Home » Archived » BPMN Modeler » BPMN - SVN & Generating Diagram Code
BPMN - SVN & Generating Diagram Code [message #4079] Tue, 02 December 2008 14:23 Go to next message
hi,
Do you know whether the BPMN-SVN-location has been changed or how long it
will be unreachable?
Concerning the Diagram Code I'd like to know if it is possible to generate
the original Diagram Code using the bpmn.gen-file from SVN (in the
trunk-folder), because every attempt failed.
Many thanks in advance,
Sven Kühner
Re: BPMN - SVN & Generating Diagram Code [message #4156 is a reply to message #4079] Tue, 02 December 2008 14:45 Go to previous message
Originally posted by: atoulme.intalio.com
Sven Kühner wrote:
> hi,
> it will be unreachable?
Look at this page for the new location of the code:
http://www.eclipse.org/bpmn/source_code.php
> generate the original Diagram Code using the bpmn.gen-file from SVN (in
> the trunk-folder), because every attempt failed.
It is clearly not recommended. This code has been heavily modified and
it seems we did not flag all the changes as @generated not.
> Sven Kühner
Previous Topic:IRC
Next Topic:general Overview (project current situation)
Current Time: Sat Jul 05 09:44:49 EDT 2025
Powered by FUDForum. Page generated in 0.07051 seconds
