Can not select JavaHL 1.6 Connector [message #46892] |
Fri, 29 May 2009 10:25  |
I'm using the newest Eclipse Galileo version 3.5RC2 and installed the
Subversive Plugins from the Eclipse UpdateSite [
http://download.eclipse.org/technology/subversive/0.7/update -site/ ] and
SVN-Connectors from Polarion Update Site
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
I installed all SVN Connectors (SVN-Kit and JavaHL) for Subversion 1.5 and
1.6 for testing. The installation was successful - everything went fine. I
have only one problem.
I can not select the JavaHL 1.6 SVN Connector in the Eclipse preferences
dialog (Team => SVN => 'Tab' "SVN Connector"). In the SVN Connector list I
can see the installed SVN Connectors. For the JavaHL 1.6 Connector there
is an entry like this:
"Native JavaHL (0x00 100000: Cannot load libraries ...
javahl16.win32_2.2.0.I20090505-1500\libsvn_subr-1.dll)"
Does anybody know the reason why?
regards & many thanks in advance!
Re: Can not select JavaHL 1.6 Connector [message #47100 is a reply to message #47070] |
Fri, 05 June 2009 09:10   |
Igor Burilo napsal(a):
> Hello Simon,
> For more details, please see
> http://dev.eclipse.org/newslists/news.eclipse.technology.sub versive/msg01125.html
> It's not a Subversive bug, it's JVM bug.
>> sNop wrote:
>>> this is bug, igor wrote that it`s somehow relate with java machine, that
>>> could be loaded only one dll
>>> But i mean that because this there should be two dll`s which are needed
>> Thank you for your reply. Do you know is there a Bug-Report about this
>> issue? I didn't find one.
>> It's very interesting for me to know when this bug is solved.
>> Thanks,
Hi Igor,
I want to ask you only one question, it's possible handle older repos < 1.6, so 1.4.x and
1.5.x with JavaHL 1.6 connector ?
Or from another side, which repos can I administrate with JavaHL 1.6 ?
Thank you for advices
Re: Can not select JavaHL 1.6 Connector [message #47300 is a reply to message #47100] |
Mon, 15 June 2009 03:49   |
Hello sNop,
You can work with 1.6, 1.5, 1.4 repositories using JavaHL 1.6 connector. You
can imagine that working with SVN connector is the same as working with svn
command client.
>> Hello Simon,
>>>> that
>>> Thanks,
> Hi Igor,
> 1.6, so 1.4.x and
Re: Can not select JavaHL 1.6 Connector [message #47394 is a reply to message #47300] |
Mon, 15 June 2009 11:53  |
> Hello sNop,
> command client.
Aha, thank you igor, now I understand what mean SVN connector
Thank you
FUDForum. Page generated in 0.03967 seconds
