Grid row headers [message #46954] |
Thu, 17 January 2008 15:09  |
I called setRowHeaderVisible(true) and I get a row header. Now how can I
specify what the values for the row headers are? I don't want numbers, I
want text labels that I can specify.
- Jason
Re: Grid row headers [message #47847 is a reply to message #47704] |
Mon, 28 January 2008 08:23  |
--------------040906080009050107080508
Chris Gross schrieb:
> Hi Jason,
> setRowHeaderLabelProvider should work. Alternately you can do as you
> did (although you should only need to actually implement
> getRowHeaderText on one provider).
> Tom - do you know why this might not be working?
Just tried it and for me it works but I think the naming is not 100%
correct and we should rename it to RowLabelProvider?
I've attached my test-snippet.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
name="GridColumnLabelProvider.java"
Content-Disposition: inline;
filename="GridColumnLabelProvider.java"
* Copyright (c) 2007 Tom Schindl and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Tom Schindl - initial API and implementation
package org.eclipse.nebula.jface.gridviewer;
import org.eclipse.jface.viewers.ColumnLabelProvider;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.nebula.widgets.grid.GridItem;
* A label provider that provides hooks for extra functionality in the {@link Grid}. This is currently
* limited to supplying the row header text.
* <p>
* <b> Only one from all {@link GridColumnLabelProvider} in a viewer should
* return a none <code>null</code></b>
* </p>
public class GridColumnLabelProvider extends ColumnLabelProvider {
* Returns the row header text for this element.
* @param element
* the model element
* @return the text displayed in the row-header or <code>null</code> if
* this label provider would not like to modify the default text
public String getRowHeaderText(Object element) {
return null;
public void update(ViewerCell cell) {
super.update(cell);
String rowText = getRowHeaderText(cell.getElement());
if (rowText != null) {
((GridItem) cell.getViewerRow().getItem()).setHeaderText(rowText);
--------------040906080009050107080508--
Re: Grid row headers [message #587809 is a reply to message #46954] |
Thu, 17 January 2008 15:46  |
Ah...I think I found it. I extended GridColumnLabelProvider and used
GridViewerColumns to add the label provider to each column. Not very
intuitive this way since the row header isn't really a column, but it
seems to work.
Should GridViewer.setRowHeaderLabelProvider() do this as well? I tried
that but it didn't seem to work for me. Might have been something I did
wrong though - I've only been using the Grid API for 30 minutes or so... :)
Re: Grid row headers [message #588042 is a reply to message #46984] |
Sun, 27 January 2008 10:09  |
Hi Jason,
regards,
-Chris
> seems to work.
Re: Grid row headers [message #588092 is a reply to message #47704] |
> Hi Jason,
Tom
* Contributors:
* <p>
* </p>
* @param element
* the model element
return null;
super.update(cell);
FUDForum. Page generated in 0.03925 seconds
