Help: Eclipse+Servlets Development [message #46991] |
Wed, 26 February 2003 03:24  |
Originally posted by: tonyz.myway.com
Hello everybody,
I'm a newcomer to Eclipse and I need some help:
How should I configure Eclipse so I can develop servlets using it ?
The rt.jar I have under D:\Program Files\Java\j2re1.4.1_01\lib does not
contain the classes needed for servlet development. Should I download from
SUN the J2EE SDK ?
On a PC where a former collegue was working on servlets using Eclipse that
J2EE SDK is not installed and is not even mentioned in Java Build
Path->Libraries.
Can somebody help me ?
Thank you.
Re: Help: Eclipse+Servlets Development [message #48318 is a reply to message #46991] |
Thu, 06 March 2003 02:50  |
Originally posted by: kanele.gmx.de
Tony Vanzetta wrote:
> Hello everybody,
> SUN the J2EE SDK ?
> Path->Libraries.
> Thank you.
There are several plugins around for Servlet development as for example
lomboz.
With these you can create Web/J2EE containers.
Have a try
Re: Help: Eclipse+Servlets Development [message #590967 is a reply to message #46991] |
Sat, 01 March 2003 20:00  |
> Hello everybody,
> SUN the J2EE SDK ?
Far as I can tell, Eclipse doesn't include any runtime libraries not
directly associated with Eclipse.
You'll need to install the appropriate SDK (sounds like you're running on a
platform supported by Sun, so get them from there), then add the
appropriate .JAR file (don't remember the name off the top of my head.
j2ee.jar?) to your build path.
HTH,
Ian
Re: Help: Eclipse+Servlets Development [message #591344 is a reply to message #46991] |
> Hello everybody,
> SUN the J2EE SDK ?
> Path->Libraries.
> Thank you.
lomboz.
Have a try
FUDForum. Page generated in 0.05012 seconds
