Home » Archived » M2M (model-to-model transformation) » [ATL] Reference in the metamodel
Re: [ATL] Reference in the metamodel [message #48355 is a reply to message #47831] |
Fri, 22 June 2007 04:32   |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Benjamin,
Benjamin CHEVALLEREAU a écrit :
> I have a new problem. I have a rule like that :
> rule R {
> from e : IN!Element
> to
> newElt : OUT!Element foreach(...) (
> myAttr <- newSubElt
> newSubElt : OUT!Element (...)
> I want that each new element contains a new sub element but with this
> rule (it's normal), I have an only sub element linked with the last
> element. How can I create a sub element foreach element ?
You can use a "lazy rule" instead of using the "foreach" statement for
this kind of purpose.
A lazy rule is a declarative rule which have to be explicitly called
from another rule. For instance, in your case you can do something like
this:
- Declare R as a lazy rule
lazy rule R {
from e : IN!Element
to
newElt : OUT!Element (
myAttr <- newSubElt
- Call it from another rule
rule S {
from
e : IN!Element
to
elements <- e.elements->collect(elem | thisModule.R(elem))
Hugo
> Thanks
>> I search to transform my metamodel to the metamodel UML2. I must
>> construct a profile with all stereotypes but in this profile I must
>> reference the class http://www.eclipse.org/uml2/2.0.0/UML#//Element
>> and i don't know how to do that ?
>> Thanks
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Reference in the metamodel [message #48445 is a reply to message #48355] |
Fri, 22 June 2007 09:45   |
Originally posted by: bch.openbluelab.org
Thanks for your help !!
I have finded a solution with lazy rule. Now, I have a new problem. I
want to link a property with an external class but I don't know how to
do that. I want create a profile UML2. In UML2, we can find :
<elementImport xmi:id="_WfN3kCDAEdyNsvUu_WiziQ">
<importedElement xmi:type="uml:Class"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Element"/>
</elementImport>
So I want to reference a class in an other metamodel but I don't know how...
Best regards
Hugo Bruneliere a écrit :
> Hi Benjamin,
>> rule R {
>> from e : IN!Element
>> to
>> myAttr <- newSubElt
> this:
> lazy rule R {
> from e : IN!Element
> to
> myAttr <- newSubElt
> rule S {
> from
> e : IN!Element
> to
> Best regards,
> Hugo
>> Thanks
>>> Hi,
>>> Thanks
Re: [ATL] Reference in the metamodel [message #49413 is a reply to message #48445] |
Tue, 26 June 2007 11:04   |
Have you an idea to reference the class
//UML_METAMODELS/UML.metamodel.uml#Element ?
> </elementImport>
> how...
> Best regards
>> Hi Benjamin,
>>> Hi,
>>> rule R {
>>> from e : IN!Element
>>> to
>>> myAttr <- newSubElt
>> like this:
>> lazy rule R {
>> from e : IN!Element
>> to
>> myAttr <- newSubElt
>> rule S {
>> from
>> e : IN!Element
>> to
>> Best regards,
>> Hugo
>>> Thanks
>>>> Hi,
>>>> Thanks
Re: [ATL] Reference in the metamodel [message #49472 is a reply to message #49413] |
Tue, 26 June 2007 11:50   |
I must admit that I am not sure to understand what you mean.
Why don't you use: "http://www.eclipse.org/uml2/2.0.0/UML#//Element", as
you wrote in your original post?
Frédéric Jouault
> Thanks
>> </elementImport>
>> how...
>> Best regards
>>> Hi Benjamin,
>>>> Hi,
>>>> rule R {
>>>> from e : IN!Element
>>>> to
>>>> myAttr <- newSubElt
>>>> this rule (it's normal), I have an only sub element linked with the
>>>> last element. How can I create a sub element foreach element ?
>>> for this kind of purpose.
>>> like this:
>>> lazy rule R {
>>> from e : IN!Element
>>> to
>>> myAttr <- newSubElt
>>> rule S {
>>> from
>>> e : IN!Element
>>> to
>>> Best regards,
>>> Hugo
>>>> Thanks
>>>>> Hi,
>>>>> Thanks
Re: [ATL] Reference in the metamodel [message #49562 is a reply to message #49472] |
Wed, 27 June 2007 03:20   |
I have a property "importedElement" that I must assign to
"http://www.eclipse.org/uml2/2.0.0/UML#//Element". But I can't write this :
importedElement <- 'http://www.eclipse.org/uml2/2.0.0/UML#//Element'
--> message: cannot set feature UML2P!ElementImport.importedElement to
value http://www.eclipse.org/uml2/2.0.0/UML#//Element
exception:
java.lang.ClassCastException: java.lang.String
So I don't know how to do that.
Frédéric Jouault a écrit :
> Hello,
> Frédéric Jouault
>> Thanks
>>> to do that. I want create a profile UML2. In UML2, we can find :
>>> </elementImport>
>>> how...
>>> Best regards
>>>> Hi Benjamin,
>>>>> Hi,
>>>>> rule R {
>>>>> from e : IN!Element
>>>>> to
>>>>> myAttr <- newSubElt
>>>> like this:
>>>> lazy rule R {
>>>> from e : IN!Element
>>>> to
>>>> myAttr <- newSubElt
>>>> rule S {
>>>> from
>>>> e : IN!Element
>>>> to
>>>> Best regards,
>>>> Hugo
>>>>> Thanks
>>>>>> Hi,
>>>>>> must reference the class
>>>>>> http://www.eclipse.org/uml2/2.0.0/UML#//Element and i don't know
>>>>>> how to do that ?
>>>>>> Thanks
Re: [ATL] Reference in the metamodel [message #49592 is a reply to message #49562] |
Wed, 27 June 2007 04:17   |
Ok, now I understand your problem a bit better, thanks ;-).
What about:
importedElement <- UML!Element
(assuming you "loaded" the UML2 "metamodel" by URI and named it "UML")
Frédéric Jouault
> to value http://www.eclipse.org/uml2/2.0.0/UML#//Element
> exception:
> Thanks
>> Hello,
>> as you wrote in your original post?
>> Regards,
>> Frédéric Jouault
>>> Thanks
>>>> I want to link a property with an external class but I don't know
>>>> how to do that. I want create a profile UML2. In UML2, we can find :
>>>> </elementImport>
>>>> know how...
>>>> Best regards
>>>>> Hi Benjamin,
>>>>>> Hi,
>>>>>> rule R {
>>>>>> from e : IN!Element
>>>>>> to
>>>>>> myAttr <- newSubElt
>>>>>> the last element. How can I create a sub element foreach element ?
>>>>> called from another rule. For instance, in your case you can do
>>>>> something like this:
>>>>> lazy rule R {
>>>>> from e : IN!Element
>>>>> to
>>>>> myAttr <- newSubElt
>>>>> rule S {
>>>>> from
>>>>> e : IN!Element
>>>>> to
>>>>> Best regards,
>>>>> Hugo
>>>>>> Thanks
>>>>>>> Hi,
>>>>>>> how to do that ?
>>>>>>> Thanks
Re: [ATL] Reference in the metamodel [message #49622 is a reply to message #49592] |
Wed, 27 June 2007 08:53   |
I have tried this :
importedElement <- UML2!Element
but I have no code in my file.
Do you know why ?
> Hello,
> What about:
> Frédéric Jouault
>> this :
>> exception:
>> Thanks
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>>> Thanks
>>>>> </elementImport>
>>>>> know how...
>>>>> Best regards
>>>>>> Hi Benjamin,
>>>>>>> Hi,
>>>>>>> rule R {
>>>>>>> from e : IN!Element
>>>>>>> to
>>>>>>> myAttr <- newSubElt
>>>>>> lazy rule R {
>>>>>> from e : IN!Element
>>>>>> to
>>>>>> myAttr <- newSubElt
>>>>>> rule S {
>>>>>> from
>>>>>> e : IN!Element
>>>>>> to
>>>>>> thisModule.R(elem))
>>>>>> Best regards,
>>>>>> Hugo
>>>>>>> Thanks
>>>>>>>> Hi,
>>>>>>>> how to do that ?
>>>>>>>> Thanks
Re: [ATL] Reference in the metamodel [message #49653 is a reply to message #49622] |
Wed, 27 June 2007 10:00   |
Do you allow inter-model references?
Frédéric Jouault
> Hello,
> I have tried this :
> Do you know why ?
> Thanks
>> Hello,
>> What about:
>> Regards,
>> Frédéric Jouault
>>> this :
>>> UML2P!ElementImport.importedElement to value
>>> exception:
>>> Thanks
>>>> Hello,
>>>> Why don't you use:
>>>> "http://www.eclipse.org/uml2/2.0.0/UML#//Element", as you wrote in
>>>> your original post?
>>>> Regards,
>>>> Frédéric Jouault
>>>>> Thanks
>>>>>> problem. I want to link a property with an external class but I
>>>>>> don't know how to do that. I want create a profile UML2. In UML2,
>>>>>> we can find :
>>>>>> </elementImport>
>>>>>> know how...
>>>>>> Best regards
>>>>>>> Hi Benjamin,
>>>>>>>> Hi,
>>>>>>>> rule R {
>>>>>>>> from e : IN!Element
>>>>>>>> to
>>>>>>>> myAttr <- newSubElt
>>>>>>> statement for this kind of purpose.
>>>>>>> lazy rule R {
>>>>>>> from e : IN!Element
>>>>>>> to
>>>>>>> myAttr <- newSubElt
>>>>>>> rule S {
>>>>>>> from
>>>>>>> e : IN!Element
>>>>>>> to
>>>>>>> thisModule.R(elem))
>>>>>>> Best regards,
>>>>>>> Hugo
>>>>>>>> Thanks
>>>>>>>>> Hi,
>>>>>>>>> must construct a profile with all stereotypes but in this
>>>>>>>>> profile I must reference the class
>>>>>>>>> Thanks
Re: [ATL] Reference in the metamodel [message #50210 is a reply to message #49653] |
Mon, 02 July 2007 03:14   |
How to allow that ?
> Hello,
> Frédéric Jouault
>> Hello,
>> I have tried this :
>> Do you know why ?
>> Thanks
>>> Hello,
>>> What about:
>>> Regards,
>>> Frédéric Jouault
>>>> this :
>>>> exception:
>>>> Thanks
>>>>> Hello,
>>>>> Why don't you use:
>>>>> your original post?
>>>>> Regards,
>>>>> Frédéric Jouault
>>>>>> Thanks
>>>>>>> we can find :
>>>>>>> </elementImport>
>>>>>>> know how...
>>>>>>> Best regards
>>>>>>>> Hi Benjamin,
>>>>>>>>> Hi,
>>>>>>>>> rule R {
>>>>>>>>> from e : IN!Element
>>>>>>>>> to
>>>>>>>>> myAttr <- newSubElt
>>>>>>>>> with this rule (it's normal), I have an only sub element linked
>>>>>>>>> with the last element. How can I create a sub element foreach
>>>>>>>>> element ?
>>>>>>>> lazy rule R {
>>>>>>>> from e : IN!Element
>>>>>>>> to
>>>>>>>> myAttr <- newSubElt
>>>>>>>> rule S {
>>>>>>>> from
>>>>>>>> e : IN!Element
>>>>>>>> to
>>>>>>>> thisModule.R(elem))
>>>>>>>> Best regards,
>>>>>>>> Hugo
>>>>>>>>> Thanks
>>>>>>>>>> Hi,
>>>>>>>>>> Thanks
Re: [ATL] Reference in the metamodel [message #50656 is a reply to message #50210] |
Wed, 04 July 2007 04:46  |
There is a checkbox in the launch config to "allow inter-model
references". In the latest version of ATL, this checkbox is in the
"advanced" tab.
Frédéric Jouault
> How to allow that ?
> Thanks
>> Hello,
>> Regards,
>> Frédéric Jouault
>>> Hello,
>>> I have tried this :
>>> Do you know why ?
>>> Thanks
>>>> Hello,
>>>> What about:
>>>> Regards,
>>>> Frédéric Jouault
>>>>> write this :
>>>>> exception:
>>>>> Thanks
>>>>>> Hello,
>>>>>> Why don't you use:
>>>>>> your original post?
>>>>>> Regards,
>>>>>> Frédéric Jouault
>>>>>>> Thanks
>>>>>>>> UML2, we can find :
>>>>>>>> </elementImport>
>>>>>>>> know how...
>>>>>>>> Best regards
>>>>>>>>> Hi Benjamin,
>>>>>>>>>> Hi,
>>>>>>>>>> rule R {
>>>>>>>>>> from e : IN!Element
>>>>>>>>>> to
>>>>>>>>>> myAttr <- newSubElt
>>>>>>>>>> linked with the last element. How can I create a sub element
>>>>>>>>>> foreach element ?
>>>>>>>>> lazy rule R {
>>>>>>>>> from e : IN!Element
>>>>>>>>> to
>>>>>>>>> myAttr <- newSubElt
>>>>>>>>> rule S {
>>>>>>>>> from
>>>>>>>>> e : IN!Element
>>>>>>>>> to
>>>>>>>>> thisModule.R(elem))
>>>>>>>>> Best regards,
>>>>>>>>> Hugo
>>>>>>>>>> Thanks
>>>>>>>>>>> Hi,
>>>>>>>>>>> Thanks
Current Time: Sat Jul 12 02:17:59 EDT 2025
Powered by FUDForum. Page generated in 0.05936 seconds
