Home » Language IDEs » Java Development Tools (JDT) » Closing bracket
Closing bracket [message #47154] Tue, 03 June 2003 05:22 Go to next message
Originally posted by: stelian.iancu.gmx.net
Hello!
I am using the latest integration Build (20030528) and, suddenly, Eclipse
doesn't automatically close my opening brackets. This is very annoying,
given that I've got used with it closing those brackets. Is there a setting
somewhere to turn this on?
Stelian Iancu
Linux Registered User 287835
Be different. Think.
Re: Closing bracket [message #47231 is a reply to message #47154] Tue, 03 June 2003 08:29 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
Automatic brace closing has been changed - the brace will only be closed
when you hit Return after the brace and actually are entering a new block.
-tom
"Stelian Iancu" <stelian.iancu@gmx.net> wrote in message
news:oprp6pnmhx9svh55@news.gmx.net...
> Hello!
setting
> Stelian Iancu
Re: Closing bracket [message #48112 is a reply to message #47231] Wed, 04 June 2003 00:50 Go to previous messageGo to next message
> -tom
I've tried the latest nightly build too, and this is what happens.
I think I'd prefer having it automatically closed, at least it would be
consistent.
rgds
x
Re: Closing bracket [message #48238 is a reply to message #48112] Wed, 04 June 2003 01:22 Go to previous messageGo to next message
> consistent.
+1
SY, Konstantin.
Re: Closing bracket [message #48330 is a reply to message #48112] Wed, 04 June 2003 02:47 Go to previous messageGo to next message
> consistent.
consistent with?
NB:
The reason for this change was the trouble when someone puts a block on one
line, like so:
if (condition) { return; }
which you cannot detect from the context.
Plus, initializing arrays is better, although this can be inferred from what
a user types
Object[] arr= new Object[] { null, null };
Re: Closing bracket [message #49155 is a reply to message #48238] Wed, 04 June 2003 16:35 Go to previous messageGo to next message
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in
news:dAVN7klKDHA.3608@fairy.ao.nlmk:
>>> closed when you hit Return after the brace and actually are entering
>>> a new block.
>> be consistent.
> +1
-1; I like the new way better.
Matt King
Re: Closing bracket [message #50855 is a reply to message #48330] Thu, 05 June 2003 00:54 Go to previous messageGo to next message
Tom Eicher wrote:
A problem appears when I try to use an anonymous inner class (for event
handling, for example). Let's take, for example:
mTable.addMouseListener(new MouseAdapter())
Now, I want to open the brace. So it should look like this:
mTable.addMouseListener(new MouseAdapter(){)
but instead, it looks like this:
mTable.addMouseListener(new MouseAdapter()){
So I have to delete the last brace:
and then:
mTable.addMouseListener(new MouseAdapter() {
So my point is that, for this situation, the old behavior is better.
Stelian Iancu
Linux registered user 287835
Re: Closing bracket [message #51194 is a reply to message #50855] Fri, 06 June 2003 02:52 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
This seems like a bug, not a valid changed behavior.
Bob
news:j0v2r-k82.ln1@paradise.bmfms.ro...
> and then:
> Stelian Iancu
Re: Closing bracket [message #51323 is a reply to message #50855] Fri, 06 June 2003 03:51 Go to previous messageGo to next message
I've had this situation myself - not really what's intended... There will
probably be some touch up, but it might not be first priority... Can you
enter (another!) bug report on jdt text for smart brace?
Note that for a quick workaround in the newest release, you can press
"Insert" to toggle the input mode from "Smart Insert" to "Insert" which will
disable any (not so) smart behaviour.
-tom
Re: Closing bracket [message #51432 is a reply to message #51323] Fri, 06 June 2003 05:20 Go to previous message
On Fri, 6 Jun 2003 09:51:42 +0200, Tom Eicher <tom.eicher@gmx.ch.nodomain>
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=38565
> will
> -tom
Stelian Iancu
Previous Topic:external jar
Next Topic:Debugger seems to be very slow
Current Time: Fri Jul 04 20:45:53 EDT 2025
Powered by FUDForum. Page generated in 0.04134 seconds
