BIRT and RCP Integration [message #465401] |
Wed, 28 March 2007 20:08 |
Originally posted by: zlzevplibgzfq.mailinator.com
I am trying to integrate the BIRT Report Engine into my RCP. I need to use the ScriptedDataSource in order to generate my reports. I started off with a very simple case of creating a report that generates a report listing the property names and values from System.getProperties(). This works fine both from eclipse and from my own RCP. As a next step I used the same rptdesign doc and I wrote a very simple properties class of my own called SimpleProperties.java:
package birttest;
import java.util.Properties;
public class SimpleProperties {
public static Properties getProperties() {
Properties props = new Properties();
props.put("First Key", "First Value");
props.put("Second Key", "Second Value");
props.put("Third Key", "Third Value");
props.put("Fourth Key", "Fourth Value");
return props;
I then changed the contents of my Scripted rptdesign file to the following:
open:
props = Packages.birttest.SimpleProperties.getProperties();
propIter = props.entrySet().iterator();
fetch:
if(!propIter.hasNext())
return false;
entry = propIter.next();
row['columnKey'] = entry.getKey();
row['columnValue'] = entry.getValue();
return true;
When I click the Preview tab on the rptdesign, the report shows up as expected. I can also use the View Report button to view it as HTML and PDF with no problems. Unfortunately, when I launch my RCP and click a button to generate a report, I get the following error:
Mar 28, 2007 4:04:21 PM org.eclipse.birt.report.model.metadata.StructPropertyType validateValue
WARNING: The value of the structure is null
Mar 28, 2007 4:04:24 PM org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor handleJS
WARNING: A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: TypeError: getProperties is not a function. (DataSet[Data Set].__bm_OPEN#4)
Script source: DataSet[Data Set].__bm_OPEN, line: 1, text:
__bm_OPEN(). See next exception for more information.
__bm_OPEN()
org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: TypeError: getProperties is not a function. (DataSet[Data Set].__bm_OPEN#4)
__bm_OPEN()
at org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:118)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:552)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:79)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)
at org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:159)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:6 6)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:68)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:234)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :210)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:743)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:183)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:148)
at org.eclipse.birt.report.engine.data.dte.DteResultSet.<init>(DteResultSet.java:85)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:130)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:210)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1641)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:62)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:73)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:123)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:81)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:85)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:143)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:241)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:116)
at birttest.ReportGenerator.executeReport(ReportGenerator.java: 43)
at birttest.View$1.widgetSelected(View.java:38)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1496)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1520)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1505)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3312)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2941)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at birttest.Application.run(Application.java:18)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: TypeError: getProperties is not a function. (DataSet[Data Set].__bm_OPEN#4)
__bm_OPEN()
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoExc eption(JavascriptEvalUtil.java:281)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:105)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:137)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:548)
... 50 more
Caused by: org.mozilla.javascript.EcmaError: TypeError: getProperties is not a function. (DataSet[Data Set].__bm_OPEN#4)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
at org.mozilla.javascript.ScriptRuntime.typeError1(ScriptRuntim e.java:3258)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(Script Runtime.java:3317)
at org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis( ScriptRuntime.java:1987)
at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRun time.java:114)
at org.mozilla.javascript.gen.c4._c1(DataSet[Data Set].__bm_OPEN:4)
at org.mozilla.javascript.gen.c4.call(DataSet[Data Set].__bm_OPEN)
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:105)
at org.mozilla.javascript.gen.c5._c0(DataSet[Data Set].__bm_OPEN:1)
at org.mozilla.javascript.gen.c5.call(DataSet[Data Set].__bm_OPEN)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c5.exec(DataSet[Data Set].__bm_OPEN)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:98)
... 52 more
WARNING: A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: ReferenceError: "propIter" is not defined. (DataSet[Data Set].__bm_FETCH#2)
Script source: DataSet[Data Set].__bm_FETCH, line: 1, text:
__bm_FETCH(). See next exception for more information.
__bm_FETCH()
org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: ReferenceError: "propIter" is not defined. (DataSet[Data Set].__bm_FETCH#2)
__bm_FETCH()
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 100)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRuntime.java:84)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:247)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:148)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:91)
at org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(ExpandableRowResultSet.java:62)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:275)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:250)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:213)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:66)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:111)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:66)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doSinglePass(PassManager.java:123)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:83)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:65)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:210)
at org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:124)
at org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.java:106)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :213)
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "propIter" is not defined. (DataSet[Data Set].__bm_FETCH#2)
__bm_FETCH()
... 65 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "propIter" is not defined. (DataSet[Data Set].__bm_FETCH#2)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3303)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1632)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1571)
at org.mozilla.javascript.gen.c6._c1(DataSet[Data Set].__bm_FETCH:2)
at org.mozilla.javascript.gen.c6.call(DataSet[Data Set].__bm_FETCH)
at org.mozilla.javascript.gen.c7._c0(DataSet[Data Set].__bm_FETCH:1)
at org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_FETCH)
at org.mozilla.javascript.gen.c7.exec(DataSet[Data Set].__bm_FETCH)
... 67 more
Mar 28, 2007 4:04:24 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: data.engine.BadFetchScriptReturnType
org.eclipse.birt.data.engine.core.DataException: data.engine.BadFetchScriptReturnType
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 109)
To me this means that when Rhino is interpreting the script, it cannot find my SimpleProperties class, however the class file is located in my project's bin/birttest directory just as it's package name should be and it worked fine for previewing/exporting within eclipse. Does anyone have any ideas why I can't use my own custom class with BIRT?
FUDForum. Page generated in 0.02712 seconds
