Home » Eclipse Projects » Subversive » Can not select JavaHL 1.6 Connector
Can not select JavaHL 1.6 Connector [message #46892] Fri, 29 May 2009 10:25 Go to next message
I'm using the newest Eclipse Galileo version 3.5RC2 and installed the
Subversive Plugins from the Eclipse UpdateSite [
http://download.eclipse.org/technology/subversive/0.7/update -site/ ] and
SVN-Connectors from Polarion Update Site
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
I installed all SVN Connectors (SVN-Kit and JavaHL) for Subversion 1.5 and
1.6 for testing. The installation was successful - everything went fine. I
have only one problem.
I can not select the JavaHL 1.6 SVN Connector in the Eclipse preferences
dialog (Team => SVN => 'Tab' "SVN Connector"). In the SVN Connector list I
can see the installed SVN Connectors. For the JavaHL 1.6 Connector there
is an entry like this:
"Native JavaHL (0x00 100000: Cannot load libraries ...
javahl16.win32_2.2.0.I20090505-1500\libsvn_subr-1.dll)"
Does anybody know the reason why?
regards & many thanks in advance!
Re: Can not select JavaHL 1.6 Connector [message #46925 is a reply to message #46892] Sat, 30 May 2009 03:32 Go to previous messageGo to next message
Simon Linden napsal(a):
> Hello,
> and 1.6 for testing. The installation was successful - everything went
> fine. I have only one problem.
> I can see the installed SVN Connectors. For the JavaHL 1.6 Connector
> there is an entry like this:
this is bug, igor wrote that it`s somehow relate with java machine, that could be loaded
only one dll
But i mean that because this there should be two dll`s which are needed
Re: Can not select JavaHL 1.6 Connector [message #47012 is a reply to message #46925] Thu, 04 June 2009 05:19 Go to previous messageGo to next message
> could be loaded only one dll
Thank you for your reply.
Do you know is there a Bug-Report about this issue? I didn't find one.
It's very interesting for me to know when this bug is solved.
Re: Can not select JavaHL 1.6 Connector [message #47040 is a reply to message #47012] Thu, 04 June 2009 07:56 Go to previous messageGo to next message
>> that could be loaded only one dll
> Thank you for your reply. Do you know is there a Bug-Report about this
I don't know, igor should write him point of view about this problem
Re: Can not select JavaHL 1.6 Connector [message #47070 is a reply to message #47012] Fri, 05 June 2009 03:29 Go to previous messageGo to next message
Hello Simon,
For more details, please see
http://dev.eclipse.org/newslists/news.eclipse.technology.sub versive/msg01125.html
It's not a Subversive bug, it's JVM bug.
Re: Can not select JavaHL 1.6 Connector [message #47100 is a reply to message #47070] Fri, 05 June 2009 09:10 Go to previous messageGo to next message
Igor Burilo napsal(a):
> Hello Simon,
>> Thanks,
Hi Igor,
I want to ask you only one question, it's possible handle older repos < 1.6, so 1.4.x and
1.5.x with JavaHL 1.6 connector ?
Or from another side, which repos can I administrate with JavaHL 1.6 ?
Thank you for advices
Re: Can not select JavaHL 1.6 Connector [message #47300 is a reply to message #47100] Mon, 15 June 2009 03:49 Go to previous messageGo to next message
Hello sNop,
You can work with 1.6, 1.5, 1.4 repositories using JavaHL 1.6 connector. You
can imagine that working with SVN connector is the same as working with svn
command client.
>> Hello Simon,
>>>> that
>>> Thanks,
> Hi Igor,
> 1.6, so 1.4.x and
Re: Can not select JavaHL 1.6 Connector [message #47394 is a reply to message #47300] Mon, 15 June 2009 11:53 Go to previous message
> Hello sNop,
> command client.
Aha, thank you igor, now I understand what mean SVN connector
Thank you
Previous Topic:Functionality of Compare With ... Branch/Tag
Next Topic:Error: unable connect...
Current Time: Sat Aug 30 22:54:48 EDT 2025
Powered by FUDForum. Page generated in 0.03734 seconds
