ve cvs [message #46938] |
Mon, 05 July 2004 10:15  |
I try VE cvs (cvs co ve-all), build with eclipse 3.0, gef 3.0 and
emf-xsd-sdo 2.0.0
When I create Visual class I get nullpointer exception without stack trace
What is a problem ?
regards
Haris Peco
Re: ve cvs [message #48518 is a reply to message #48441] |
Tue, 06 July 2004 22:02   |
Hello Rich,
I work with manual cvs on linux :
cvs co ve-all
then, import all plugina in ve-all with plugin for import plugin multiple
project
I get error for duplicate plugin and all com.ibm.* plugin are in first
directory in ve-all and in org.eclipse.jem-feature
I try ve on windows , too - it is same - when make visual class I get error
in visual editor - nullpointer exception
I see new pallete (show it when hover), but isn't there frame in visual
editor
Does it mean : compile ve for win32 target on linux and it should work on
linux, too ?
I compile complete eclipse from cvs (without standard 'cvs export' than
manual 'cvs co ..'); emf, gef,cdt , lomboz ... too, but have problem with
ve
It is important for me - does it current ve cvs work ?
Rich Kulp wrote:
> Two things:
> 1) Just import ve-all, don't import jem-feature because ve-all already
> includes jem-feature.
> 2) We currently only compile against win32 eclipse. You can compile ON
> Linux, but your target Eclipse needs to be a win32 eclipse.
Re: ve cvs [message #48873 is a reply to message #48812] |
Wed, 07 July 2004 13:11  |
I like special cvs out of eclipse workspace - I work all in my cvs
repository and often delete workspace
One question yet, only:
current ve cvs work fine (open simple visual class without exception) ?
Rich Kulp wrote:
> I suggest using the CVS support in Eclipse. It is great and it would
> solve your problem and you would not be doing multiple steps. It would
> be just one step, check out from CVS through Eclipse. We do some special
> stuff where we have a few projects embedded within another project.
> Eclipse CVS checkout of ve-all understands this and does it correctly.
>> linux, too ?
> No, this means compile on Linux, but in your
> Windows->Preferences->Plugin Development->Target Platform you point to a
> win32 version of Eclipse.
> I can't help unless you do it through Eclipse CVS because it requires a
> special setup that Eclipse understands when Eclipse extracts from CVS.
Re: ve cvs [message #48903 is a reply to message #48873] |
Wed, 07 July 2004 11:03  |
Yes, the current cvs code works fine. The Integration build made last
night for the testpass we're in was built from the latest cvs source.
- Jeff
snpe wrote:
Re: ve cvs [message #594440 is a reply to message #46938] |
Tue, 06 July 2004 10:26  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Do you really want to use VE from cvs? That is only useful if you are a
VE developer who is changing VE code. You should be using the already
built downloads instead to use VE.
Thanks, Rich Kulp
Re: ve cvs [message #594501 is a reply to message #47719] |
Tue, 06 July 2004 16:48  |
I have 56k modem connection and I can't download every new release from
beginning
I try VE dowload and it work, but cvs have new features
VE cvs isn't changed in last 7-8 days, but I can't build it
Is it work or not ?
Re: ve cvs [message #594517 is a reply to message #47953] |
Tue, 06 July 2004 16:51  |
I am sorry. I can build it, but I get nullpointer when I open visual class
regards
> beginning
> Is it work or not ?
> Thanks
Re: ve cvs [message #594608 is a reply to message #48013] |
Tue, 06 July 2004 16:45  |
Are you using Export Feature, or are you trying to run it as a Runtime
Workbench?
Thanks, Rich Kulp
Re: ve cvs [message #594622 is a reply to message #48304] |
Tue, 06 July 2004 20:16  |
Both.it is same.
I can't import jem-feature - I get duplicate plugins (com.ibm.* plugins are
in ve-all directory and jem-fature , too)
> Workbench?
Re: ve cvs [message #594632 is a reply to message #48363] |
Tue, 06 July 2004 20:18  |
I can't compile plugin org.eclipse.ve.swt (linux) without add swt-win32.jar,
too
regards
snpe wrote:
> Both.it is same.
> are in ve-all directory and jem-fature , too)
> Thanks
>> Workbench?
Re: ve cvs [message #594642 is a reply to message #48393] |
Tue, 06 July 2004 18:20  |
Two things:
Thanks, Rich Kulp
Re: ve cvs [message #594667 is a reply to message #48441] |
Hello Rich,
cvs co ve-all
project
editor
linux, too ?
ve
Rich Kulp wrote:
> Two things:
Re: ve cvs [message #594748 is a reply to message #48518] |
Wed, 07 July 2004 10:48  |
> linux, too ?
Thanks, Rich Kulp
Re: ve cvs [message #594766 is a reply to message #48812] |
>> linux, too ?
Re: ve cvs [message #594777 is a reply to message #48873] |
- Jeff
snpe wrote:
FUDForum. Page generated in 0.05713 seconds
