
of text copy/paste and help popups etc. the memory consumption increases
dramatically fast and the overall performance slows rapidly down. Don't know
if it would be possible to automate such usual editing tasks for some hours
and try to measure them. - What I generally mean here is, that the users
common interaction with the UI parts, mostly produces much more memory usage
overhead than performing a (re)build and such easier automated/measured run
tasks. - Eclipse performs here somehow much better than other Java IDEs I've
used, but might also under special circimstances have possibly similar
problems. - There are situations, where the VMs occupy nearly max memory,
but aren't freeing it again in the same manner they allocated it, which may
be resulted to still referenced (not nulled) objects or dangling object
pointers and the like. This in turn always influences the way how and when a
garbage collection will be performed. The results are then slow harddisk
swappings. - However, AFAI can actually see, Eclipse behaves here much
better than other Java IDEs I've in use.
-Valentino
"John Arthorne" <John_Arthorne@oti.com_> schrieb im Newsbeitrag
news:3E638CCE.5030106@oti.com_...
> improvement effort:
is
Re: RC1 memory leak???? [message #47942 is a reply to message #47588] Mon, 03 March 2003 23:31 Go to previous messageGo to next message
news:b3v0u6$cdh$1@rogue.oti.com...
> memory
> all
> > away.
> > > Bob
is
very
Who are you to tell me what matters to me? :-) Actually, I've used -Xmx256M
for quite a while now, so I haven't had any problems. I was only concerned
from the standpoint that I don't want to see Eclipse bloated unnecessarily
(assuming there is such a thing as necessary bloat).
Ron
> > away.
> Bob
Re: RC1 memory leak???? [message #47972 is a reply to message #47766] Tue, 04 March 2003 00:06 Go to previous message
Yes, I know. One of the OTI people followed up very seriously on a bug
report I filed on this subject but wasn't able to repro the condition. But
between M3 and M4 my steady state memory use went from 45MB to ~95MB.
Anecdotal evidence from the newsgroup suggests I am far from the only person
who experienced this.
It probably has something to do with my pattern of use (for one thing, I
tend to have a _lot_ of open files) but the fact remains that you folks
think the memory footprint shrank and a lot of users think it increased. The
fact that increasing the default max memory eliminates the problems users
experience should count for something. ;-}
Bob
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
> improvement effort:
is
Re: RC1 memory leak???? [message #591015 is a reply to message #47413] Sun, 02 March 2003 22:17 Go to previous message
or so.
> Robert
Re: RC1 memory leak???? [message #591027 is a reply to message #47444] Sun, 02 March 2003 22:23 Go to previous message
Mem Usage : 120MB
notice
> or so.
> > Robert
Re: RC1 memory leak???? [message #591039 is a reply to message #47413] Sun, 02 March 2003 23:19 Go to previous message
Bob
> Robert
Re: RC1 memory leak???? [message #591051 is a reply to message #47504] Mon, 03 March 2003 00:54 Go to previous message
away.
> Bob
Ron
Re: RC1 memory leak???? [message #591075 is a reply to message #47534] Mon, 03 March 2003 02:46 Go to previous message
memory
all
> away.
> > Bob
> away.
Bob
Re: RC1 memory leak???? [message #591107 is a reply to message #47413] Mon, 03 March 2003 06:22 Go to previous message
sincerely
morten wilken
> Robert
Re: RC1 memory leak???? [message #591146 is a reply to message #47534] Mon, 03 March 2003 12:11 Go to previous message
improvement effort:
Re: RC1 memory leak???? [message #591201 is a reply to message #47766] Mon, 03 March 2003 15:07 Go to previous message
-Valentino
> improvement effort:
is
Re: RC1 memory leak???? [message #591214 is a reply to message #47588] Mon, 03 March 2003 23:31 Go to previous message
> memory
> all
> > away.
> > > Bob
is
very
Ron
> > away.
> Bob
Re: RC1 memory leak???? [message #591226 is a reply to message #47766] Tue, 04 March 2003 00:06 Go to previous message
Bob
> improvement effort:
is
Previous Topic:WSAD: Are there any application launch events for "Run on Server"?
Next Topic:Help. How can i use JDK 1.4.1_02 in enclipse
Current Time: Fri Aug 29 17:33:37 EDT 2025
Powered by FUDForum. Page generated in 0.13189 seconds
