Home » Archived » OHF » CDA CCD distinction
CDA CCD distinction [message #46939] Mon, 01 September 2008 03:50 Go to next message
How use procedures (Code) to distinction between¡¡CDA and CCD?
Thanks!!
Re: CDA CCD distinction [message #47147 is a reply to message #46939] Thu, 04 September 2008 12:55 Go to previous message
Hi Robert,
A CCD document is still a conformant CDA document -- just with
additional constraints. If one would want to distinguish between the two
in an XDS environment, they'd use a format code. So far IHE has not
exactly done so for CDA and CCD. They do have format codes for much of
the PCC content profiles -- most of which are constrained forms of CDA.
more information on PCC be found here:
http://wiki.ihe.net/index.php?title=Frameworks#IHE_Patient_C are_Coordination_Technical_Framework
examples of format codes (we'll probably see these in 2009) can be found
here:
http://wiki.ihe.net/index.php?title=PCC_TF-2#IHE_Format_Code s
hope this helps,
Sarah
RobertHua wrote:
> Thanks!!
Re: CDA CCD distinction [message #587316 is a reply to message #46939] Thu, 04 September 2008 12:55 Go to previous message
Hi Robert,
here:
hope this helps,
Sarah
RobertHua wrote:
> Thanks!!
Previous Topic:links for IHE testing
Next Topic:XCA testing status
Current Time: Mon Sep 01 05:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.05861 seconds
