Home » Modeling » M2T (model-to-text transformation) » Generating OCL from Model
Generating OCL from Model [message #47189] Thu, 19 June 2008 14:56 Go to next message
Hi all,
I wonder if someone can help me. I want to create a DSL defined using an
ECore metamodel. This DSL will generate OCL. I have defined the metamodel
in ECore, but I am unsure how to generate the OCL now. Will M2T allow for
this? When will it be released? Can JET generate non-java text?
Any help would be much appriciated.
Mark
Re: Generating OCL from Model [message #47242 is a reply to message #47189] Fri, 20 June 2008 06:21 Go to previous messageGo to next message
Mark Melia wrote:
> Hi all,
> metamodel in ECore, but I am unsure how to generate the OCL now. Will
> M2T allow for this? When will it be released? Can JET generate non-java
> text?
Can generate any text you want.
Here is how you run a JET transform on an ecore document:
http://help.eclipse.org/help33/topic/org.eclipse.jet.doc/tas ks/usingJetWithEMF.xhtml
The wiki is also helpful:
http://wiki.eclipse.org/M2T-JET
Problem Loading Ecore Model [message #47404 is a reply to message #47242] Mon, 30 June 2008 18:06 Go to previous message
Originally posted by: uneebtariq.gmail.com
Felix Dorner wrote:
> Mark Melia wrote:
>> Hi all,
>> text?
Hey Hi
I am working with mark on this project and have neva Used JET before. I
am having a couple of problems using JET.
1. How to load ecore model as an input? What should be the
extension(myecore.?)
2. Plz can someone give me a simple example of loading ecore in JET and
transforming it into code.
waiting for ur response
Uneeb Janjua
Previous Topic:JET <ws:project...> effect
Next Topic:Problem loading ecore model as input in JET
Current Time: Mon Sep 01 02:42:42 EDT 2025
Powered by FUDForum. Page generated in 0.06066 seconds
