Live mode constraint not working correctly [message #47330] |
Tue, 29 August 2006 03:12  |
I have two questions:
1)AFAIU, the difference between constraints under Node/Link Mapping
element and constraints in Audit Container is that the former controls
whether a node/link can be created, and the latter checks whether the
existing model is semantically correct?
2)I created a simple constraint(checks whether name's length is greater
than 2) in Audit Container, it works fine in batch mode, but when I
switched it to live mode, there seems to be some problem. For example, I
can get warning decorator when I enter name in properties view, but can
not get it by direct editing. I wonder that in live mode, for which
situations would the constraint be checked?
FUDForum. Page generated in 0.42297 seconds
