Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and JDBC
RAP and JDBC [message #47220] |
Mon, 17 September 2007 09:50  |
Originally posted by: abo.splitshade.de
I wonder how i would best use JDBC together with RAP.
Should I implement the JDBC-Driver as a separate Bundle
which is shared among Users?
Or what would be the best practice for this?
Sincerely
Martin
RAP M6 [message #47610 is a reply to message #47583] |
Tue, 18 September 2007 12:03   |
Originally posted by: blaumilch.gmx.ch
I tried to update my RAP Environment by copying the new M6-Jars into
my plugin folder, but regrettebly eclipse is crashing since then...
Then I copied the files one after another and it comes out that this is
the bad guy:
org.eclipse.rap.ui_1.0.0.20070817-1525.jar
perhaps I misunderstood the principles of updating eclipse-plugins, but
the rap-update-site only provides M1... so I do it manually.
I would be thankful for any idea !!!
so long
Johannes
this is the log-file from my rap-workspace:
!ENTRY org.eclipse.osgi 4 0 2007-09-18 17:55:00.870
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
org.eclipse.wst.server.core.internal.ResourceManager.isActiv eBundle(ResourceManager.java:319)
org.eclipse.wst.server.core.internal.ServerPlugin$1.bundleCh anged(ServerPlugin.java:272)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1210)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
!ENTRY org.eclipse.wst.server.core 4 0 2007-09-18 17:55:01.090
!MESSAGE
!STACK 0
!SESSION 2007-09-18 17:55:09.542
eclipse.buildId=I20070625-1500
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.678
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.678
!MESSAGE Conflict for 'org.eclipse.ui.file.closePart':
HandlerActivation(commandId=org.eclipse.ui.file.closePart,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler,
expression=,sourcePriority=0)
handler=org.eclipse.ui.internal.handlers.ClosePartHandler@1b8119a,
!MESSAGE Conflict for 'org.eclipse.ui.views.showView':
HandlerActivation(commandId=org.eclipse.ui.views.showView,
handler=org.eclipse.ui.handlers.ShowViewHandler@6147d9,
handler=org.eclipse.ui.handlers.ShowViewHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.718
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.718
!MESSAGE Conflict for 'org.eclipse.ui.file.close':
HandlerActivation(commandId=org.eclipse.ui.file.close,
handler=org.eclipse.ui.internal.CloseEditorHandler,
!MESSAGE Conflict for 'org.eclipse.ui.file.closeAll':
HandlerActivation(commandId=org.eclipse.ui.file.closeAll,
handler=org.eclipse.ui.internal.CloseAllHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.728
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.728
!MESSAGE Conflict for 'org.eclipse.ui.file.closeOthers':
HandlerActivation(commandId=org.eclipse.ui.file.closeOthers,
handler=org.eclipse.ui.internal.CloseOthersHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextEditor':
HandlerActivation(commandId=org.eclipse.ui.window.nextEditor ,
handler=org.eclipse.ui.internal.CycleEditorHandler:true,
!MESSAGE Conflict for 'org.eclipse.ui.window.previousEditor':
HandlerActivation(commandId=org.eclipse.ui.window.previousEd itor,
handler=org.eclipse.ui.internal.CycleEditorHandler:false,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextView':
HandlerActivation(commandId=org.eclipse.ui.window.nextView,
handler=org.eclipse.ui.internal.CycleViewHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.738
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2007-09-18 17:55:20.738
!MESSAGE Conflict for 'org.eclipse.ui.window.previousView':
HandlerActivation(commandId=org.eclipse.ui.window.previousVi ew,
handler=org.eclipse.ui.internal.CycleViewHandler:false,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.nextPerspe ctive,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:true ,
!MESSAGE Conflict for 'org.eclipse.ui.window.previousPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.previousPe rspective,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:fals e,
!ENTRY org.eclipse.ui.workbench 4 2 2007-09-18 17:55:21.960
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NullPointerException: You cannot parameterize a null parameter
org.eclipse.core.commands.Parameterization.<init>(Parameterization.java:76)
at org.eclipse.ui.internal.ShowViewMenu.getCommand(ShowViewMenu .java:300)
at org.eclipse.ui.internal.ShowViewMenu.<init>(ShowViewMenu.java:123)
at org.eclipse.ui.internal.FastViewBar.<init>(FastViewBar.java:209)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:1062)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:624)
org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:268)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:974)
at org.eclipse.jface.window.Window.create(Window.java:426)
org.eclipse.ui.internal.Workbench$59.runWithException(Workbe nch.java:3319)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:797)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: RAP M6 [message #47703 is a reply to message #47610] |
Tue, 18 September 2007 16:23   |
Originally posted by: rherrmann.innoopract.com
Hi Johannes,
the target platform downloads provided since M4 are *not* meant to be
installed into your Eclipse installation for exactly the reason you just
experienced. Sorry for that:(
Please follow the procedure described on the downloads page:
http://www.eclipse.org/rap/downloads.php
Rüdiger
Johannes Schmidt wrote:
> I tried to update my RAP Environment by copying the new M6-Jars into my
> the bad guy:
> so long
> Johannes
> !STACK 0
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: RAP and JDBC [message #48293 is a reply to message #47583] |
Wed, 19 September 2007 13:33   |
Why I asked is, I have the JDBC-Driver in an external Plugin,
in my base plugin, I have defined an extension Point, so that I am able
to contribute JDBC Drivers on the fly.
This can be important because I must support a wide range of Databases.
So, I load the Driver , using "createExecutableExtension",
and I do get an INstance of JDBCDriver.
But I am not able to get a Connection, instead I get a "no suitable
Driver found"-SQL-Exception. If I try the same thing with the driver
in the Classpath of my Plugin, this works so fine.
Is there a classloading-issue I am not aware of?
Or what?s the problem here?
Re: RAP and JDBC [message #48572 is a reply to message #48492] |
Thu, 20 September 2007 08:55  |
finally it works, its not an issue for RAP, but rather as I supposed a
Classloading issue.
Thank you anyway
Greetings
Martin
Current Time: Thu Jul 31 01:11:42 EDT 2025
Powered by FUDForum. Page generated in 0.03609 seconds
