Quickly customizing a process (e.g via copy-and-paste) [message #46754] |
Mon, 07 January 2008 21:44  |
I'm extending OpenUP with out company's specific and I am trying to keep
a similar method content hierarchy in my plug-in as OpenUP.
The problem/annoyance I am having is that I have to manually create this
structure and manually create the child elements and then select
variability.
Has any thought been given to allow copying items from one plug-in and
pasting them into another plug-in and maybe prompting for the type of
"Content Variablity" to use?
This would save me a lot of effort in customizing an existing process.
Re: Quickly customizing a process (e.g via copy-and-paste) [message #48297 is a reply to message #48212] |
Fri, 22 February 2008 22:43  |
Originally posted by: phaumer.us.no-spam.ibm.com
Hello Barrie.
We currently do not have much support for dragging or copy-pasting
categories in the tree. However, this sounds like a good idea that we
should discuss. Dragging and prompting for a variability type would
certainly be an excellent improvement for plugin authors that want to extend
an existing plugin to "plug in" their categories. We are discussing in our
team at the moment what kind of refactoring and copy we want to support in
the next release. So the timing is great. Could you write some more
scenarios for what you have in mind?
Peter.
"Barrie Treloar" <baerrach@gmail.com> wrote in message
news:fpi72a$vu6$1@build.eclipse.org...
> Shilpa Toraskar wrote:
>> I was actually talking about customizing a process in process editor. If
>> you open a process editor, you should be able to do DND method elements
>> from configuration view.
>> You are basically tryng to copy custom category. There is no drag and
>> drop there
>> Manual copy/paste will work there but you would have to fix dependencies
>> etc.
>> Shilpa
> Shilpa is the only one to reply to this thread.
> Does anyone think what I am requesting is unreasonable?
> Is anyone else extending an existing process (like OpenUP) or are they
> doing their own custom processes with no dependencies.
Re: Quickly customizing a process (e.g via copy-and-paste) [message #586181 is a reply to message #46793] |
Mon, 14 January 2008 17:33  |
> Have you looked at customizing original process via Drag and Drop -
> extend, copy, deep copy functionality available in EPF ?
That's exactly what I want. Can you describe a scenario that works for you?
DnD does not appear to be enabled in EPF 1.2.0.2 (20071113-1739)
I have tried DnD on the following and I get no drag icon:
1)
openup/
Custom Categories/
openup_views/
openup_treebrowser/
introduction_to_openup
into
my/
Custom Categories/
my_views/
my_treebrowser/
2) openup/
Method Content/
Content Packages/
solution/
test/
Roles/
tester_tst
into
my/
Method Content/
Content Packages/
solution/
test/
Roles/
Re: Quickly customizing a process (e.g via copy-and-paste) [message #586198 is a reply to message #47024] |
Tue, 15 January 2008 15:56  |
You are basically tryng to copy custom category. There is no drag and drop
there
etc.
Shilpa
Re: Quickly customizing a process (e.g via copy-and-paste) [message #588486 is a reply to message #47054] |
Wed, 20 February 2008 16:45  |
> drop there
> etc.
> Shilpa
Re: Quickly customizing a process (e.g via copy-and-paste) [message #588504 is a reply to message #47054] |
Thu, 21 February 2008 05:18  |
Originally posted by: andreas.pursche.inf.tu-dresden.de
By the way, there seems to be a bug in copy/paste custom categories:
If I try to copy a structured custom category with sub-categories,
the structure is damaged after pasting them into a plug-in.
Is this a known issue?
> drop there
> etc.
Re: Quickly customizing a process (e.g via copy-and-paste) [message #588515 is a reply to message #48212] |
Hello Barrie.
Peter.
>> drop there
>> etc.
>> Shilpa
FUDForum. Page generated in 0.05700 seconds
