Layouts [message #461047] |
Thu, 15 September 2005 04:41  |
Originally posted by: davidyoung_2001.yahoo.co.uk
I'm trying to create a "Thunderbird" type layout, with a folders view on
the left (full height) and then the left hand side split into two panes
(top and bottom). All the windows need to be re-sized by draging......
I have the following code but I'n struggling as to how to get the sash
working between the top and bottom views....HELP
package Test;
import org.eclipse.swt.*;
import org.eclipse.swt.custom.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
public class test {
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("Test");
shell.setLayout(new FillLayout());
SashForm form = new SashForm(shell, SWT.HORIZONTAL);
Composite leftComposite = new Composite(form, SWT.BORDER);
leftComposite.setLayout(new RowLayout());
final Composite rightComposite = new Composite(form, SWT.BORDER);
rightComposite.setLayout(new FormLayout());
Composite compositeTheNEW = new Composite(rightComposite, SWT.NONE);
FormData compositeFormDataTheNEW = new FormData();
compositeFormDataTheNEW.left = new FormAttachment(0, 0);
compositeFormDataTheNEW.right = new FormAttachment(100, 0);
compositeFormDataTheNEW.top = new FormAttachment(0, 0);
compositeFormDataTheNEW.bottom = new FormAttachment(100, 0);
compositeTheNEW.setLayoutData(compositeFormDataTheNEW);
compositeTheNEW.setLayout(new FormLayout());
Composite composite2 = new Composite(compositeTheNEW, SWT.BORDER);
FormData composite2FormData = new FormData();
composite2FormData.left = new FormAttachment(0, 4);
composite2FormData.right = new FormAttachment(100, -4);
composite2FormData.top = new FormAttachment(0, 4);
composite2FormData.bottom = new FormAttachment(50, -4);
composite2.setLayoutData(composite2FormData);
//composite2.setLayout(new RowLayout());
Composite composite3 = new Composite(compositeTheNEW, SWT.BORDER);
FormData composite3FormData = new FormData();
composite3FormData.left = new FormAttachment(0, 4);
composite3FormData.right = new FormAttachment(100, -4);
composite3FormData.top = new FormAttachment(composite2, 4);
composite3FormData.bottom = new FormAttachment(100, -4);
composite3.setLayoutData(composite3FormData);
form.setWeights(new int[] {30, 70});
shell.setSize(800, 600);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
Re: Layouts [message #461051 is a reply to message #461047] |
Thu, 15 September 2005 05:07   |
Hi David,
The problem is that you've created only one SashForm instance.
Here is the code modified:
package Test;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.SashForm;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class test {
rightComposite.setLayout(new GridLayout());
SashForm sashForm2 = new SashForm(rightComposite, SWT.VERTICAL);
sashForm2.setLayout(new GridLayout());
GridData gridData = new GridData();
gridData.grabExcessHorizontalSpace = true;
gridData.grabExcessVerticalSpace = true;
gridData.horizontalAlignment = GridData.FILL;
gridData.verticalAlignment = GridData.FILL;
sashForm2.setLayoutData(gridData);
Composite composite2 = new Composite(sashForm2, SWT.BORDER);
composite2.setLayoutData(gridData);
Composite composite3 = new Composite(sashForm2, SWT.BORDER);
composite3.setLayoutData(gridData);
shell.open();
display.sleep();
display.dispose();
Re: Layouts [message #461068 is a reply to message #461051] |
Thu, 15 September 2005 08:46  |
Thank you very much - I've been trying to get this to work for weeks
(newcomer to JAVA)
FUDForum. Page generated in 0.03864 seconds
