Home » Language IDEs » AspectJ » 3.1M4 ClassCastException
3.1M4 ClassCastException [message #47364] Thu, 03 February 2005 13:38 Go to next message
Originally posted by: wharold.e2open.com
[posted earlier on eclipse.platform. Darin Swanson pointed out the AJDT
reference at the top of the stack trace and suggested I repost here]
I just moved up from 3.1M3 to 3.1M4. I'm getting frequent Error dialogs,
usually when I go to open a project or package but occasionally when I just
access a file. In the log the error is always the same:
java.lang.ClassCastException: java.util.ArrayList
org.eclipse.ajdt.buildconfigurator.PropertyPageManager.extra ctJDTRegistryPag
eContributors(PropertyPageManager.java:120)
Modulo these dialogs everything seems to work. I spent the last 45 minutes
searching the newsgroups but I didn't see a reference to this problem. In
case it's brand new here's the log file header information:
!SESSION 2005-02-03
10:56:39.261 -----------------------------------------------
eclipse.buildId=I20041216-2000
java.version=1.5.0_01
Command-line arguments: -os win32 -ws win32 -arch x86
and the complete stack trace:
!ENTRY org.eclipse.core.runtime 4 2 2005-02-03 10:57:29.464
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.ajdt.buildconfigurator.PropertyPageManager.regis terJDTPropertyPa
ge(PropertyPageManager.java:105)
org.eclipse.ajdt.buildconfigurator.BuildConfigurator.selecti onChanged(BuildC
onfigurator.java:93)
org.eclipse.ui.internal.AbstractSelectionService$3.run(Abstr actSelectionServ
ice.java:160)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelec
tionService.java:158)
org.eclipse.ui.internal.AbstractSelectionService$1.selection Changed(Abstract
SelectionService.java:66)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:163)
:1044)
org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:161)
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.
java:1667)
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.jav
a:935)
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer
..java:961)
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:209
org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.ja va:204)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:364)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2803)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2448)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
I've got some code that requires Java 5 so I'd like to stay on M4 but those
dialogs are getting really annoying.
Thanks ... WkH
Re: 3.1M4 ClassCastException [message #47395 is a reply to message #47364] Fri, 04 February 2005 05:12 Go to previous message
> just access a file. In the log the error is always the same:
> at
> those dialogs are getting really annoying.
I think you're using a version of AJDT (1.1.12 perhaps?) which is not
supported on Eclipse 3.1M4. Fortunately there is a version available for
this Eclipse build, although it is a development build. It is available
via the AJDT download page:
http://www.eclipse.org/ajdt/download.html
Look for the 1.2.0.DEVELOPMENT builds section, the current one is
1.2.0.20050202134544. Note there are two of these builds, one for Eclipse
3.0 and one for 3.1M4, so please make sure you get the right one.
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: 3.1M4 ClassCastException [message #586420 is a reply to message #47364] Fri, 04 February 2005 05:12 Go to previous message
> at
Matt.
Matt Chapman
Previous Topic:3.1M4 ClassCastException
Next Topic:Open Editor for IProgramElement
Current Time: Mon Jul 21 21:30:44 EDT 2025
Powered by FUDForum. Page generated in 0.03344 seconds
