SWT isn´t working [message #46707] |
Sun, 04 July 2004 14:52  |
I have installed VEP 1.0 on Eclipse v3.0 Oficial release, but the visual
design doesn´t work.
I followed the installations instructions (copy to eclipse "features"
and "plugins" folders), and it appears on Help / About / Feature
details. I create a "File / New / Other / Visual Class", and select
"Superclass as java.lang.Object", as says on the
" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/newAndNoteworthy/1.0.0-M1/previewi ngSWT.html"
and the "SWT group" appears as expected. But when I try to put a
"Shell", or any other widget, it only appears an icon like beans, and
the widget name below.
Any idea about this problem?
Did I downloaded the right packages?
I donloaded:
VE-runtime-S20040628 (VE-runtime-S20040628.zip)
GEF-runtime-3.0 (GEF-runtime-3.0.zip)
emf-sdo-runtime-2.0.0 (emf-sdo-runtime-2.0.0.zip)
Some ideas?
Thanks in advance
Alessandro
Re: SWT isn´t working [message #47219 is a reply to message #46707] |
Mon, 05 July 2004 23:30  |
Using the tip that Jeff Myers told me on post above the SWT visual
design seems to work fine.
He told me to delete the "configuration" folder and restart Eclipse.
I guess that it should be documented somehow.
Thanks for the help.
Alessandro
Alessandro Fragnani wrote:
> I donloaded:
> Some ideas?
> Thanks in advance
> Alessandro
Re: SWT isn´t working [message #594258 is a reply to message #46707] |
Alessandro
> I donloaded:
> Some ideas?
> Thanks in advance
> Alessandro
FUDForum. Page generated in 0.06954 seconds
