Home » Language IDEs » AspectJ » Eclipse JDT Slow/Hanging when in source editor
Eclipse JDT Slow/Hanging when in source editor [message #46640] Fri, 21 January 2005 07:20 Go to next message
Originally posted by: darran_white.airmiles.co.uk
I`m using the "Easy Install" AspectJ and AJDT distributions available from
Russ Miles page.
When using the editor in eclipse everything operates incredibly slowly or
hangs. I`ve selected incremental builds in the aspectJ properties and
un-associated .java files with the aspectJ editor.
The project isn`t particularily large.
I`ve also changed my JVM settings to -vmargs -Xms256m -Xmx512m.
I`m using a pentium 4 3Ghz with 2Gig of ram.
This is my first experiance with Eclipse and AJDT so I`m probably missing
something obvious.
Any help would be appreciated.
Thanks.
Re: Eclipse JDT Slow/Hanging when in source editor [message #46692 is a reply to message #46640] Fri, 21 January 2005 11:09 Go to previous message
Started a new project from scratch and now all appears to work fine.
> Russ Miles page.
> something obvious.
> Thanks.
Re: Eclipse JDT Slow/Hanging when in source editor [message #586080 is a reply to message #46640] Fri, 21 January 2005 11:09 Go to previous message
> Russ Miles page.
> something obvious.
> Thanks.
Previous Topic:Eclipse JDT Slow/Hanging when in source editor
Next Topic:Memory requirement for ajdt
Current Time: Sat May 10 09:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.02753 seconds
