Home » Language IDEs » C / C++ IDE (CDT) » Breakpoint Locations
Breakpoint Locations [message #47152] Thu, 24 October 2002 10:29 Go to next message
Originally posted by: ijmuiden.pointbreak.biz
Just noticed that if you edit a file with breakpoints in it, the breakpoints
appear to stick with their source code (i.e. a breakpoint marker on the
fourth line will move to the sixth, if two lines are added before the fourth
line). However, the breakpoint locations (line numbers) are not updated.
Effectively, when you start debugging the breakpoint (and the marker) will
be on the fourth instead of the sixth line.
Should I make this a feature request, and if so, does anybody know if this
is CDT specific, or also the case for Java debugging.
Gerjon
Re: Breakpoint Locations [message #47296 is a reply to message #47152] Thu, 24 October 2002 11:33 Go to previous message
Originally posted by: johan.nosp.m.appeal.se
File a bug report. Post the number here (I'm interested in how it goes).
Cheers //Johan
> Cheers,
> Gerjon
Previous Topic:Debugger Timeout
Next Topic:Code Assist, again :-)
Current Time: Sun Aug 31 05:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.04759 seconds
