Missing images [message #47115] |
Mon, 28 January 2008 09:42  |
I'm facing quite curious issue rigth now, I don't know how to move on,
does it sound familiar to anyone?
My published configuration doesn't include some of images. I have checked
rights, all log files, I don't understand. Publishing finished without any
error.
I'm using command line interface; I used CruiseControl on windows to invoke
publishing and it worked fine; I have moved to linux and Jazz and now I face
the issue described above.
I would be very happy if any idea.
Roman
Re: Missing images [message #48652 is a reply to message #47115] |
Sat, 08 March 2008 19:57  |
Roman Smirak wrote:
> error.
> Roman
I had similar issues where some diagrams were publishing and some where
not - sometimes within the same capability pattern. Everything looked
great in browser mode, but some images did not pull through when published.
I determined that the file names were too long for the operating system
(XP). I found when I look in:
~/published_folder/"plug-in"/capabilitypatterns/resources
and verify that file names for all the images are recognized by the OS
this enabled all the images to be published. Depending on how
they are used, process file names get appended with things like:
"really_long_process_name_8CA0D7A6_62b8111a_Activity".
I renamed the culprit activities and capability patterns with shorter
names and all the images published.
David Hadley
Re: Missing images [message #586264 is a reply to message #47142] |
Tue, 29 January 2008 04:54  |
Hi Shilpa.
I mean icon images, static images, e.g.
openup\customcategories\resources\three_layers.jpg, screenshots included in
toolmentors, etc.
Can you point me to a class/component responsible for image/icon handling?
Roman
"Shilpa Toraskar" <storaskar@xx.xxx.xxx> wrote in message
news:49bc605a599b6279d11f56effc2f658f$1@www.eclipse.org...
> which images do you have issue with ? Diagram images or icon images ?
> Shilpa
Re: Missing images [message #586277 is a reply to message #47197] |
Tue, 29 January 2008 05:13  |
News: First I thought there might be an issue with rights or a name of the
images (*.gif vs *.GIF). However, I have published the config using GUI &
cmd line (outside building engine) and I get proper count of images. Which
probably means there is something wrong with the integration with Jazz
building; however, I don't know what and even how to investigate what...
Roman
"Roman Smirak" <roman.smirak@tietoenator.com> wrote in message
news:fnmt5j$eo3$1@build.eclipse.org...
> Hi Shilpa.
> in toolmentors, etc.
> Roman
>> Shilpa
Re: Missing images [message #586308 is a reply to message #47223] |
Tue, 29 January 2008 14:16  |
Looks like all images/icons are getting published and copied to correct
folder for you. I would start by taking a look source html on published
pages and see whether the path to images are correct or not, whether those
images exist or not.
If path is wrong or if image is missing then i can start going into EPF
source code to see.
Also, give it a try for Windows/Jazz & Linux/Eclipse combo and try to nail
down whether it's Jazz or Linux or something else :)
Shilpa
Re: Missing images [message #586375 is a reply to message #47281] |
Wed, 30 January 2008 02:54  |
I have changed my ant definition from a process execution:
<exec executable="${dir.epf.composer}/epf">
<arg line="-application org.eclipse.epf.publishing.cmdline.Publish" />
<arg line="-data ${dir.data}" />
<arg line="-nosplash" />
<arg line="-libraryPath ${dir.checkout}" />
<arg line="-publishPath ${dir.epf.publish}" />
<arg line="-config TE-RUP_Agile" />
<arg line="-feedback mailto:te.rup@tietoenator.com" />
<arg line="-glossary" />
<arg line="-index" />
<arg line="-publishUnverifiedDiagrams" />
<arg line="-title TE-RUP_Agile" />
<arg line="-vmargs -Xms64m -Xmx512m" />
</exec>
To java:
<java dir="${dir.epf.composer}"
jar=" ${dir.epf.composer}/plugins/org.eclipse.equinox.launcher_1.0 .0.v20070606.jar "
fork="true" maxmemory="512m" logError="true">
<arg line="-ws gtk" />
<classpath>
<pathelement
location=" ${dir.epf.composer}/plugins/org.eclipse.equinox.launcher_1.0 .0.v20070606.jar "
</classpath>
</java>
And now - big surprise - it works! All the pictures are in place. Actually,
the idea behind the change: I have noticed eclipse was refreshing workspace
every time it started; which sounded like problem with process; so I tried
to change it (bug in OS/Java?)...
Anyway, it works I have to move on...
However, I have found 2 picture issues (warning log + they are still missing
in the published config):
Warning: Guideline:req_gathering_techniques: missing resource file
'./../../../openup/guidances/guidelines/resources/Workshop.G IF'
Warning: RoleSet:openup_roles: missing resource file
'./../../openup/rolesets/./resources/OpenUp1_350.jpg'
Have you noticed same problem? I expect GIF or capital letters might be
problem (the references in source xmi?)
Roman
news:a1c63d4302177a45eb589565681f1702$1@www.eclipse.org...
> Which EPF did you download ? If you are using latest EPF build 1.2.0.1 you
> need JRE 1.5.
> Please follow the instructions given here
> http://www.eclipse.org/epf/downloads/tool/tool_downloads.php
> Shilpa
news:0bfe89ba1477a1af67fd981d29032f78$1@www.eclipse.org...
> images exist or not. If path is wrong or if image is missing then i can
> start going into EPF source code to see.
> Shilpa
Re: Missing images [message #588271 is a reply to message #47411] |
Wed, 30 January 2008 13:07  |
For linux, file names are case-sensitive. So we would have to change
references in data files correctly.
I didn't quite get whether you are using our OpenUp from CVS or your own
process. If it's openup, please file a bug against "content" component
for those 2 image references.
Shilpa
Re: Missing images [message #588279 is a reply to message #47472] |
Wed, 30 January 2008 14:13  |
it is OpenUP. I'll submit a bug.
Roman
news:df8a2292097f57dbb74c97da86a57596$1@www.eclipse.org...
> Shilpa
Re: Missing images [message #588622 is a reply to message #47115] |
Roman Smirak wrote:
> error.
> Roman
David Hadley
FUDForum. Page generated in 0.05729 seconds
