Weaving Aspect in Jar [message #46737] |
Mon, 24 January 2005 09:10  |
Originally posted by: ericml.audaxis.com
I'm trying to implement an aspect on a class located in a Jar. The jar
is part of my project build path.
Is there a way to do that without having to copy the class source code
in my project?
I tried to put the jar in the inpath settings but it does not seems to work.
--ERic
Re: Weaving Aspect in Jar [message #46872 is a reply to message #46755] |
Mon, 24 January 2005 12:23   |
>>in my project?
> Yes, you can binary weave into class files in a JAR file. The JAR file
> should be added to your InPath (under project Projects > AspectJ InPath)
> but it doesn't need to be on your build path.
> There is a preferences option to "show weaving info messages to problems
> view" which should then confirm whether the weaving is happened as you
> want.
> If you still can't get it working, please give your AJDT version, and more
> details of your setup. Is your JAR file contained within your project, or
> is it external?
> Matt.
Thanks Matt for the quick answer.
I'm using AJDT version: 1.1.12
I already tried to put the JAR in the inPath but it didn't work.
The jar is not in the project. It's coming from my maven repository and
it is defined as an external jar (I tried to use variable extension but
the variable name is not translated - ajdt is looking for
<project_dir>/MAVEN_REPO/<jar path in the repository>)
This is maybe the issue. I will try with the jar in the project.
Thanks again,
--ERic
Re: Weaving Aspect in Jar [message #46931 is a reply to message #46872] |
Mon, 24 January 2005 12:38  |
Hopefully that will work. Various bugs in this area have been fixed in
AJDT 1.2.0M2, including the variable name translation, so you may also
like to try that. I remember there was also a problem with external
inpath and aspectpath jars on Linux.
Matt.
Re: Weaving Aspect in Jar [message #586147 is a reply to message #46737] |
Mon, 24 January 2005 11:07  |
> in my project?
want.
is it external?
Matt.
Re: Weaving Aspect in Jar [message #586199 is a reply to message #46755] |
>>in my project?
> want.
> is it external?
> Matt.
Thanks again,
--ERic
Re: Weaving Aspect in Jar [message #586233 is a reply to message #46872] |
Matt.
FUDForum. Page generated in 0.03351 seconds
