Home » Eclipse Projects » Plugin Development Environment (PDE) » Create a filter rule in New Project Wizard
Create a filter rule in New Project Wizard [message #47188] Mon, 16 February 2009 15:08
I want to create a plugin which contains a wizard. This wizard is
simmilar with the "New Java Project Wizard". By default I want to create
some folders in a source folder. I create these folders, but in the
resulting project structure these folders are shown as packages. I know
that one can create an exclusion pattern in project properties.
But I don't know how can I accomplish this from code. Maybe setting some
"folder nature".
I will be glad to see that there is a solution to my problems.
Thank you in advance
Previous Topic:When is a plugin Editable?
Next Topic:Create a filter rule in New Project Wizard
Current Time: Fri Jul 04 10:02:31 EDT 2025
Powered by FUDForum. Page generated in 0.31247 seconds
