Home » General (non-technical) » Eclipse Foundation » Eclipse automated tests failing
Eclipse automated tests failing [message #46702] |
Mon, 25 June 2007 07:16  |
I'm not sure if this is the right place to post this message. If not,
please point me to the right group.
I'm running the automated test suite for eclipse on a port for HP-UX IPF.
However, some of the test suites like pdeui, jdtapt, swt etc. are not
running at all. The messages that appear on the console are as follows.
Any clues ?
Virender.
pdeui
Buildfile: test.xml
pdeui:
init:
runtests:
junit:
setup:
setup-zip:
[delete] Deleting directory
/home/sharan/eclipseTest/eclipse-testing/test-ecl
ipse
[mkdir] Created dir:
/home/sharan/eclipseTest/eclipse-testing/test-eclipse
installTestPlugins:
[exec] caution: excluded filename not matched:
eclipse/*/org.eclipse.test.
source*/*
configureTeamTest:
init:
suite:
ui-test:
eclipse-test:
[echo] Running org.eclipse.pde.ui.tests.AllPDETests
[java] !SESSION 2007-06-18 17:48:37.344
[java] eclipse.buildId=I20061102-1715
[java] java.version=1.4.2.03
[java] java.vendor=Hewlett-Packard Co.
[java] BootLoader constants: OS=hpux, ARCH=ia64_32, WS=motif, NL=en
[java] Framework arguments: -application
org.eclipse.test.uitestapplicatio
n
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter
,org.eclipse.pde.ui.tests.AllPDETests.xml -testPluginName
ts -className org.eclipse.pde.ui.tests.AllPDETests
[java] Command-line arguments: -application
tion -dev bin -data
/home/sharan/eclipseTest/eclipse-testing/test-eclipse/eclips
e/pde_sniff_folder
itResultFormatter,org.eclipse.pde.ui.tests.AllPDETests.xml -testPluginName
org.e
clipse.pde.ui.tests -className org.eclipse.pde.ui.tests.AllPDETests -os
hpux -ws
motif -arch ia64_32 -consolelog
[java] !ENTRY org.eclipse.osgi 2 0 2007-06-18 17:48:59.664
[java] !MESSAGE The following is a complete list of bundles which are
not r
esolved, see the prior log entry for the root cause if it exists:
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.665
[java] !MESSAGE Bundle
update@plugins/org.eclipse.jdt.apt.ui_3.3.0.v2006100
3-2100.jar [28] was not resolved.
[java] !SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2007-06-18 17:48:59.665
[java] !MESSAGE Missing required bundle
org.eclipse.jdt.apt.core_[3.2.0,4.0
0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.666
update@plugins/org.eclipse.jdt.junit4.runtime_1.0.10
0.v20061101-0800.jar [33] was not resolved.
[java] !SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2007-06-18
17:48:59.6
66
[java] !MESSAGE Missing required bundle org.junit4_[4.1.0,4.2.0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.667
update@plugins/org.eclipse.jdt.apt.core_3.3.0.v20061
003-2100.jar [91] was not resolved.
[java] !SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2007-06-18
17:48:59.667
[java] !MESSAGE Missing Constraint:
Bundle-RequiredExecutionEnvironment: J2
SE-1.5
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.668
[java] !MESSAGE Bundle update@plugins/org.junit4_4.1.0.1/ [110] was
not res
olved.
[java] !SUBENTRY 2 org.junit4 2 0 2007-06-18 17:48:59.668
SE-1.5
[java] SIGSEGV 11* segmentation violation
[java] si_signo [11]: SIGSEGV 11* segmentation violation
[java] si_errno [0]: Error 0
[java] si_code [1]: SEGV_MAPERR [addr: 0xef2b9c78]
[java] Aborting...
[java] Unexpected Signal : 11 occurred at PC=0x7AC20721
[java] Function=[Unknown.]
[java] Library=(N/A)
[java] NOTE: We are unable to locate the function name symbol for the
error
[java] just occurred. Please refer to release documentation for
possi
ble
[java] reason and solutions.
[java] Current Java thread:
[java] "main" prio=7 tid=000662a0 nid=1 lwp_id=-1 runnable
[0x00000000..0x7
fffe728]
[java] Dynamic libraries:
[java] /opt/java1.4/jre/bin/IA64N/java
[java] text:0x00001000-0x000119d0 data:0x00012000-0x00012648
[java] /usr/lib/hpux32/libpthread.so.1
[java] text:0xc008d000-0xc011fcb0 data:0x7efef000-0x7eff1508
[java] /opt/java1.4/jre/lib/IA64N/server/libjvm.so
[java] text:0xc490f000-0xc58b4cd0 data:0x7ed00000-0x7ef36b78
[java] /usr/lib/hpux32/libdl.so.1
[java] text:0xc039f000-0xc03a1660 data:0x7efec000-0x7efec068
[java] /usr/lib/hpux32/libc.so.1
[java] text:0xc0120000-0xc039e300 data:0x7efb0000-0x7efc10f8
[java] /usr/lib/hpux32/libm.so.1
[java] text:0xc0521000-0xc0686ba0 data:0x7efcf000-0x7efcf5d8
[java] /usr/lib/hpux32/librt.so.1
[java] text:0xc1c76000-0xc1c7c1f0 data:0x7efcc000-0x7efcc1a8
[java] /usr/lib/hpux32/libuca.so.1
[java] text:0xc10a4000-0xc10abaf0 data:0x7efcb000-0x7efcb150
[java] /usr/lib/hpux32/libunwind.so.1
[java] text:0xc105d000-0xc10a3470 data:0x7efc9000-0x7efca1f0
[java] /usr/lib/hpux32/libcl.so.1
[java] text:0xc1c7d000-0xc1c7d304 data:0x7efc8000-0x7efc8018
[java] /usr/lib/hpux32/libCsup.so.1
[java] text:0xc082f000-0xc08760f0 data:0x7efa9000-0x7efafbe8
[java] /usr/lib/hpux32/libIO77.so.1
[java] text:0xc22fd000-0xc2399410 data:0x7ef9c000-0x7efa6918
[java] /opt/java1.4/jre/lib/IA64N/native_threads/libhpi.so
[java] text:0xc23db000-0xc23f6d80 data:0x7ef96000-0x7ef97880
[java] /opt/java1.4/jre/lib/IA64N/libverify.so
[java] text:0xc23a6000-0xc23c4a10 data:0x7ef92000-0x7ef930a8
[java] /opt/java1.4/jre/lib/IA64N/libjava.so
[java] text:0xc23f7000-0xc243e630 data:0x7ef8d000-0x7ef913b0
[java] /opt/java1.4/jre/lib/IA64N/libzip.so
[java] text:0xc243f000-0xc246d180 data:0x7ef87000-0x7ef88880
[java] /opt/java1.4/jre/lib/IA64N/libnet.so
[java] text:0xc2ec6000-0xc2ee8f60 data:0x7ef86000-0x7ef866b8
[java] /usr/lib/hpux32/libnm.so
[java] text:0xc10ac000-0xc10cb3a0 data:0x7ef83000-0x7ef83458
[java] /opt/java1.4/jre/lib/IA64N/libnio.so
[java] text:0xc08bb000-0xc08c6d20 data:0x7ef82000-0x7ef82488
[java]
/home/sharan/eclipseTest/eclipse-testing/test-eclipse/eclips e/config
uration/org.eclipse.osgi/bundles/107/1/.cp/libswt-motif-3314 .so
[java] text:0xc7562000-0xc765a4f0 data:0x7ef58000-0x7ef5caa0
[java] /usr/lib/hpux32/libXm.so.1
[java] text:0xc9625000-0xc9a192b0 data:0x7ec00000-0x7ec332d0
[java] /usr/lib/hpux32/libXext.so.1
[java] text:0xc9a1a000-0xc9a4d410 data:0x7ef37000-0x7ef37b38
[java] /usr/lib/hpux32/libXt.so.1
[java] text:0xc9561000-0xc9624820 data:0x7ef39000-0x7ef3faf0
[java] /usr/lib/hpux32/X11R6/libSM.so.1
[java] text:0xc27ed000-0xc2800db0 data:0x7ef38000-0x7ef38df0
[java] /usr/lib/hpux32/X11R6/libICE.so.1
[java] text:0xc2f72000-0xc2fa1b00 data:0x7ecfc000-0x7ecff7c0
[java] /usr/lib/hpux32/libX11.so.1
[java] text:0xc765b000-0xc7881180 data:0x7ef40000-0x7ef4f7e8
[java] /usr/lib/hpux32/libXp.so.1
[java] text:0xc27d9000-0xc27ecfc0 data:0x7ef5d000-0x7ef5d770
[java] /usr/lib/hpux32/libXtst.so.1
[java] text:0xc0d3a000-0xc0d46f30 data:0x7ef81000-0x7ef81370
[java]
uration/org.eclipse.osgi/bundles/45/1/.cp/os/hpux/ia64_32/li blocalfile_1_0_0.so
[java] text:0xc0d47000-0xc0d497c0 data:0x7ece7000-0x7ece7080
[java] /usr/lib/hpux32/libnss_dns.so.1
[java] text:0xc0cb9000-0xc0cc6f00 data:0x7ece6000-0x7ece6370
[java] Heap at VM Abort:
[java] Heap
[java] def new generation total 21184K, used 16673K [66800000,
67ef0000,
6bd50000)
[java] eden space 18880K, 76% used [66800000, 676086f0, 67a70000)
[java] from space 2304K, 100% used [67cb0000, 67ef0000, 67ef0000)
[java] to space 2304K, 0% used [67a70000, 67a70000, 67cb0000)
[java] tenured generation total 46828K, used 29306K [6bd50000,
6eb0b000,
76800000)
[java] the space 46828K, 62% used [6bd50000, 6d9eead0, 6d9eec00,
6eb0b0
00)
[java] compacting perm gen total 34816K, used 34622K [76800000,
78a00000,
7a800000)
[java] the space 34816K, 99% used [76800000, 789cf858, 789cfa00,
78a000
00)
[java] Local Time = Mon Jun 18 18:08:18 2007
[java] Elapsed Time = 1183
[java] #
[java] # HotSpot Virtual Machine Error : 11
[java] # Please report this error to HP customer support.
[java] #
[java] # Java VM: Java HotSpot(TM) Server VM (1.4.2
1.4.2.03-040402-00:47-I
A64N IA64 mixed mode)
[java] #
[java] # An error report file has been saved as hs_err_pid28421.log.
[java] # Please refer to the file for further information.
[java] #
[java] Unhandled signal occurred at 0x200000007ac20721
[java] Java Result: 6
cleanup:
run:
collect:
[junitreport] [Fatal Error] :-1:-1: Premature end of file.
[junitreport] The file
ipse/org.eclipse.pde.ui.tests.AllPDETests.xml is not a valid XML document.
It is
possibly corrupted.
[copy] Copying 1 file to
/home/sharan/eclipseTest/eclipse-testing/results/x
ml
genHtml:
[style] Transforming into
/home/sharan/eclipseTest/eclipse-testing/results/h
tml
[style] Processing
/home/sharan/eclipseTest/eclipse-testing/results/xml/org.
eclipse.pde.ui.tests_hpux.motif.ia64_32.xml to
testing/results/html/org.eclipse.pde.ui.tests_hpux.motif.ia6 4_32.html
[style] Loading stylesheet
/home/sharan/eclipseTest/eclipse-testing/JUNIT.XS
L
BUILD SUCCESSFUL
BUILD SUCCESSFUL
Total time: 23 minutes 1 second
swt
Buildfile: test.xml
swt:
init:
runtests:
junit:
setup:
setup-zip:
ipse
installTestPlugins:
source*/*
configureTeamTest:
init:
suite:
core-test:
eclipse-test:
[echo] Running ${class-tests}
[java] !SESSION 2007-06-19 12:17:54.211
org.eclipse.test.coretestapplicat
ion
er,${class-tests}.xml -testPluginName org.eclipse.swt.tests -className
${class-t
ests}
cation -dev bin -data
pse/swt_sniff_folder
UnitResultFormatter,${class-tests}.xml -testPluginName
assName ${class-tests} -os hpux -ws motif -arch ia64_32 -consolelog
[java] !ENTRY org.eclipse.osgi 2 0 2007-06-19 12:18:14.085
not r
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.085
[java] !SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2007-06-19 12:18:14.086
0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.086
[java] !SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2007-06-19
12:18:14.0
86
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.087
[java] !SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2007-06-19
12:18:14.087
SE-1.5
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.088
not res
olved.
[java] !SUBENTRY 2 org.junit4 2 0 2007-06-19 12:18:14.088
SE-1.5
[java] Class not found "${class-tests}"
[java] Java Result: 2
cleanup:
run:
collect:
ml
genHtml:
tml
[style] Processing
eclipse.swt.tests_hpux.motif.ia64_32.xml to
ting/results/html/org.eclipse.swt.tests_hpux.motif.ia64_32.h tml
L
BUILD SUCCESSFUL
BUILD SUCCESSFUL
Total time: 2 minutes 19 seconds
jfacedatabinding
Buildfile: test.xml
jfacedatabinding:
init:
runtests:
junit:
setup:
setup-zip:
ipse
installTestPlugins:
source*/*
configureTeamTest:
init:
suite:
core-test:
eclipse-test:
[echo] Running org.eclipse.jface.tests.databinding.BindingTestSuite
[java] !SESSION 2007-06-20 12:52:37.046
ion
er,org.eclipse.jface.tests.databinding.BindingTestSuite.xml
eclipse.jface.tests.databinding -className
indingTestSuite
pse/databinding_sniff_folder
nit.XMLJUnitResultFormatter,org.eclipse.jface.tests.databind ing.BindingTestSuite
xml -testPluginName org.eclipse.jface.tests.databinding -className
org.eclipse.
jface.tests.databinding.BindingTestSuite -os hpux -ws motif -arch ia64_32
-conso
lelog
[java] !ENTRY org.eclipse.osgi 2 0 2007-06-20 12:53:08.952
not r
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.952
[java] !SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2007-06-20 12:53:08.953
0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.953
[java] !SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2007-06-20
12:53:08.9
54
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.954
[java] !SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2007-06-20
12:53:08.955
SE-1.5
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.955
not res
olved.
[java] !SUBENTRY 2 org.junit4 2 0 2007-06-20 12:53:08.956
SE-1.5
[java] Ignoring disabled test:
org.eclipse.jface.tests.databinding.scenario
s.BindingScenariosTestSuite.null
[java] SIGBUS 10* bus error
[java] si_signo [10]: SIGBUS 10* bus error
[java] si_code [1]: BUS_ADRALN [addr: 0x3bfa2d]
[java] Aborting...
[java] An unexpected exception has been detected in native code
outside the
VM.
[java] Unexpected Signal : 10 occurred at PC=0xC76AAFD0
[java] Function=XSaveContext
[java] Library=/usr/lib/hpux32/libX11.so.1
[java] "main" prio=6 tid=0004dae0 nid=1 lwp_id=-1 runnable
[0x7fffd000..0x7
fffe6f8]
[java] at
org.eclipse.swt.internal.motif.OS._XtAppCreateShell(Native Me
thod)
[java] at
org.eclipse.swt.internal.motif.OS.XtAppCreateShell(OS.java:3 7
01)
[java] at org.eclipse.swt.graphics.Device.init(Device.java:668)
[java] at org.eclipse.swt.widgets.Display.init(Display.java:1948)
[java] at org.eclipse.swt.graphics.Device.<init>(Device.java:189)
[java] - locked <6c2aff68> (a java.lang.Object)
[java] at org.eclipse.swt.widgets.Display.<init>(Display.java:406)
[java] at org.eclipse.swt.widgets.Display.<init>(Display.java:398)
[java] at
org.eclipse.swt.widgets.Display.getDefault(Display.java:1328 )
[java] - locked <76fcade8> (a java.lang.Class)
[java] at
org.eclipse.jface.tests.databinding.scenarios.BindingScenari o
sTestSuite$1.setUp(BindingScenariosTestSuite.java:51)
[java] at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
[java] at
junit.framework.TestResult.runProtected(TestResult.java:124)
[java] at junit.extensions.TestSetup.run(TestSetup.java:25)
[java] at junit.framework.TestSuite.runTest(TestSuite.java:230)
[java] at junit.framework.TestSuite.run(TestSuite.java:225)
[java] at
org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a
:327)
[java] at
:201)
[java] at
org.eclipse.test.CoreTestApplication.runTests(CoreTestApplic a
tion.java:35)
[java] at
org.eclipse.test.CoreTestApplication.run(CoreTestApplication .
java:31)
[java] at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl a
tformActivator.java:78)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .
runApplication(EclipseAppLauncher.java:104)
[java] at
start(EclipseAppLauncher.java:74)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS t
arter.java:348)
[java] at
arter.java:165)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[java] at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce s
sorImpl.java:39)
[java] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe t
hodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:324)
[java] at
org.eclipse.core.launcher.Main.invokeFramework(Main.java:341 )
[java] at org.eclipse.core.launcher.Main.basicRun(Main.java:285)
[java] at org.eclipse.core.launcher.Main.run(Main.java:987)
[java] at org.eclipse.core.launcher.Main.main(Main.java:962)
[java]
[java] text:0xc28a9000-0xc28bcdb0 data:0x7ef38000-0x7ef38df0
[java] text:0xc27e6000-0xc27f9fc0 data:0x7ef5d000-0x7ef5d770
[java] text:0xc27d9000-0xc27e5f30 data:0x7ef81000-0x7ef81370
[java] Heap
[java] def new generation total 12288K, used 6141K [66800000,
67550000,
6bd50000)
[java] eden space 10944K, 48% used [66800000, 66d3c8e0, 672b0000)
[java] from space 1344K, 57% used [672b0000, 67372c68, 67400000)
[java] to space 1344K, 0% used [67400000, 67400000, 67550000)
[java] tenured generation total 27328K, used 7102K [6bd50000,
6d800000,
76800000)
[java] the space 27328K, 25% used [6bd50000, 6c43f9c8, 6c43fa00,
6d8000
00)
[java] compacting perm gen total 16384K, used 8699K [76800000,
77800000,
7a800000)
[java] the space 16384K, 53% used [76800000, 7707edd0, 7707ee00,
778000
00)
[java] Local Time = Wed Jun 20 12:53:28 2007
[java] Elapsed Time = 58
[java] #
[java] # The exception above was detected in native code outside the
VM
[java] #
[java] #
[java] # An error report file has been saved as hs_err_pid4476.log.
[java] #
[java] Unhandled signal occurred at 0x60000000c76aafd0
cleanup:
run:
collect:
ipse/org.eclipse.jface.tests.databinding.BindingTestSuite.xm l is not a
valid XML
document. It is possibly corrupted.
ml
genHtml:
tml
[style] Processing
eclipse.jface.tests.databinding_hpux.motif.ia64_32.xml to
st/eclipse-testing/results/html/org.eclipse.jface.tests.data binding_hpux.motif.i
a64_32.html
L
BUILD SUCCESSFUL
Current Time: Sat Jul 26 09:26:35 EDT 2025
Powered by FUDForum. Page generated in 0.24902 seconds
