Schema standard types [message #47351] |
Tue, 08 June 2004 02:04  |
Originally posted by: invalid.soft-gems.net
Hi Ed,
I tried to get all types in a schema using schema.eAllContents() but found
that default types (e.g. xs:integer) are not included in this collection.
I thought eAllContents would return anything in a schema, but it seems I
need something different for this. Can you help please?
Mike
www.soft-gems.net
Re: Schema standard types [message #47475 is a reply to message #47415] |
Tue, 08 June 2004 07:20  |
--------------6EB3CED71C7AC3C390907CC6
Content-Type: text/plain; charset=us-ascii
Mike,
No, it's defined like this:
<xs:simpleType name="boolean" id="boolean">
<xs:annotation>
<xs:appinfo>
<hfp:hasFacet name="pattern"/>
<hfp:hasFacet name="whiteSpace"/>
<hfp:hasProperty name="ordered" value="false"/>
<hfp:hasProperty name="bounded" value="false"/>
<hfp:hasProperty name="cardinality" value="finite"/>
<hfp:hasProperty name="numeric" value="false"/>
</xs:appinfo>
<xs:documentation
source="http://www.w3.org/TR/xmlschema-2/#boolean"/>
</xs:annotation>
<xs:restriction base="xs:anySimpleType">
<xs:whiteSpace value="collapse" fixed="true"
id="boolean.whiteSpace"/>
</xs:restriction>
</xs:simpleType>
An enumeration would have to be a restriction of some type that already
included the values...
Mike Lischke wrote:
> Ed Merks wrote:
> > xsdSchema.getSchemaForSchema().getTypeDefinitions will get the type
> > definitions defined by the schema for schemas. The method
> > xsdSchema.getSimpleTypeIdMap() applied to the schema for schema will give
> > precisely the built-in simple types.
> Excellent Ed, thank you. Works like a charm.
> Btw: I expected to get an enumeration facet for xs:boolean but there is
> none. Isn't this type defined as the list of values "true", "false", "0"
> and "1"?
> Mike
> www.soft-gems.net
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mike,
<p>No, it's defined like this:
<blockquote><xs:simpleType name="boolean" id="boolean">
<br> <xs:annotation>
<br> <xs:appinfo>
<br> <hfp:hasFacet name="pattern"/>
<br> <hfp:hasFacet name="whiteSpace"/>
<br> <hfp:hasProperty name="ordered" value="false"/>
<br> <hfp:hasProperty name="bounded" value="false"/>
<br> <hfp:hasProperty name="cardinality"
value="finite"/>
<br> <hfp:hasProperty name="numeric" value="false"/>
<br> </xs:appinfo>
<br> <xs:documentation
<br> source="<A HREF="http://www.w3.org/TR/xmlschema-2/#boolean"/">http://www.w3.org/TR/xmlschema-2/#boolean"/</A>>
<br> </xs:annotation>
<br> <xs:restriction base="xs:anySimpleType">
<br> <xs:whiteSpace value="collapse" fixed="true"
<br> id="boolean.whiteSpace"/>
<br> </xs:restriction>
<br></xs:simpleType></blockquote>
<br>
<p>Mike Lischke wrote:
<blockquote TYPE=CITE>Ed Merks wrote:
<p>> xsdSchema.getSchemaForSchema().getTypeDefinitions will get the type
<br>> definitions defined by the schema for schemas. The method
<br>> xsdSchema.getSimpleTypeIdMap() applied to the schema for schema will
give
<br>> precisely the built-in simple types.
<p>Excellent Ed, thank you. Works like a charm.
<p>Btw: I expected to get an enumeration facet for xs:boolean but there
is
<br>none. Isn't this type defined as the list of values "true", "false",
"0"
<br>and "1"?
<p>Mike
<br>--
<br>www.soft-gems.net</blockquote>
</html>
--------------6EB3CED71C7AC3C390907CC6--
Re: Schema standard types [message #588232 is a reply to message #47351] |
Tue, 08 June 2004 06:39  |
Mike,
The eAllContents method walks the containment tree of an object, so it will
return everything physically contained under the object. The
XSDSchema.getTypeDefinitions() returns all the types defined by a schema and
all those imported or included into the schema. It will not contain the
built-in schema types either, because they are not imported nor included, they
are simply ubiquitous and available everywhere without import. Using
Mike Lischke wrote:
> Hi Ed,
> Mike
> www.soft-gems.net
Re: Schema standard types [message #588243 is a reply to message #47381] |
Tue, 08 June 2004 06:52  |
and "1"?
Mike
www.soft-gems.net
Re: Schema standard types [message #588261 is a reply to message #47415] |
Mike,
<xs:annotation>
<xs:appinfo>
</xs:appinfo>
<xs:documentation
</xs:annotation>
</xs:restriction>
</xs:simpleType>
> and "1"?
> Mike
> www.soft-gems.net
<html>
Mike,
<br> <xs:appinfo>
value="finite"/>
<br> </xs:appinfo>
<br>
give
is
"0"
<br>and "1"?
<p>Mike
<br>--
</html>
FUDForum. Page generated in 0.03555 seconds
