Home » Eclipse Projects » Equinox » Problem with split packages
Problem with split packages [message #47114] Fri, 18 March 2005 09:14 Go to next message
I am seeing a problem with resolving a split package across bundles (using
Eclipse 31 M5a driver). Here is the scenario:
Bundle-A :
Export-Package: package.split
Bundle-B :
Require-Bundle: Bundle-A
Bundle-glue:
Require-Bundle: Bundle-A, Bundle-B
Reexport-Package: package.split; foo="bar"
After launching, Bundle-Glue doesn't seem to get resolved.
If I turn on tracing on OSGi resolver options, I see the following message,
before Bundle-glue is declared not resolved:
"* grouping clash with [Bundle-A] : package.split"
Can someone explain what this means ? Is this not a valid split-package
scenario ?
Subbarao
Re: Problem with split packages [message #47143 is a reply to message #47114] Tue, 22 March 2005 14:10 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Looks valid. Do you have
Bundle-ManifestVersion: 2
in your manifests?
Jeff
"Subbarao Meduri" <mkv@us.ibm.com> wrote in message
news:d1eno6$87j$1@www.eclipse.org...
> Bundle-A :
> Bundle-B :
> Bundle-glue:
message,
> scenario ?
> Subbarao
Re: Problem with split packages [message #47173 is a reply to message #47114] Wed, 23 March 2005 07:47 Go to previous message
Originally posted by: stepper.sympedia.de
Subbarao,
are you sure you may name your package "package.XYZ"?
"package" is not allowed as identifier in Java.
Cheers
/Eike
> Bundle-A :
> Bundle-B :
> Bundle-glue:
> scenario ?
> Subbarao
Previous Topic:Extending the OSGI Console with your own commands?
Next Topic:Maven and eclipse plugins
Current Time: Fri May 09 20:11:29 EDT 2025
Powered by FUDForum. Page generated in 0.05586 seconds
