Access Restrictions - How to get rid of them? [message #46681] |
Thu, 12 February 2009 09:11  |
Using Ganymede 3.4, I have several plugins, one (A) of them generates
Access Restriction on classes from another plugin (B). A has a depency to B.
I am looking for a structured way to synchronize the PDE environment
accross all my plugins.
What I understand Access Restrictions come from mismatches in JRE's or
explicitly set restrictions. From what I can see in my manifest files in
each plugin I don't have discrepancies in JRE's or explicit restrictions
set.
So in other words, What's the list of items I need to check, when
encountering Access Restrictions?
Thanks! Christophe
Re: Access Restrictions - How to get rid of them? [message #46827 is a reply to message #46748] |
Fri, 13 February 2009 10:27  |
Are you seeing the warnings in the workspace of in a headless build?
Maybe you are using classes in packages that you don't have a
Require-Bundle or Import-Package for? This could happen by using
something from a transitive dependency that you haven't explicitly declared.
In the workspace this would normally result in a Forbidden Access error
(but that can be changed to warning or turned off). In a headless build
there isn't the same flexibility with warnings/errors and the forbidden
access can only be reported as a warning (since it is an osgi thing and
not java.
Forbidden errors/warnings are Bad because you probably won't be able to
load those classes at runtime because of how the class loaders are wired
together. (Discouraged warnings mean you can load the classes unless
osgi was running in strict mode).
-Andrew
Christophe Bouhier wrote:
> Andrew Niefer wrote:
>> Check the bundle that exports the package that contains the class you
>> are referring to.
>> If the bundle exports the package with x-internal:=true then you get
> Thank you for responding. What you write is also what i gathered from
> the documentation.The x-internal is not set by default, and it's not in
> my Manifest.MF, still I get the Access Restrictions which is weird?
>> Access warnings for using things in that package. If it specifies
>> x-friends, only the listed friends are allowed to use it.
>> To get rid of the warning, the x-internal must be removed (making the
>> package API), or your bundle needs to be added as a friend.
>> -Andrew
Re: Access Restrictions - How to get rid of them? [message #591920 is a reply to message #46681] |
Thu, 12 February 2009 11:16  |
are referring to.
-Andrew
> to B.
> set.
> Thanks! Christophe
Re: Access Restrictions - How to get rid of them? [message #591923 is a reply to message #46729] |
Thu, 12 February 2009 17:38  |
> are referring to.
> -Andrew
Re: Access Restrictions - How to get rid of them? [message #591946 is a reply to message #46748] |
not java.
-Andrew
>> are referring to.
>> -Andrew
FUDForum. Page generated in 0.30794 seconds
