Home » Eclipse Projects » Subversive » Can not select SVN Connector
Can not select SVN Connector [message #46773] Mon, 18 May 2009 11:07 Go to next message
Hi all,
I can not select an SVN Connector with Subversive 0.7.8 weekly build
from 05/15. I'm running Eclipse 3.5 RC1 OSX_x86. I installed SVNkit
1.1.7 and 1.2.0.
Is that a known problem or does anybody else have the same problem and
probably also a solution?
thanks in Advance
Ingo
Re: Can not select SVN Connector [message #46803 is a reply to message #46773] Mon, 18 May 2009 11:21 Go to previous message
Ingo Renner wrote:
> Hi all,
> 1.1.7 and 1.2.0.
solved by the instructions here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275495
Ingo
Previous Topic:Nop SVN Connectors in OS X Cocoa M7
Next Topic:Installed Subversive & connectors cannot select connectors
Current Time: Sun Aug 31 07:04:11 EDT 2025
Powered by FUDForum. Page generated in 0.03411 seconds
