Home » Archived » Test and Performance Tools Platform (TPTP) » Impossible to remove the plug-in
Impossible to remove the plug-in [message #46850] Thu, 15 December 2005 12:15 Go to next message
Originally posted by: duvelbier-tsmets.yahoo.com
When removing the plugin, I get :
Problems occurred restoring workbench.
Unable to restore perspective: Workspace - Profiling and Logging.
Could not create view:
org.eclipse.hyades.log.ui.internal.navigator.LogNavigator
org.eclipse.hyades.trace.views.adapter.internal.ExecutionSta tisticViewer2
org.eclipse.hyades.trace.views.adapter.internal.MemoryStatis ticViewer
org.eclipse.hyades.trace.internal.ui.PDProjectExplorer
org.eclipse.hyades.trace.views.adapter.internal.PatternViewe r
Could not find view:
Shouldn't the configuration be part of a external file ... instead of
(probably) part of the ".eclipse" configuration file
\T,
Re: Impossible to remove the plug-in [message #47002 is a reply to message #46850] Fri, 16 December 2005 09:30 Go to previous message
Hi Thomas,
Can you provide the name of the plug-in your removed? Also, what
configuration are you referring to in the last sentence of your post? As a
sidebar, whenever plug-ins are modified, you should start Eclipse with
the -clean flag to force the run time to reload plug-in manifests.
Paul
"Thomas SMETS" <duvelbier-tsmets@yahoo.com> wrote in message
news:01b248ac32bac2878bb5677712dbface$1@www.eclipse.org...
> \T,
Previous Topic:tptpFileTransferAgent.exe broken?
Next Topic:launching AGR test from command line
Current Time: Sun Aug 31 06:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
