eclipse 3.3 and Resource Navigator [message #465280] |
Wed, 28 March 2007 07:26 |
Originally posted by: fanny.boulaire.csiro.au
I have upgraded to Eclipse 3.3M5, to be able to use EMF and BIRT together within an RCP application that works fine in Eclipse 3.2.
My problem is that I cannot see any projects or files in my resource Navigator anymore.
The code previously used in the declareWorkbenchImages() method (similar to http://eclipsezone.com/forums/thread.jspa?messageID=91883079 �) isn't working anymore and I get the following error message:
Exception in thread "Thread-1" java.lang.NullPointerException
at org.eclipse.jface.resource.JFaceResources.getResources(JFace Resources.java:186)
at org.eclipse.jface.resource.ImageRegistry.<init>(ImageRegistry.java:151)
at org.eclipse.jface.resource.ImageRegistry.<init>(ImageRegistry.java:123)
at org.eclipse.ui.internal.WorkbenchImages.initializeImageRegis try(WorkbenchImages.java:568)
at org.eclipse.ui.internal.WorkbenchImages.getDescriptors(Workb enchImages.java:469)
at org.eclipse.ui.internal.WorkbenchImages.declareImage(Workben chImages.java:456)
at org.eclipse.ui.internal.WorkbenchConfigurer.declareImage(Wor kbenchConfigurer.java:105)
Any help would be much appreciated.
Cheers
FUDForum. Page generated in 0.03820 seconds
