Re: Halting SWT thread but repainting [message #463185 is a reply to message #463115] |
Fri, 28 October 2005 16:48 |
Hans Messages: 36 Registered: July 2009 |
Member |
Gordon Hirsch wrote:
> Hans wrote:
>> Just for the archive - here is the solution: use
>> Shell.setEnabled(false) to block it while the Swing process is
>> running. This will reject any use input but still handle repaint events.
> Hans,
> Wouldn't the setEnabled(false) call visually change the SWT window (i.e.
> grey it out)? The javadoc seems to say so.
I tried it for the Eclipse main window and the behavior is as desired -
it is not greyed out and no longer accepts any input. On Windows at
least...
By the way, in my code snippet below, of course there has to be a line
busy = true;
at the very beginning.
Hans
> Also, if I may respond late to a previous post of yours on this
> thread... The strategy of opening a hidden SWT modal dialog in
> conjunction with the Swing dialog, while messy, can be made to work. The
> trick is to add a focus handler to the hidden SWT dialog; whenever it
> gains focus, you can transfer control right back to the Swing dialog.
> My main concern is that some unusual event will cause this hidden modal
> dialog to remain open after the Swing dialog closes. That would
> permanently disable all input to my application. Not good. So, I'd
> really like to find a cleaner way...
>> So a pattern such as the following can be employed (from SWT thread,
>> assuming there is a boolean field "busy" in the class):
>> SwingUtilities.invokeLater(new Runnable() {
>> public void run() {
>> try {
>> // Do the Swing work, e.g. modal dialog
>> finally {
>> busy = false;
>> shell.setEnabled(false);
>> Display display = shell.getDisplay();
>> while (!shell.isDisposed() && busy) {
>> if (!display.readAndDispatch()) {
>> display.sleep();
>> shell.setEnabled(true);
>> Hans
FUDForum. Page generated in 0.03298 seconds
