memroy leak not detected/memory profiler stopping? [message #46657] |
Wed, 15 June 2005 18:57  |
Originally posted by: lbmes2000.yahoo.com
Hi all
Im using tptp 4.0. When I start memory profiling everything works fine --
i am able to call up instance info and whatnot. After a number of
refreshes, however, the memory profiler claims there is no info and I have
to start recollecting info, losing all the previosly gathered info.
Eventually both eclipse and the program suffer OutOfMemoryError meessages.
While the profiler is working, it does not appear that the program is
leaking memory, the number of live instances for any particular class does
not grow. I get the OOM for the application when I run it from the
command line as well.
I am running under linux. I am not clicking the option that warns about
exponential memory growth (instance level info), and I do not have any
limits set. Here is what shows up on the command line when eclipse
collapses.
java.lang.OutOfMemoryError
Unhandled event loop exception
Reason:
Failed to execute runnable (java.lang.OutOfMemoryError)
*** SWT nested exception
Reason:
FUDForum. Page generated in 0.04845 seconds
