Home » Eclipse Projects » Remote Application Platform (RAP) » 1. image on a button; 2. SVG support in RAP?
1. image on a button; 2. SVG support in RAP? [message #46661] Wed, 12 September 2007 10:25 Go to next message
Originally posted by: s5824917.inf.tu-dresden.de
Hi folks,
1. question:
I got a little RAP-HelloWorld application to run. Now I am trying to set an
image on a button.
I tried the following:
Image img = org.eclipse.rwt.graphics.Graphics.getImage("info.gif");
button2.setImage(img);
but the image doesn't show up, actually I get
"Unable to create view: Argument not valid
Image 'info.gif' cannot be found"
So the image can not be found, but I read the InputStream that is being used
here searches the classpath...
"Note: This method searchs the classpath of the current web-application"
InputStream getResourceAsStream( String name );
Structure and position of the image: (so you can see where I put the
info.gif file)
RAPHelloWorld
/ src
/ src / org.eclipse.rap.hellworld
/icons
/META-INF
/info.gif
Can someone help a newbie like me to get this to work?
2. question:
Is it possible to use other objects inside the views too, like SVG or
external Javascript?
So that I could build two views in a perspective, one view with the
SVG-image and one
with options to manipulate said SVG-image.
how hard would it be to accomplish that?
Re: 1. image on a button; 2. SVG support in RAP? [message #46765 is a reply to message #46661] Wed, 12 September 2007 11:26 Go to previous messageGo to next message
Hi Stefan,
you'll find my answers below...
Stefan Lindner wrote:
> Hi folks,
> 1. question:
> image on a button.
> <snip>
You just need to put your image into a package like src/resources and
then pass the image name and the current classloader to the image like this:
Image img = Graphics.getImage("info.gif", getClass().getClassLoader());
> 2. question:
> SVG-image and one
Neither RAP nor Qooxdoo support SVG images at the moment (maybe they
never will as there is no API in SWT for that use case). But...
You can create a little custom widget which generates the corresponding
dom node for you (<svg> in FF, <object> in IE if you have the SVG
plugin). This should be straight forward if i didn't forgot something ;)
Hope that helps. Don't hesitate to ask here if you've problems regarding
your custom widget :)
Cheers
Benny
Re: 1. image on a button; 2. SVG support in RAP? [message #46818 is a reply to message #46765] Wed, 12 September 2007 11:54 Go to previous messageGo to next message
Benjamin Muskalla wrote:
> Hi Stefan,
>> Hi folks,
>> 1. question:
>> set an image on a button.
>> <snip>
> this:
Sorry - typo :)
Image img = Graphics.getImage("resources/info.gif",
>> 2. question:
>> SVG-image and one
> Cheers
> Benny
Re: 1. image on a button; 2. SVG support in RAP? [message #48666 is a reply to message #46818] Fri, 21 September 2007 09:53 Go to previous messageGo to next message
Originally posted by: ingo.kaulbach.bayerbbs.com
Is there an other, easier, way to load the Image?
I am not familar with the ClassLoader-Stuff...
Re: 1. image on a button; 2. SVG support in RAP? [message #48782 is a reply to message #48666] Fri, 21 September 2007 10:53 Go to previous message
Originally posted by: jkrause.innoopract.com
It is just those two lines of code, you don't need to know anything
about classloaders:
ClassLoader imageLoader = getClass().getClassLoader();
Image image1 = Graphics.getImage( "icons/info.gif", imageLoader );
And you need to put the image either on the source path, or, like in
this example in the icons folder of the plugin.
Previous Topic:workbench problem
Next Topic:1.0 will need to be delayed for a couple of days for process reasons
Current Time: Fri Jul 25 11:37:05 EDT 2025
Powered by FUDForum. Page generated in 0.06517 seconds
