Home » Eclipse Projects » Mylyn » Connecting to JIRA through a central authentication service (CAS)
Connecting to JIRA through a central authentication service (CAS) [message #47410] Tue, 22 April 2008 18:39 Go to next message
Originally posted by: nclemeur.daesim.com
I am trying to connect to a JIRA instance where the authentication has
been customised and is handled in a separate application (CAS).
The problem I am having is that it seems that mylyn does not handle well
the redirect to the authentication form (from https://www.mysite.com/jira
to https://www.mysite.com/cas). The error displayed is "Server error:
(302)Found"
JIRA is running on tomcat which is accessed through mod_jk and apache. For
authentication, I am using CAS (http://www.ja-sig.org/products/cas/)
through mod_auth_cas which means that the authentification is done before
the JIRA instance is accessed. Once the authentication is done in CAS, the
user is automatically redirected through original request.In JIRA, I have
a filter that check the remote user and automatically log the user in.
I would appreciate any advice helping to found where the problem is.
I am running JIRA 3.12.2 and Mylyn 2.3.
PS: to test that my eclipse configuration was ok I have successfully
connected to http://jira.codehaus.org.
Re: Connecting to JIRA through a central authentication service (CAS) [message #47501 is a reply to message #47410] Thu, 24 April 2008 14:01 Go to previous message
The JIRA connector follows redirects on login but expects certain responses
in order to validate a login. The error you are seeing comes from the Axis
SOAP client that is used to access the JIRA remote service. Please make
sure that SOAP/RPC services are enabled for your repository:
http://wiki.eclipse.org/index.php/Mylyn_FAQ#What_are_the_ser ver_requirements.3F
If that is the case please file a new bug report:
http://www.eclipse.org/mylyn/bugs/
It would be great if you could include the sequence of redirects for login
and accessing a site, e.g. http://mysite.com/jira/browse/ISSUE-1 .
Steffen
Nicolas Clemeur wrote:
> Hello,
> (302)Found"
Re: Connecting to JIRA through a central authentication service (CAS) [message #589213 is a reply to message #47410] Thu, 24 April 2008 14:01 Go to previous message
Steffen
> Hello,
> (302)Found"
Previous Topic:Is it possible to report a bug from the Problems view?
Next Topic:Error parsing server response
Current Time: Sat Jul 26 12:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.03988 seconds
