Home » Archived » Visual Editor (VE) » java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #46968] Mon, 05 July 2004 09:55 Go to next message
Originally posted by: ebarnett.adinet.com.uy
I have installed ve and Eclipse 3 final release, I created a new SWT Window
with a textbox and when I try to run it I get this error.
Any help?
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #47001 is a reply to message #46968] Mon, 05 July 2004 10:26 Go to previous messageGo to next message
> Any help?
> Thanks
Just a question on VE. When you create a JButton do you see it correctly
before running the java application? If you can see it can you tell me
what the version of VE you use? Thanks
Séb
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #47029 is a reply to message #46968] Mon, 05 July 2004 10:31 Go to previous message
Eli,
You don't have the swt dll set in your java.library.path variable. See
this entry in the SWT FAQ:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#missingdll
- Jeff
> Any help?
> Thanks
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #594171 is a reply to message #46968] Mon, 05 July 2004 10:26 Go to previous message
> Any help?
> Thanks
Séb
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #594184 is a reply to message #46968] Mon, 05 July 2004 10:31 Go to previous message
Eli,
- Jeff
> Any help?
> Thanks
Previous Topic:ve cvs
Next Topic:Can't open visual editor Eclipse 3.0 (with recommended versions)
Current Time: Sun Aug 31 17:47:35 EDT 2025
Powered by FUDForum. Page generated in 0.12372 seconds
